Hi,
today I tried to install the latest build of Manjaro LxQT.
I put it on an USB drive and booted it.
All fine.
I went through the install dialouge and finished… an it happend nothing.
The window closes… nothing more.
If I try it with commandline I can’t start calamares
KDSingleApplicationGuard: Could neither create nor attach to shared memory segment.
QSharedMemomry::create() failed: QSharedMemoryPrivate::initKey: Es kann kein Schlüssel für die Sperrung gesetzt werdenQSharedMemomry::attach() failed: QSharedMemoryPrivate::initKey: Es kann kein Schlüssel für die Sperrung gesetzt werden
KDSingleApplicationGuard::instances: need to be operational to report on other instances
Calamares is already running, shutting down`
or try it with calamares_polkit (don't know the difference) it starts and shows this
` calamares_polkit
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
12:43:52 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
12:43:52 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
/usr/bin/calamares_polkit: Zeile 6: 5817 Speicherzugriffsfehler (Speicherabzug geschrieben) pkexec --disable-internal-agent "/usr/bin/calamares" "$@"
