I’ve experienced a bug since weeks on my day to dy laptop.
If I’m booting or rebooting my laptop and forgot to disable Gnome extensions, my first connection to gnome is very long and after some times, it return on login screen and I can log into Gnome without issue (with Gnome extension disabled automatically).
I’ve not experienced that on 2 others devices, only this.
Did anyone have the same problem ?
I don´t know if I can show gnome extensions logs ?
I tried to disabled all extensions, keep only extension that I’m using on others devices but no changes, If I keep gnome extension enabled, my first login fail after some times.
I’m on Gnome 42.2 but It happened also before Gnome 42.
I’m not a Gnome user, so I doubt I’ll be able to offer much, if any help. However, I can point you in the correct direction to give the necessary info so those that can help are able to do so.
