Installation Speed 100 times slower in package manager than via a web browser
Hello, I’m a fairly new user (installed yesterday) and have managed to make my way this far without many issues. However, I’m noticing that when I have tried to install OpenJDK-21 via Add/Remove Programs, it is almost 100 times slower (400mb/s to 4mb/s)than just installing it via a web browser. How can I fix this?
  Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=277911ef-d6af-4ac3-96fa-f5ad966720f1 rw nouveau.modeset=0 quiet
    splash udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Dell product: G5 5000 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0M6C7G v: A00 serial: <superuser required> UEFI: Dell
    v: 1.11.0 date: 09/14/2022
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.4 GiB used: 4.94 GiB (32.1%)
  Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF8
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 2793 high: 4402 min/max: 800/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4000 2: 3706 3: 800
    4: 3856 5: 800 6: 3372 7: 4402 8: 2703 9: 3512 10: 800 11: 4000 12: 2874
    13: 800 14: 4309 15: 3027 16: 1728 bogomips: 92838
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Dell driver: nvidia
    v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:21c4 class-ID: 0300
  Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:13
    chip-ID: 0c45:8006 class-ID: 0301
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 70 s-size: 1393x392mm (54.84x15.43")
    s-diag: 1447mm (56.97")
  Monitor-1: DP-0 pos: primary,left res: 1920x1080 dpi: 70
    size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
  Monitor-2: DVI-D-0 pos: left res: 1920x1080 hz: 60 dpi: 190
    size: 256x144mm (10.08x5.67") diag: 294mm (11.56") modes: N/A
  Monitor-3: HDMI-0 pos: right res: 1920x1080 dpi: 82
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  API: EGL Message: No EGL data available.
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 SUPER driver: nvidia v: 535.129.03 device-ID: 10de:21c4
    surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
    bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-3: SteelSeries ApS Arctis 5 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:6
    chip-ID: 1038:12aa class-ID: 0300 serial: <filter>
  Device-4: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.4:9
    chip-ID: 03f0:0d8b class-ID: 0300 serial: <filter>
  API: ALSA v: k6.5.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.84 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:2600
    class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:15 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 5020
    bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
  Local Storage: total: 2.73 TiB used: 21.25 GiB (0.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1001 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD20SDRW-34VUUS0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1031 scheme: MBR
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 21.25 GiB (22.2%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: ManjaroKDE
    uuid: 277911ef-d6af-4ac3-96fa-f5ad966720f1
  ID-2: /boot/efi raw-size: 24.41 GiB size: 24.4 GiB (99.95%)
    used: 352 KiB (0.0%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: C070-051F
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 809.32 GiB fs: ntfs label: Hard Drive
    uuid: 467441C17441B489
  ID-3: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: New Volume
    uuid: 1468371B6836FB56
  Device-1: 1-4:6 info: SteelSeries ApS Arctis 5 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 250mA
  Hub-2: 1-5:7 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 1-5.1:12 info: HP HyperX QuadCast S type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 03f0:048c class-ID: 0300
  Device-2: 1-5.4:9 info: HP HyperX QuadCast S type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 1-6:8 info: Tablet Monitor type: mouse driver: uclogic,usbhid
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 256c:006d class-ID: 0301
  Device-4: 1-7:10 info: Alienware LED controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
  Device-5: 1-9:11 info: Western Digital Elements 2621 type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1058:2621 class-ID: 0806
    serial: <filter>
  Device-6: 1-10:13 info: Microdia Dual Mode Camera (8006 VGA)
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  Device-7: 1-12:14 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Device-8: 1-14:15 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 53.0 C pch: 44.0 C mobo: N/A gpu: nvidia temp: 45 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 34%
  Processes: 335 Uptime: 13h 51m wakeups: 0 Init: systemd v: 254
  Packages: 1272 pm: pacman pkgs: 1259 libs: 415 tools: pamac pm: flatpak
  pkgs: 6 pm: snap pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.2.15
  running-in: konsole inxi: 3.3.31
Huh, what? Are you sure you’re using linux?
Perhaps take some more time and do some reading on mirrors: Manjaro Mirrors - Manjaro
Um, I think you don’t really know what a kernel is, so I’ve amended your thread title. Welcome, by the way! :vulcan_salute:
Now, the download speed of any package depends on the speed of the mirror selected. Therefore it is always best to first update your mirror list and have it select the fastest mirrors. :point_down:
sudo pacman-mirrors -f && sudo pacman -Syu
That said, do not install any software via a web browser. GNU/Linux does not work that way. You must use your package manager — in Arch-based distributions, this is pacman, although Manjaro also comes with pamac, which can be used both at the command line and as a graphical package manager, commonly referred to as “Add/Remove Software”.
Running that fixed my issue immediately! Thank you so much! You’re right by the way, haha. I’m still fairly new to all of this. I apologize if any of post was difficult to read, English isn’t my first language.
Well, we do offer several categories for other languages in the Languages section of the forum.
If you cannot find a category for your own language there, then you can always post in the Languages category itself while adding a tag with your language to your thread title. That way, the people who do speak your native tongue can find your thread and help you. :wink:
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
