Installed xfce 18.1.0 rc8 Testing
Great install, not one hiccup. using UEFI on AMD equipment with Nvidia, see specs:
bob@Manjaro-Testing~$ inxi-Fxzc0
  Host: Manjaro-Testing Kernel: 5.3.0-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 9.1.0 Desktop: Xfce 4.14.1 Distro: Manjaro Linux
  Type: Desktop System: Hewlett-Packard product: HP EliteDesk 705 G1 SFF
  v: N/A serial: <filter>
  Mobo: Hewlett-Packard model: 2215 serial: <filter> UEFI: Hewlett-Packard
  v: L06 v02.30 date: 03/22/2018
  Device-1: hidpp_battery_0 model: Logitech M570 charge: 95%
  status: Discharging
  Topology: Quad Core model: AMD A10-6800K APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
  bogomips: 32752
  Speed: 2919 MHz min/max: 2000/4100 MHz Core speeds (MHz): 1: 2804 2: 2350
  3: 2118 4: 2227
  Device-1: NVIDIA GK208 [GeForce GT 720] vendor: Micro-Star MSI
  driver: nvidia v: 430.40 bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.5 driver: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GT 720/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40
  direct render: Yes
  Device-1: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k5.3.0-1-MANJARO
  Device-1: Broadcom and subsidiaries NetXtreme BCM5762 Gigabit Ethernet PCIe vendor: Hewlett-Packard driver: tg3 v: 3.137 port: e000 bus ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
  bus ID: 3-1:2
  IF: wlp0s19f2u1 state: up mac: <filter>
  Local Storage: total: 2.73 TiB used: 67.04 GiB (2.4%)
  ID-1: /dev/sda vendor: Seagate model: ST2000VM002-9UY166 size: 1.82 TiB
  ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08M2NA0
  ID-1: / size: 911.41 GiB used: 26.23 GiB (2.9%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 8.80 GiB used: 13.3 MiB (0.1%) fs: swap dev: /dev/sda3
  System Temperatures: cpu: 20.4 C mobo: N/A gpu: nvidia temp: 55 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
  Processes: 178 Uptime: 1h 25m Memory: 7.76 GiB used: 1.08 GiB (14.0%)
  Init: systemd Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7 inxi: 3.0.35
Mines just writing now - I'll see you on the other side :wink:
[EDIT - either desktop fails to load or screen is forced-black. either way unusable for me on first try]
First check your download with sha1sum or something similar. I used a USB drive written by balenaEtcher to install.
