==> ERROR: Unknown download protocol: manual
Aborting…
error downloading sources: oracle-sqldeveloper
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
