Hi,
i cant install anything anymore. It is a fresh install of latest manjaro. I only installed gnome-terminal yesterday (see other thread from me).
Now, im back from work, and wanted to update the system (pacman -Syu), and this happens:
Fehler: GPGME error: Keine Daten
:: Paketdatenbanken werden synchronisiert …
core 169,2 KiB 408 KiB/s 00:00 [######################] 100%
extra 1892,1 KiB 1816 KiB/s 00:01 [######################] 100%
community 6,7 MiB 1593 KiB/s 00:04 [######################] 100%
multilib 175,2 KiB 3,23 MiB/s 00:00 [######################] 100%
Fehler: Keine Datenbank konnte synchronisiert werden (Ungültige oder beschädigte Datenbank (PGP-Signatur))
even manually install with pacman -U didnt work. yay didnt work too. Same errors.
Hello,
You probably have to update mirrors too:
sudo pacman-mirrors -f5 && pamac update
99 luftballons might got deflated
winnie
3
If that doesn’t work, you might have to dispatch some super high tech jet fighters.
Same errors. Didnt help anything.
Cant post Log, because the Board gives a error about im not allowed to post links?!
winnie
5
What about,
sudo pacman-key --refresh-keys
Might be the case you need to do this
system
Closed
8
