Manjaro does not install when I follow all instructions.
I am running Windows 10 with all the most current updates etc.
I’m using VirtualBox 6.1
I have created a virtual machine with these settings:
Name and operating system:
Name: Linux Manjaro XFCE
Machine Folder: c:\Users\jbeck\VirtualBox VMs
Type: Linux
Version: Arch Linux (64-bit)
Memory size: 3072MB
Create a virtual hard disk now: Create (yes)
Hard disk file type: VDI (VirtualBox Disk Image)
Storage on physical hard disk: Fixed size
File location and size: C:\Users\jbeck\VirtualBox VMs\Linux Manjaro XFCE\Linux Manjaro XFCE.vdi
Now when I start the machine, Manjaro loads, I go through all the steps… I get the first screen that has the “Install” option. I pick Install… I go through all the steps… name, password, I do not pick start without login/password, I do pick same password for administrator, etc… then it says all done. I select the “Restart” option.
When Manjaro restarts… it does not ask for my password… when I try to update an app, it tells me my password is incorrect.
Thanks for all the tips. I’ve got Manjaro installed. Now I’m trying to install VboxGuestAdditions.iso. I get this error message: “Unable to insert the virtual optical disk C:\Program Files\Oracle\VirtualBox\VboxGuestAsdsirions.iso into the machine Linux Manjaro.” The VboxGuestAdditions.iso does indeed live at C:\Program Files\Oracle\VirtualBox, so I am missing something here. Any tips would be appreciated.
