Hello, I just upgraded from kernel 4.19.152 to 5.4.72 and some errors popped up.
How to resolve them ???
$ sudo journalctl -p 3 -xb
-- Logs begin at Sun 2019-03-03 18:25:48 CET, end at Wed 2020-10-21 20:29:19 CEST. --
Oct 21 20:28:09 HELLRIDER kernel: usbhid 4-1.1:1.1: couldn't find an input interrupt endpoint
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D0: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D2: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D3: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D4: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D5: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D6: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: hdaudio hdaudioC1D7: no AFG or MFG node found
Oct 21 20:28:10 HELLRIDER kernel: snd_hda_intel 0000:01:00.1: no codecs initialized
Oct 21 20:28:24 HELLRIDER lightdm[1071]: gkr-pam: unable to locate daemon control file
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
and if that doesn’t contain any info on usbhid 4-1.1:1.1, an lsusb too please.
This is all the relevant info from the command about system, machine, audio and usb.
The usbhid 4-1.1:1.1 is under usbhid 3-1.1:1.1 today according to the errors from today(all the same except the usbhid) journalctl its Device-1: 3-1.1:3 in the log above its the mouse(Genius Gaming Mouse X-G200).
In regard to the
Currently none. Microphone is working, AUX is working, Speakers are working, so I really don’t know why are the errors from the journalctl appearing???
I’ve marked the below answer as the solution to your question:
In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this:
so that the next person that has the same problem as you will now find a “solved” question.
