I followed the instructions at snapcraft to install the PowerShell snap. When I started pwsh
, I received the error
No usable version of libssl was found
The solution was to add openssl-1.0
via pacman
sudo pacman -S openssl-1.0
Therefore the complete instructions for installing the PowerShell snap on Manjaro 21.1 are:
sudo systemctl enable --now snapd.socket
sudo ln -s /var/lib/snapd/snap /snap
- Log out and back in again to ensure snap’s paths are updated correctly.
sudo snap install powershell --classic
You can then run pwsh
in Terminal or search for ‘PowerShell’ in your application menu.
Regards,
