Installed Manjaro 18.0.3-pre3 Illyria
#1
No problems with install, thanks.
[bob@Manjaro-Testing ~]$ inxi -Fxzc0
  Host: Manjaro-Testing Kernel: 4.20.10-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 8.2.1 Desktop: Xfce 4.13.2git-UNKNOWN
  Distro: Manjaro Linux
  Type: Desktop System: LENOVO product: 10181 v: Lenovo K450e
  serial: <filter>
  Mobo: LENOVO model: N/A v: 31900058 STD serial: <filter> BIOS: LENOVO
  v: I1KT38AUS date: 06/10/2014
  Device-1: hidpp_battery_0 model: Logitech M570 charge: 90%
  status: Discharging
  Topology: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP
  arch: Haswell rev: 3 L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25555
  Speed: 998 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 998 2: 998
  3: 998 4: 998
  Device-1: NVIDIA GK208 [GeForce GT 720] vendor: Micro-Star MSI
  driver: nvidia v: 415.27 bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.3 driver: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GT 720/PCIe/SSE2 v: 4.6.0 NVIDIA 415.27
  direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k4.20.10-1-MANJARO
  vendor: Lenovo driver: r8168 v: 8.045.08-NAPI port: d000 bus ID: 03:00.0
  Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
  vendor: Lenovo driver: rtl8821ae v: kernel port: c000 bus ID: 04:00.0
  IF: wlp4s0 state: down mac: <filter>
  Local Storage: total: 1.82 TiB used: 57.59 GiB (3.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08M2NA0
  ID-2: /dev/sdc type: USB vendor: Western Digital model: WD Elements 25A2
  ID-1: / size: 453.11 GiB used: 23.52 GiB (5.2%) fs: ext4 dev: /dev/sda3
  ID-2: swap-1 size: 8.80 GiB used: 6.5 MiB (0.1%) fs: swap dev: /dev/sda2
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 53 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
  Processes: 187 Uptime: 51m Memory: 7.72 GiB used: 889.9 MiB (11.3%)
  Init: systemd Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0 inxi: 3.0.30
[Testing Update] 2019-02-18 - Systemd, Wine-Staging, Texlive, Python, Haskell
