Hello! I’m new to Linux, and was installing for the first time on my Laptop, from Windows 10. Around 90% of the way through the installation (the bootloader part) I get an error saying the bootloader could not be installed with a grub-install command following. When running said command in the terminal, it returns
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of `/boot/efi’.
Any fixes? I’m installing on a DVD and using the KDE Plasma iso
PS: Sorry if some terminology is wrong, I’m new here!
You have to chroot into the local installation to run the grub-install command. The error says that it tries to install grub on the live session, what truly does not work.
Very important:
Verify your Windows installation type - is it BIOS/MBR - is it BIOS/GPT or is it plain EFI/GPT.
This is not a flaw of Manjaro but important to know because Manjaro needs to be installed using the same mode - and it is not always obvious which mode to use.
