I have a problem with the touchscreen. It works the other way around: if I press in the upper right corner, I get a click in the lower right corner (It is mirrored on the horizontal axis).
I read archlinux wiki touchscreen, I check that I have “xf86-input-evdev” and try xinputcalibrator:
~ xinput_calibrator ✔ 14s
Warning: multiple calibratable devices found, calibrating last one (xwayland-touch:17)
use --device to select another one.
Calibrating standard Xorg driver "xwayland-touch:17"
current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535
If these values are estimated wrong, either supply it manually with the --precalib option, or run the 'get_precalib.sh' script to automatically get it (through HAL).
--> Making the calibration permanent <--
copy the snippet below into '/etc/X11/xorg.conf.d/99-calibration.conf'
Section "InputClass"
Identifier "calibration"
MatchProduct "!!Name_Of_TouchScreen!!"
Option "MinX" "-431"
Option "MaxX" "65758"
Option "MinY" "65441"
Option "MaxY" "256"
EndSection
Change '!!Name_Of_TouchScreen!!' to your device's name in the config above.
~ cat /etc/X11/xorg.conf.d/99-calibration.conf INT ✘
Option "MaxY" "256"
EndSection
The problem persists even after rebooting.
~ inxi -Fz ✔
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 Desktop: GNOME 41.1
Distro: Manjaro Linux
Type: Desktop System: Chuwi product: Hi13 v: Reserved
serial: <superuser required>
Mobo: Hampoo model: I2W6_AP135 v: Hampoo Reserved
serial: <superuser required> UEFI: American Megatrends v: I2W6_AP135.041
date: 08/21/2017
ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/37.0 Wh (100.0%)
volts: 7.4 min: 7.4
Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP cache:
L2: 4 MiB
Speed: 1811 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2088 2: 2089
3: 2087 4: 2088
Device-1: Intel HD Graphics 500 driver: i915 v: kernel
Display: wayland server: X.org 1.21.1.1 driver: loaded: i915
note: n/a (using device driver) - try sudo/root
OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 21.2.5
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit
driver: N/A
Device-2: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
Local Storage: total: 58.24 GiB used: 8.28 GiB (14.2%)
ID-1: /dev/mmcblk1 vendor: HP model: DF4064 size: 58.24 GiB
ID-1: / size: 56.74 GiB used: 8.28 GiB (14.6%) fs: ext4
dev: /dev/mmcblk1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/mmcblk1p1
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 233 Uptime: 17m Memory: 3.65 GiB used: 3.36 GiB (91.8%)
Shell: Zsh inxi: 3.3.09
