installation of manjaro ARM lxqt on a raspberry pi 3
#1
I come here because I have a raspberry pi 3 B+ v1.2
I had raspbian to install on it and everything was working fine and I wanted to install Manjaro-ARM-lxqt-rpi3-19.04 on it I decompressed the image on my microsd and started on it, it boots well at some point it stops and nothing else
message translated with deepl
#2
i think this is hangs on fb0 ( frame buffer) for vc4 ,
coming from link HDMI or DVI ( rapberry pi3B & screen )
can you be more precise on video link
#3
HDMI :grimaçant:
#4
@strit , is there any vc4-dkms-3d in the iso manjaro ?
#5
comment le vérifier ?
#6
dans config.txt il n'y a que:
enable_uart=1
dtparam=audio=on
hdmi_drive=2
audio_pwm_mode=2
#7
No. Nor do Arch Linux ARM or the AUR.
#8
How did you burn the image to the SD card?
I recommend using Etcher or DD directly.
#9
maybe see this wiki
https://archlinuxarm.org/platforms/armv7/broadcom/raspberry-pi-2
about video & config
#10
Yeah. I have.
All the settings in that wiki is getting used in Manjaro ARM.
Video driver package and the Audio stuff too.
#11
problème résolue en fait j'avais décompresser direct sur la microsd donc j,ai recommencer en utilisant etcher et sa marche
