Hi, I want to install manjaro, but when I boot with the open source driver, it gives an out-of-range error, and when I boot with the property driver, after a few minutes, it reaches the Reached target graphical interface line … and nothing happens, how can I manjaro Install it ?!
What is the graphics card?
Did you try to “Boot with proprietary drivers”?
it is GT218
yes i try but its not work
Try an older version of @Jim.B 's Gnome spins.
P.S. Not too old though as otherwise you have to update a lot!
I’d start with the second-to-last one of the 21-series.
i try but get same result
Please be more specific: Which ones did you try?
If all of them:
We’re sorry to say your system is incompatible with Manjaro
