Installing GPU drivers (CUDA) breaks system
CUDA or its dependencies are breaking my system upon reboot after installation. This requires a timeshift restoration and has been replicated to occur. This system is 2 days old.
  • The exact issue occurs at the 3 dots going dark grey after decrypting the drive.
  • Ctrl + f2 let’s me use timeshift or access the journals which were not of much use to me anyway.
  • Let me know what further can help…
Inxi below. But:
  • GTX 1070
$ sudo pacman -S cuda         ✔
[sudo] Passwort für USER:
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Warnung: Abhängigkeits-Zyklus entdeckt:
Warnung: eglexternalplatform wird vor seiner Abhängigkeit nvidia-utils installiert werden
Pakete (5) egl-wayland-2:1.1.11-4  eglexternalplatform-1.1-2  nvidia-utils-530.41.03-4  opencl-nvidia-530.41.03-4  cuda-12.1.1-1
inxi:
$ inxi -fazy -v1         ✔
  Kernel: 6.2.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
    root=UUID=bd3cd218-dc9e-44aa-ae15-c03d3d53a76d rw quiet
    cryptdevice=UUID=6c9819af-598f-4116-8378-6f8f7eef755a:luks-6c9819af-598f-4116-8378-6f8f7eef755a
    root=/dev/mapper/luks-6c9819af-598f-4116-8378-6f8f7eef755a splash
    resume=/dev/mapper/luks-996ebde6-e025-49f2-85ca-3e28186ab136
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2368 high: 3600 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2733 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2789 10: 2200 11: 2200
    12: 3600 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2484 19: 2200
    20: 2200 21: 2876 22: 2200 23: 2752 24: 2200 bogomips: 177681
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
    driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1 empty: DP-2, DP-3, DVI-D-1, HDMI-A-1 bus-ID: 08:00.0
    chip-ID: 10de:1b81 class-ID: 0300 temp: 53.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau resolution: 3440x1440
  API: OpenGL v: 4.3 Mesa 23.0.3 renderer: NV134 direct-render: Yes
  Local Storage: total: 2.05 TiB used: 84.25 GiB (4.0%)
  Processes: 480 Uptime: 4m wakeups: 2 Memory: available: 62.71 GiB
  used: 5.52 GiB (8.8%) Init: systemd v: 252 default: graphical tool: systemctl
  Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1363
  libs: 358 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
CUDA requires the proprietary NVIDIA driver. See Configure Graphics Cards - Manjaro
