Hey all, I’ve been using Manjaro in a VM for a while but am encountering an issue preventing a hardware installation.
Native monitor resolution is 2560x1440 @ 144hz
When booting to the live USB, grub and most of the startup process displays fine until around the time the startup script finishes then the screen resizes to a tiny 640x480 box.
Can not continue with installation as the windows for calamaries are larger than 640x480 so I can not interact with the installation.
Display settings only show the option of 640x480 @ 60hz
If I had an actual installation I think I would try to add a 10_monitor.conf to the X11 conf but this is useless in my situation as I am still on the live USB ISO which is immutable.
Please help this is incredibly frustrating. Thank you.
Additional info:
[manjaro@manjaro ~]$ inxi -Fxz
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX TRX40-XE GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 1402 date: 01/15/2021
Device-1: hid-0003:17EF:60EE.0004-battery
model: Lenovo TrackPoint Keyboard II charge: N/A status: N/A
Info: 24-Core (3-Die) model: AMD Ryzen Threadripper 3960X bits: 64
type: MT MCP MCM arch: Zen 2 rev: 0 cache: L2: 12 MiB
bogomips: 364224
Speed: 2194 MHz min/max: 2200/3800 MHz boost: enabled
Core speeds (MHz): 1: 2194 2: 2193 3: 2194 4: 2195 5: 2194 6: 2194
7: 2196 8: 2195 9: 2194 10: 2195 11: 2196 12: 2193 13: 2196 14: 2197
15: 2198 16: 2196 17: 2191 18: 2196 19: 2194 20: 2192 21: 1971
22: 3590 23: 2052 24: 2052 25: 2194 26: 2192 27: 2195 28: 2191
29: 2194 30: 2193 31: 2195 32: 2195 33: 2193 34: 2196 35: 3588
36: 2195 37: 2195 38: 2195 39: 2194 40: 2197 41: 2195 42: 2196
43: 2195 44: 2054 45: 2194 46: 2195 47: 2192 48: 2195
Device-1: AMD vendor: XFX Limited driver: amdgpu v: kernel
bus-ID: 03:00.0
Display: server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 640x480~60Hz
OpenGL:
renderer: AMD SIENNA_CICHLID (DRM 3.40.0 5.10.42-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: N/A
bus-ID: 22:00.4
Device-3: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-6:7
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169
v: kernel port: c000 bus-ID: 43:00.0
IF: enp67s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel port: b000 bus-ID: 44:00.0
IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: b000
bus-ID: 45:00.0
IF: wlp69s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 7-6:3
Local Storage: total: 1.94 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS200T1X0E-00AFY0
size: 1.82 TiB temp: 49.9 C
ID-2: /dev/sda type: USB vendor: Samsung model: Flash Drive
Message: No partition data found.
System Temperatures: cpu: 44.0 C mobo: 0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 678 Uptime: 28m Memory: 125.73 GiB used: 5.13 GiB (4.1%)
Init: systemd Compilers: gcc: N/A Packages: 1218 Shell: Bash v: 5.1.8
inxi: 3.3.04
I also think I may be able to manually set the output resolution via xrandr, unfortunately I am new to xrandr so my attempts so far to add a 2560x1440 output results in an out of range error, I must be doing it wrong.
Ok solved. Was on the right track with xrandr, solution was as follows:
xrandr --newmode "2560x1440R" 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
xrandr --addmode DisplayPort-0 2560x1440R
From there use " xrandr – output" or select via GUI.
system
Closed
25 July 2021 18:38
5
