I’m trying to build a simple docker container that runs manjaro-arm-installer
on a most updated Manjaro Minimal Linux OS.
This is what I have:
# Build Manjaro-arm-installer Docker container
FROM jonathonf/manjaro:latest
LABEL version="0.1"
LABEL maintainer="Folaht"
LABEL release-date="2021-04-31"
# Install keyrings
RUN pacman-key --init
RUN pacman-key --populate archlinux
RUN pacman-key --populate manjaro
RUN pacman-key --refresh-keys
RUN yes | pacman -Sy archlinux-keyring manjaro-keyring
# Update Manjaro Linux OS
RUN pacman -Sc
RUN pacman -Syyuu
RUN pacman-mirrors --fasttrack
# Install dependencies
RUN yes | pacman -S btrfs-progs
# Install Manjaro Arm Installer
RUN yes | pacman -S manjaro-arm-installer
# Run command on Docker launch
CMD ["manjaro-arm-installer"]
And this is the error I’m getting:
gpg: refreshing 131 keys from hkps://hkps.pool.sks-keyservers.net
gpg: keyserver refresh failed: General error
==> ERROR: A specified local key could not be updated from a keyserver.
The command '/bin/sh -c pacman-key --refresh-keys' returned a non-zero code: 1
gpg: refreshing 131 keys from hkp://pgp.mit.edu
gpg: keyserver refresh failed: No keyserver available
The command '/bin/sh -c pacman-key --refresh-keys --keyserver hkp://pgp.mit.edu' returned a non-zero code: 1
gpg: public key DB323392796CA067 is 3037 days newer than the signature
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 22 signed: 71 trust: 0-, 0q, 0n, 22m, 0f, 0u
gpg: depth: 2 valid: 65 signed: 19 trust: 65-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2021-08-02
The command '/bin/sh -c pacman-key --refresh-keys --keyserver hkp://pool.sks-keyservers.net' returned a non-zero code: 1
I think I should be asking for something much more general.
FROM manjarolinux/base:latest
LABEL version="0.1"
# Install keyrings and refresh keys
RUN pacman -Sc
RUN yes | pacman -Syyuu
CMD ["/usr/bin/manjaro-arm-installer"]
