It seems that installing mhwd
automatically installs the older mhwd nvidia driver 390xx. Is that behaviour by design? Would that conflict with mhwd-nvidia-450xx
No, those are just database module-ids, not drivers.
Oops my bad, thanks for clarifying this. If I may ask a follow up it seems that mhwd
is intertwined with mhwd-nvidia-390xx
, removing it requires removing mhwd-db
and mhwd
. Why is that so, wouldn’t it be better to have only mhwd
and mhwd-db
without mhwd-nvidia-390xx
MHWD can’t do it’s job without it’s database and module-ids.
Thanks, it just seemed a bit odd that it brings an older database module-id rather than a newer one like for instance mhwd-nvidia-450xx
, that’s all.
I know what you mean. It seems odd that mhwd-db
depends on both mhwd-nvidia-390xx
and mhwd-nvidia>=455
at the same time.
They’re now the only supported proprietary NVIDIA drivers, so MHWD needs the module-ids to detect video cards.
Wouldn’t mhwd-nvidia-390xx
work better as an optional dependency?
No, because then it wouldn’t be installed by default and couldn’t detect video cards supported by it. I’ve already explained why it’s there.
Hmm… I see.
Got it, and I guess now nvidia drivers (i.e. latest) are renamed from nvidia-455xx into just nvidia.
e.g.
linux414-nvidia-455xx --> linux414-nvidia
mhwd-nvidia-455xx --> mhwd-nvidia
Here’s another confusion that I have what does mhwd
bring to the table that pacman can’t do?
I guess the question is if we can install nvidia drivers using pacman why do we need mhwd (besides easy of use) or am I missing sth fundamental?
