I try to install Manjaro KDE
But at the start the installation program appears after“Waiting for 1 module”error
Try
Success
In Hyper-V(the second generation,direct mount the iso)to install The above error
Replace the SATA to AHCI
Change Tsinghua source
Using the USB phone to share the network
Useing ventoy
Using rufus
Using xfce
Version:Manjaro KDE 21.3.7(verified Hash,Tsinghua source download)
Network:you can normal access about them on the Internet Baidu and other websites
Configuration:
i5 7400
8GB DDR4 single root
WD Blue 1Tb
Colorful SL300 120GB
GTX1050
Boot with Proprietary drivers for that GPU, or are you trying to install on Virtual Machine? Seems the installer to have stopped right before language selection, and from your report is not clear why …
[manjaro@manjaro ~]$ sudo -E calamares
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1000
Calamares is already running, shutting down.
Other running Calamares instances:
true 5230 ("/usr/bin/calamares", "-D6")
true 6604 ("calamares")
