I want to install Manjaro but when I boot I 1. can’t connect to the internet and 2 (more importantly) it does not recognize my Hard disk. (checked through running lsblk in terminal) The non-recognition of my hard drive is a problem the windows 10 installer has as well. On Ubuntu it works just fine. How can I fix this so Manjaro can install?
Edit: I put this in the XFCE section since I used the XFCE iso
Here’s the output of sudo lshw done from my computer if it’s of any help in fixing this:
> ubuntu
> description: Notebook
> product: HP Laptop 17-cn0xxx (37P29UA#ABA)
> vendor: HP
> version: Chassis Version
> serial: 5CG1146BRZ
> width: 64 bits
> capabilities: smbios-3.3.0 dmi-3.3.0 smp vsyscall32
> configuration: boot=normal chassis=notebook family=103C_5335KV HP Notebook sku=37P29UA#ABA uuid=12B834C9-F067-4FB9-A871-4BA1E4C42277
> *-core
> description: Motherboard
> product: 883C
> vendor: HP
> physical id: 0
> version: 69.16
> serial: PLKTQ00WBF17HI
> slot: Base Board Chassis Location
> *-firmware
> description: BIOS
> vendor: AMI
> physical id: 0
> version: F.03
> date: 03/11/2021
> capacity: 8MiB
> capabilities: pci upgrade shadowing cdboot bootselect edd smartbattery biosbootspecification netboot uefi
> *-memory
> description: System Memory
> physical id: 11
> slot: System board or motherboard
> *-bank:0
> description: SODIMM [empty]
> physical id: 0
> slot: Bottom - Slot 1 (left)
> *-bank:1
> description: SODIMM DDR4 Synchronous 3200 MHz (0.3 ns)
> product: HMA81GS6DJR8N-XN
> vendor: SK Hynix
> physical id: 1
> serial: 7489D726
> slot: Bottom - Slot 2 (right)
> width: 64 bits
> clock: 3200MHz (0.3ns)
> *-cache:0
> description: L1 cache
> physical id: 29
> slot: L1 Cache
> capacity: 96KiB
> capabilities: synchronous internal write-back data
> configuration: level=1
> *-cache:1
> physical id: 2a
> slot: L1 Cache
> capacity: 64KiB
> capabilities: synchronous internal write-back instruction
> *-cache:2
> description: L2 cache
> physical id: 2b
> slot: L2 Cache
> capacity: 2560KiB
> capabilities: synchronous internal write-back unified
> configuration: level=2
> *-cache:3
> description: L3 cache
> physical id: 2c
> slot: L3 Cache
> capacity: 6MiB
> configuration: level=3
> *-cpu
> description: CPU
> product: 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz
> vendor: Intel Corp.
> physical id: 2d
> bus info: cpu@0
> version: 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz
> serial: To Be Filled By O.E.M.
> slot: U3E1
> capacity: 4100MHz
> width: 64 bits
> clock: 100MHz
> capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l2 invpcid_single cdp_l2 ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves split_lock_detect dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid movdiri movdir64b fsrm avx512_vp2intersect md_clear flush_l1d arch_capabilities cpufreq
> configuration: cores=2 enabledcores=2 threads=4
> *-pci
> description: Host bridge
> product: Intel Corporation
> vendor: Intel Corporation
> physical id: 100
> bus info: pci@0000:00:00.0
> version: 01
> width: 32 bits
> clock: 33MHz
> *-display
> description: VGA compatible controller
> physical id: 2
> bus info: pci@0000:00:02.0
> logical name: /dev/fb0
> version: 01
> width: 64 bits
> clock: 33MHz
> capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
> configuration: depth=32 driver=i915 latency=0 mode=1600x900 visual=truecolor xres=1600 yres=900
> resources: iomemory:600-5ff iomemory:400-3ff irq:145 memory:6002000000-6002ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
> *-generic:0
> description: Signal processing controller
> physical id: 4
> bus info: pci@0000:00:04.0
> version: 01
> width: 64 bits
> clock: 33MHz
> capabilities: msi pm cap_list
> configuration: driver=proc_thermal latency=0
> resources: iomemory:600-5ff irq:16 memory:6003200000-600321ffff
> *-generic:1 UNCLAIMED
> description: System peripheral
> physical id: 8
> bus info: pci@0000:00:08.0
> version: 01
> width: 64 bits
> clock: 33MHz
> configuration: latency=0
> resources: iomemory:600-5ff memory:6003245000-6003245fff
> *-generic:2
> physical id: a
> bus info: pci@0000:00:0a.0
> version: 01
> width: 64 bits
> clock: 33MHz
> capabilities: pciexpress pm cap_list
> configuration: driver=intel-pmt latency=0
> resources: iomemory:600-5ff irq:0 memory:6003230000-6003237fff
> *-raid
> description: RAID bus controller
> product: Volume Management Device NVMe RAID Controller
> physical id: e
> bus info: pci@0000:00:0e.0
> version: 00
> width: 64 bits
> clock: 33MHz
> capabilities: raid msix pciexpress pm bus_master cap_list
> configuration: driver=vmd latency=0
> resources: iomemory:600-5ff iomemory:600-5ff irq:0 memory:6000000000-6001ffffff memory:52000000-53ffffff memory:6003100000-60031fffff
> *-usb
> description: USB controller
> product: Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller
> physical id: 14
> bus info: pci@0000:00:14.0
> version: 20
> width: 64 bits
> clock: 33MHz
> capabilities: pm msi xhci bus_master cap_list
> configuration: driver=xhci_hcd latency=0
> resources: iomemory:600-5ff irq:123 memory:6003220000-600322ffff
> *-usbhost:0
> product: xHCI Host Controller
> vendor: Linux 5.11.0-16-generic xhci-hcd
> physical id: 0
> bus info: usb@1
> logical name: usb1
> version: 5.11
> capabilities: usb-2.00
> configuration: driver=hub slots=12 speed=480Mbit/s
> *-usb:0
> description: Mass storage device
> product: USB Flash Drive
> vendor: Lexar
> physical id: 1
> bus info: usb@1:1
> version: 1.01
> serial: 50E8C59059924818E92A
> capabilities: usb-2.00 scsi
> configuration: driver=usb-storage maxpower=200mA speed=480Mbit/s
> *-usb:1
> description: Video
> product: HP True Vision HD Camera
> vendor: SunplusIT Inc
> physical id: 5
> bus info: usb@1:5
> version: 0.02
> capabilities: usb-2.01
> configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
> *-usb:2
> description: Bluetooth wireless interface
> product: Bluetooth Radio
> vendor: Realtek
> physical id: a
> bus info: usb@1:a
> version: 1.10
> serial: 00e04c000001
> capabilities: bluetooth usb-1.10
> configuration: driver=btusb maxpower=500mA speed=12Mbit/s
> *-usbhost:1
> physical id: 1
> bus info: usb@2
> logical name: usb2
> version: 5.11
> capabilities: usb-3.10
> configuration: driver=hub slots=4 speed=10000Mbit/s
> *-memory UNCLAIMED
> description: RAM memory
> product: Tiger Lake-LP Shared SRAM
> physical id: 14.2
> bus info: pci@0000:00:14.2
> version: 20
> width: 64 bits
> clock: 33MHz (30.3ns)
> capabilities: pm cap_list
> resources: iomemory:600-5ff iomemory:600-5ff memory:600323c000-600323ffff memory:6003244000-6003244fff
> *-serial:0
> description: Serial bus controller
> product: Tiger Lake-LP Serial IO I2C Controller #0
> physical id: 15
> bus info: pci@0000:00:15.0
> version: 20
> width: 64 bits
> clock: 33MHz
> capabilities: pm bus_master cap_list
> configuration: driver=intel-lpss latency=0
> resources: irq:27 memory:4017000000-4017000fff
> *-serial:1
> product: Tiger Lake-LP Serial IO I2C Controller #1
> physical id: 15.1
> bus info: pci@0000:00:15.1
> version: 20
> width: 64 bits
> clock: 33MHz
> resources: irq:40 memory:4017001000-4017001fff
> *-communication
> description: Communication controller
> product: Tiger Lake-LP Management Engine Interface
> physical id: 16
> bus info: pci@0000:00:16.0
> version: 20
> width: 64 bits
> clock: 33MHz
> capabilities: pm msi bus_master cap_list
> configuration: driver=mei_me latency=0
> resources: iomemory:600-5ff irq:146 memory:6003241000-6003241fff
> *-generic:3 UNCLAIMED
> physical id: 17
> bus info: pci@0000:00:17.0
> version: 00
> width: 32 bits
> clock: 33MHz
> *-pci
> description: PCI bridge
> product: Tiger Lake-LP PCI Express Root Port #9
> physical id: 1d
> bus info: pci@0000:00:1d.0
> version: 20
> width: 32 bits
> clock: 33MHz
> capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
> configuration: driver=pcieport
> resources: irq:122 ioport:3000(size=4096) memory:54000000-540fffff
> *-network
> description: Wireless interface
> product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
> vendor: Realtek Semiconductor Co., Ltd.
> physical id: 0
> bus info: pci@0000:01:00.0
> logical name: wlp1s0
> version: 00
> serial: 80:d2:1d:d6:9d:93
> width: 64 bits
> clock: 33MHz
> capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
> configuration: broadcast=yes driver=rtw_8821ce driverversion=5.11.0-16-generic firmware=N/A ip=10.0.0.26 latency=0 link=yes multicast=yes wireless=IEEE 802.11
> resources: irq:148 ioport:3000(size=256) memory:54000000-5400ffff
> *-isa
> description: ISA bridge
> product: Tiger Lake-LP LPC Controller
> physical id: 1f
> bus info: pci@0000:00:1f.0
> version: 20
> width: 32 bits
> clock: 33MHz
> capabilities: isa bus_master
> *-multimedia
> description: Multimedia audio controller
> product: Tiger Lake-LP Smart Sound Technology Audio Controller
> physical id: 1f.3
> bus info: pci@0000:00:1f.3
> version: 20
> width: 64 bits
> clock: 33MHz
> configuration: driver=sof-audio-pci latency=32
> resources: iomemory:600-5ff iomemory:600-5ff irq:147 memory:6003238000-600323bfff memory:6003000000-60030fffff
> *-serial:2
> description: SMBus
> product: Tiger Lake-LP SMBus Controller
> physical id: 1f.4
> bus info: pci@0000:00:1f.4
> version: 20
> width: 64 bits
> clock: 33MHz
> configuration: driver=i801_smbus latency=0
> resources: iomemory:600-5ff irq:16 memory:6003240000-60032400ff ioport:efa0(size=32)
> *-serial:3 UNCLAIMED
> product: Tiger Lake-LP SPI Controller
> physical id: 1f.5
> bus info: pci@0000:00:1f.5
> version: 20
> width: 32 bits
> clock: 33MHz
> resources: memory:50400000-50400fff
> *-sata
> description: SATA controller
> physical id: 17
> version: 20
> width: 32 bits
> clock: 66MHz
> capabilities: sata msi pm ahci_1.0 bus_master cap_list
> configuration: driver=ahci latency=0
> resources: irq:143 memory:52000000-52001fff memory:52002800-520028ff memory:52002000-520027ff
> *-pnp00:00
> product: PnP device HPQ8001
> physical id: 1
> capabilities: pnp
> configuration: driver=i8042 kbd
> *-pnp00:01
> product: PnP device PNP0c02
> physical id: 2
> capabilities: pnp
> configuration: driver=system
> *-pnp00:02
> product: PnP device PNP0b00
> physical id: 3
> capabilities: pnp
> configuration: driver=rtc_cmos
> *-pnp00:03
> product: PnP device INT3f0d
> physical id: 4
> capabilities: pnp
> *-pnp00:04
> physical id: 5
> capabilities: pnp
> *-pnp00:05
> physical id: 6
> capabilities: pnp
> *-pnp00:06
> physical id: 7
> capabilities: pnp
> *-pnp00:07
> physical id: 8
> capabilities: pnp
> *-scsi:0
> physical id: 9
> logical name: scsi1
> capabilities: emulated
> *-disk
> description: ATA Disk
> product: TOSHIBA MQ04ABF1
> vendor: Toshiba
> physical id: 0.0.0
> bus info: scsi@1:0.0.0
> logical name: /dev/sda
> version: 7C
> serial: 21IYT6QMT
> capabilities: gpt-1.00 partitioned partitioned:gpt
> configuration: ansiversion=5 guid=ee7c4949-4e41-4684-8ea1-a8fbe165e26f logicalsectorsize=512 sectorsize=4096
> *-volume:0
> description: Windows FAT volume
> vendor: mkfs.fat
> physical id: 1
> bus info: scsi@1:0.0.0,1
> logical name: /dev/sda1
> logical name: /target/boot/efi
> version: FAT32
> serial: 420a-7ad2
> capacity: 511MiB
> capabilities: boot fat initialized
> configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=EFI System Partition state=mounted
> *-volume:1
> description: EXT4 volume
> vendor: Linux
> physical id: 2
> bus info: scsi@1:0.0.0,2
> logical name: /dev/sda2
> version: 1.0
> serial: 7ac20c5c-4492-47da-9533-43bb040b94ae
> capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
> configuration: created=2021-07-18 21:32:00 filesystem=ext4 lastmountpoint=/target modified=2021-07-18 21:32:10 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro mounted=2021-07-18 21:32:10 state=mounted
> *-scsi:1
> physical id: a
> logical name: scsi2
> capabilities: emulated scsi-host
> *-disk
> description: SCSI Disk
> vendor: Lexar
> physical id: 0.0.0
> bus info: scsi@2:0.0.0
> logical name: /dev/sdb
> version: 8.07
> serial: 5
> capabilities: removable
> configuration: ansiversion=4 logicalsectorsize=512 sectorsize=512
> *-medium
> physical id: 0
> configuration: guid=561cc8d5-b62e-4d81-8984-d38f47540156
> *-volume
> vendor: MSDOS5.0
> physical id: 1
> logical name: /dev/sdb1
> logical name: /cdrom
> version: FAT32
> serial: 0c6d-a4db
> capacity: 7634MiB
> capabilities: fat initialized
> configuration: FATs=2 filesystem=fat label=UBUNTU 21_0 mount.fstype=vfat mount.options=ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=Main Data Partition state=mounted
> *-battery
> description: Lithium Ion Battery
> product: HW03041X
> vendor: 333-42-34-A
> physical id: 1
> version: 01/07/2021
> serial: 33356 01/07/2021
> slot: Primary
> capacity: 41000mWh
> configuration: voltage=11.3V ubuntu
> vendor: HP
> serial: 5CG1146BRZ
> width: 64 bits
> *-core
> product: 883C
> vendor: HP
> physical id: 0
> version: 69.16
> *-firmware
> description: BIOS
> vendor: AMI
> physical id: 0
> version: F.03
> date: 03/11/2021
> capacity: 8MiB
> *-memory
> physical id: 11
> *-bank:0
> physical id: 0
> *-bank:1
> vendor: SK Hynix
> physical id: 1
> serial: 7489D726
> width: 64 bits
> *-cache:0
> physical id: 29
> slot: L1 Cache
> capacity: 96KiB
> *-cache:1
> physical id: 2a
> slot: L1 Cache
> capacity: 64KiB
> *-cache:2
> physical id: 2b
> slot: L2 Cache
> capacity: 2560KiB
> *-cache:3
> physical id: 2c
> slot: L3 Cache
> capacity: 6MiB
> *-cpu
> description: CPU
> vendor: Intel Corp.
> physical id: 2d
> bus info: cpu@0
> slot: U3E1
> capacity: 4100MHz
> width: 64 bits
> clock: 100MHz
> *-pci
> physical id: 100
> version: 01
> width: 32 bits
> clock: 33MHz
> *-display
> physical id: 2
> version: 01
> width: 64 bits
> clock: 33MHz
> *-generic:0
> physical id: 4
> version: 01
> width: 64 bits
> clock: 33MHz
> physical id: 8
> version: 01
> width: 64 bits
> clock: 33MHz
> *-generic:2
> physical id: a
> version: 01
> width: 64 bits
> clock: 33MHz
> *-raid
> physical id: e
> version: 00
> width: 64 bits
> clock: 33MHz
> *-usb
> physical id: 14
> version: 20
> width: 64 bits
> clock: 33MHz
> *-usbhost:0
> physical id: 0
> bus info: usb@1
> logical name: usb1
> version: 5.11
> *-usb:0
> vendor: Lexar
> physical id: 1
> bus info: usb@1:1
> version: 1.01
> *-usb:1
> description: Video
> physical id: 5
> bus info: usb@1:5
> version: 0.02
> *-usb:2
> vendor: Realtek
> physical id: a
> bus info: usb@1:a
> version: 1.10
> *-usbhost:1
> physical id: 1
> bus info: usb@2
> logical name: usb2
> version: 5.11
> *-memory UNCLAIMED
> physical id: 14.2
> version: 20
> width: 64 bits
> *-serial:0
> physical id: 15
> version: 20
> width: 64 bits
> clock: 33MHz
> *-serial:1
> physical id: 15.1
> version: 20
> width: 64 bits
> clock: 33MHz
> *-communication
> physical id: 16
> version: 20
> width: 64 bits
> clock: 33MHz
> physical id: 17
> version: 00
> width: 32 bits
> clock: 33MHz
> *-pci
> physical id: 1d
> version: 20
> width: 32 bits
> clock: 33MHz
> *-network
> physical id: 0
> version: 00
> width: 64 bits
> clock: 33MHz
> *-isa
> physical id: 1f
> version: 20
> width: 32 bits
> clock: 33MHz
> *-multimedia
> physical id: 1f.3
> version: 20
> width: 64 bits
> clock: 33MHz
> *-serial:2
> description: SMBus
> physical id: 1f.4
> version: 20
> width: 64 bits
> clock: 33MHz
> physical id: 1f.5
> version: 20
> width: 32 bits
> clock: 33MHz
> *-sata
> physical id: 17
> version: 20
> width: 32 bits
> clock: 66MHz
> *-pnp00:00
> physical id: 1
> capabilities: pnp
> *-pnp00:01
> physical id: 2
> capabilities: pnp
> *-pnp00:02
> physical id: 3
> capabilities: pnp
> *-pnp00:03
> physical id: 4
> capabilities: pnp
> *-pnp00:04
> physical id: 5
> capabilities: pnp
> *-pnp00:05
> physical id: 6
> capabilities: pnp
> *-pnp00:06
> physical id: 7
> capabilities: pnp
> *-pnp00:07
> physical id: 8
> capabilities: pnp
> *-scsi:0
> physical id: 9
> logical name: scsi1
> *-disk
> vendor: Toshiba
> physical id: 0.0.0
> version: 7C
> serial: 21IYT6QMT
> *-volume:0
> vendor: mkfs.fat
> physical id: 1
> version: FAT32
> serial: 420a-7ad2
> capacity: 511MiB
> *-volume:1
> vendor: Linux
> physical id: 2
> version: 1.0
> *-scsi:1
> physical id: a
> logical name: scsi2
> *-disk
> vendor: Lexar
> physical id: 0.0.0
> version: 8.07
> serial: 5
> *-medium
> physical id: 0
> *-volume
> vendor: MSDOS5.0
> physical id: 1
> version: FAT32
> serial: 0c6d-a4db
> capacity: 7634MiB
> *-battery
> product: HW03041X
> vendor: 333-42-34-A
> physical id: 1
> version: 01/07/2021
> slot: Primary
> capacity: 41000mWh
Something else to mention: This is especially strange since Arch recognizes it and I managed to get it to boot with systemd but it hangs on the start job
Have you formatted the drive before trying to do the installation. In my experience sometimes windows formatting things has made it difficult in the past for me. In the installation media you should be able to used gparted to wipe the drive, only if you want to. Also check in the bios to see is the drive is detected. I have had drives show that they did exist, but they have failed completely. Lastly if you are looking to dual boot forum.manjaroorg/t/root-tip-dual-boot-manjaro-and-windows/1164
this will help you out
put a dot between manjaro and org
Hope that helps , have a nice night
~Woe
you should check your bios, make sure disks are set to sata.
Looks like you have an Intel RST. The “Fake Raid” or “firmware assisted Raid” need a special configuration. Better use just AHCI/SATA mode.
Seems then Ubuntu have a better auto config tool to manage a Intel RST Raid. Anyway… Firmware based Raids are dumb, because only one part is hardware based: Synchronization only just before any OS has been started. Anything else is still software raid.
Is there a way I can get email notifications? It caused me to forget about this for weeks and made me look like a real jerk abandoning a thread like this. Anyway I can’t find a way to change to AHCI mode in the UEFI. I took pictures somewhere I’ll try to send them. I had similar issues with reinstalling Windows 10 for a dual boot until I realized I needed the Intel® Rapid Storage Technology Driver Installation Software with Intel® Optane™ Memory (10th and 11th Gen Platforms)driver. Now Windows 10 is installed and I’m configuring it and making it work (now onto the task of getting it to recognize my wifi card and that the touchpad exists.) The Problem is that Driver’s only available for Windows 10 so I’m kinda stumped about how I could get it working for Manjaro. When I was playing around with Arch enabling VMD in the modules array in mkinitcpio.conf and regenerating the initramfs fixed this. I’m not sure how I could do that for a live usb though. Any ideas?
Nice You found the solution yourself.
About the live usb: By adding it to the initramfs (mkinitcpio) you recreated the init image. This image can’t be changed on the installer ISO. You will have to recreate the ISO.
I haven’t done that before. How do I recreate the ISO? (Asking cause I’ve been trying with one of those other distros I’ve been considering Solus, to mount the initrd img I’ve run
> sudo mount -o loop /media/ubuntu/SolusLiveBudgie/boot/initrd.img ./initrd-tmp
from my Ubuntu live USB (the Solus USB is a different one and I’m doing this because I currently don’t have Linux on any of my computers since I got rid of Ubuntu to install Windows 10 for a dual boot on the laptop today) and I get an error like
> mount: /home/ubuntu/Documents/initrd-tmp: wrong fs type, bad option, bad superblock on /dev/loop17, missing codepage or helper program, or other error.
How do I go about doing this?
Nevermind found something on linuxsecrets that’s very comprehensive called Remastering the Install ISO
