Manjaro suspend doesn't save my current session and other unstability issues
I have newly installed gnome version but it’s very unstable for me when I do suspend my system and comeback all my current running applications is gone and it shows welcome screen for some reason.
Also I have another issues sometimes my GPU fan suddenly ramp up at 100% when not using the system (screen is locked) and also experienced some graphics glitched(colored) when I wake up from sleep(suspend).
system:
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=6d231d41-c3f6-41b8-9d6f-6fa0eeacc3b8 rw quiet splash apparmor=1
  Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
  Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.D0
    date: 11/07/2019
  RAM: total: 15.63 GiB used: 2.66 GiB (17.0%)
  RAM Report:
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2245 high: 3604 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2197 2: 2058
    3: 2056 4: 2056 5: 2197 6: 2196 7: 2199 8: 2200 9: 3604 10: 2057 11: 2134
    12: 2181 13: 2199 14: 2199 15: 2200 16: 2198 bogomips: 115232
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    conditional, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 26:00.0 chip-ID: 1002:67df
    class-ID: 0300
  Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
    loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 26:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: Kingston HyperX 7.1 Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0951:16a4
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.42 running: yes
    vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
  IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 945.95 GiB used: 30.84 GiB (3.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
    model: KIOXIA TransMemory size: 14.43 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
  ID-1: / raw-size: 856.99 GiB size: 842.54 GiB (98.31%)
    used: 30.84 GiB (3.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 6d231d41-c3f6-41b8-9d6f-6fa0eeacc3b8
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 39D2-F0EA
  ID-3: /run/media/test/Network raw-size: 33.41 GiB size: 32.59 GiB (97.54%)
    used: 24 KiB (0.0%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: Network
    uuid: f6896a85-e905-4566-a63e-36fd5af4956f
  ID-1: swap-1 type: partition size: 7.47 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda4 maj-min: 8:4 label: swap
    uuid: abb56ead-53c0-4b4d-8775-9cd82cb3cc36
  ID-1: /dev/sda3 maj-min: 8:3 size: 33.35 GiB fs: ext4 label: Files
    uuid: 0938f90b-f11a-497b-9a79-3f0758e8d08a
  ID-2: /dev/sdb1 maj-min: 8:17 size: 3.31 GiB fs: iso9660
  ID-3: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 928C-E79F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-4:2 info: Kingston HyperX 7.1 Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 0951:16a4 class-ID: 0300
    serial: <filter>
  Device-2: 1-5:3 info: NZXT Smart Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 1e71:1714 class-ID: 0300 serial: <filter>
  Device-3: 1-7:4 info: Cooler Master AMD SR4 lamplight Control
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
  Device-4: 1-8:5 info: Cooler Master Masterkeys Lite L Combo RGB Mouse
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 350mA chip-ID: 2516:0044 class-ID: 0300
  Device-5: 1-9:6 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 100mA chip-ID: 2516:0042 class-ID: 0301
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-3:2 info: KIOXIA TransMemory type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 504mA
    chip-ID: 30de:6545 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 55.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 798
  Processes: 373 Uptime: 19m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1262 lib: 352
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
Also I noticed some weird switch sound come from my case minutes after suspend. I’m not sure about that
Maybe most importantly: [HowTo] Provide System Information
I fixed this by:
  • Downgrading kernel from 5.15 to 5.10
  • Switching from Wayland to Xorg
  • Created swap partition for hibernation
