Hey, im trying to install msoffice 2016 on playonmanjaro but I got stuck in a part that says to select the setup ISO file, but I dont have one and cant find one. What can I do?
How would you install MS Office without the installation media?
Thats what I am trying to find
You don’t. It’s a commercial product, so you need to buy it.
i have the licence, but how can I get the ISO file?
On the Microsoft download page.
Honestly, this is pretty basic stuff. Are you sure you are up for the task of running a rolling distribution based on Arch Linux?
From the title and description this seems relevant: Microsoft Office 2016 - Supported software - PlayOnLinux - Run your Windows applications on Linux easily! if using the playonlinux gui. Are you using that @sica2602 ?
As for the iso, if you have a Microsoft account there is a download available on the support site, search for offline installation. Looking elsewhere would most likely result in a less secure option in the form of a compromised installation, a miner, ransomware etc.
