Installed manjaro-pipewire and had interrupted sound, then installed pulseaudio
I had installed manjaro-pipewire.
I had interrupted sound with audio playback from wav files and internet radio stream.
I have removed manjaro-pipewire and installed manjaro-pulse.
Now I have no audio playback.
inxi -Fza:
  Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=ea34cc1e-e69b-4519-bb9a-dfb3ec61db74 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
  Type: Server System: Supermicro product: X10SRA v: 0123456789
    serial: <superuser required> Chassis: type: 17 v: 0123456789
  Mobo: Supermicro model: X10SRA v: 1.01 serial: <superuser required>
    UEFI: American Megatrends v: 2.1a date: 10/24/2018
  Info: model: Intel Core i7-6800K bits: 64 type: MT MCP arch: Broadwell
    gen: core 6 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 15 MiB desc: 1x15 MiB
  Speed (MHz): avg: 1658 high: 3800 min/max: 1200/3800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1200
    4: 1500 5: 1200 6: 3800 7: 1200 8: 1200 9: 1200 10: 1200 11: 3800 12: 1200
    bogomips: 81624
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nvidia v: 545.29.06
    alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
    2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.0
    chip-ID: 10de:2182 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26") monitors: <missing: xrandr>
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2182
    surfaces: xcb,xlib
  Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
    class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 10de:1aeb class-ID: 0403
  API: ALSA v: k6.1.71-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
    chip-ID: 8086:1533 class-ID: 0200
  Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.38 TiB used: 267.34 GiB (19.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 22.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.84 GiB (10.1%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 160 MiB (16.4%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-4: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
    used: 14.34 GiB (4.9%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
  ID-5: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
    used: 9.24 GiB (29.2%) fs: ext4 dev: /dev/nvme0n1p10 maj-min: 259:10
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 18.0 C pch: 27.5 C mobo: N/A gpu: nvidia
    temp: 30 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 38%
  Processes: 305 Uptime: 1m wakeups: 0 Memory: total: 32 GiB
  available: 31.23 GiB used: 2.5 GiB (8.0%) Init: systemd v: 255
  Packages: pm: pacman pkgs: 1260 libs: 402 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Please post more information about audio cards detected in PulseAudio
pactl list cards
and configuration of modules, sinks and sources
pacmd dump
pactl list cards
Karte #0
        Treiber: module-alsa-card.c
        Owner-Modul: 6
        Eigenschaften:
                alsa.card = "1"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xfb080000 irq 96"
                device.bus_path = "pci-0000:03:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "1aeb"
                device.product.name = "TU116 High Definition Audio Controller"
                device.string = "1"
                device.description = "TU116 High Definition Audio Controller"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Profile:
                output:hdmi-stereo: Digital Stereo (HDMI)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 38668, verfügbar: ja)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
                output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
                off: Aus (Ziele: 0, Quellen: 0, Priorität: 0, verfügbar: ja)
        Aktives Profil: output:hdmi-stereo
        Ports:
                hdmi-output-0: HDMI / DisplayPort (Typ: HDMI, Priorität: 5900, Latenzversatz: 0 usec, verfügbar)
                        Eigenschaften:
                                device.product.name = "DELL U2713HM
                        Teil der/des Profil(s): output:hdmi-stereo
                hdmi-output-1: HDMI / DisplayPort 2 (Typ: HDMI, Priorität: 5800, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                        Teil der/des Profil(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
                hdmi-output-2: HDMI / DisplayPort 3 (Typ: HDMI, Priorität: 5700, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                        Teil der/des Profil(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
                hdmi-output-3: HDMI / DisplayPort 4 (Typ: HDMI, Priorität: 5600, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                        Teil der/des Profil(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Karte #1
        Owner-Modul: 7
        Eigenschaften:
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0xfb610000 irq 95"
                device.bus_path = "pci-0000:00:1b.0"
                sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "8d20"
                device.product.name = "C610/X99 series chipset HD Audio Controller"
                device.string = "0"
                device.description = "Internes Audio"
        Profile:
                input:analog-stereo: Analog Stereo-Eingabe (Ziele: 0, Quellen: 1, Priorität: 65, verfügbar: nein)
                output:analog-stereo: Analog Stereo-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 39268, verfügbar: ja)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (Ziele: 1, Quellen: 1, Priorität: 6565, verfügbar: ja)
                output:analog-surround-21: Analog Surround 2.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 34068, verfügbar: ja)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: ja)
                output:analog-surround-40: Analog Surround 4.0-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 33968, verfügbar: ja)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1265, verfügbar: ja)
                output:analog-surround-41: Analog Surround 4.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 34068, verfügbar: ja)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: ja)
                output:analog-surround-50: Analog Surround 5.0-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 33968, verfügbar: ja)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1265, verfügbar: ja)
                output:analog-surround-51: Analog Surround 5.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 34068, verfügbar: ja)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: ja)
                output:iec958-stereo: Digital Stereo (IEC958)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 38268, verfügbar: ja)
                output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958)-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 5565, verfügbar: ja)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 300, verfügbar: ja)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3)-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 365, verfügbar: nein)
        Aktives Profil: output:analog-stereo
        Ports:
                analog-input-front-mic: Front Microphone (Typ: Mikro, Priorität: 8500, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                        Teil der/des Profil(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-rear-mic: Rear Microphone (Typ: Mikro, Priorität: 8200, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                analog-input-linein: Line In (Typ: Line, Priorität: 8100, Latenzversatz: 0 usec, nicht verfügbar)
                analog-output-lineout: Line Out (Typ: Line, Priorität: 9000, Latenzversatz: 0 usec, verfügbar)
                        Teil der/des Profil(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
                analog-output-headphones: Headphones (Typ: Kopfhörer, Priorität: 9900, Latenzversatz: 0 usec, nicht verfügbar)
                        Eigenschaften:
                iec958-stereo-output: Digital Output (S/PDIF) (Typ: SPDIF, Priorität: 0, Latenzversatz: 0 usec, Verfügbarkeit unbekannt)
                        Teil der/des Profil(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
pacmd dump
Karte #0
        Owner-Modul: 6
        Eigenschaften:
                alsa.card = "1"
                device.bus = "pci"
                device.string = "1"
        Profile:
        Ports:
                        Eigenschaften:
                        Eigenschaften:
                        Eigenschaften:
                        Eigenschaften:
Karte #1
        Owner-Modul: 7
        Eigenschaften:
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Profile:
        Ports:
                        Eigenschaften:
                        Eigenschaften:
                        Eigenschaften:
Response from pactl list cards shows 2 cards with 2 available audio outputs
Karte #0
        Owner-Modul: 6
        Eigenschaften:
                alsa.card = "1"
        Ports:
                        Eigenschaften:
Karte #1
        Owner-Modul: 7
        Eigenschaften:
                alsa.card = "0"
        Ports:
Correct response from pacmd dump would have shown which of the 2 outputs are set as default sink
and if either sink was muted/suspended
I suggest disable the output:hdmi-stereo sink that might be playing audio over HDMI to Dell monitor
so audio can only play to analog-output-lineout - green 3.5mm jack on rear panel
pactl set-card-profile alsa_card.pci-0000_03_00.1 off
And check the remaining sink output is not muted or suspended when audio is playing
pactl list sinks
