Trying to do a fresh install of KDE on a Dell Laptop and I cant figure out what is going on here. Calamares hangs for a minute on the very first screen. Then after I get passed creating user and click install it goes to this installation failed notification? Anyone have any idea what is going on here? Thank You in advance!!
Seems it failed to create a MSDOS partiontable. You can get version 20.1.1, which got released from here and try again. Also you may use the partitionmanager on the ISO to create that table for you.
Thank You very much @philm. I’ll try the new iso first. That same problem happens when I try to partition manually as well?
@philm Loaded up the new iso and still had the same results. I then took your other advice created MSDOS Partion and that solved my issue. Thank You very much.
Ya, sometimes with fresh harddrives some issues my occur when not formatted correctly …
