Hi!
I’m trying to change OS to Manjaro from Fedora. I have already created some partition and 3 RAID 0.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 129M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 785M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.7G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 643.7M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part
sdb 8:16 1 57.6G 0 disk /run/miso/bootmnt
├─sdb1 8:17 1 3.3G 0 part
└─sdb2 8:18 1 4M 0 part
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:2 0 2G 0 part
├─nvme0n1p2 259:3 0 5G 0 part
│ └─md125 9:125 0 10G 0 raid0
├─nvme0n1p3 259:4 0 75G 0 part
│ └─md126 9:126 0 149.9G 0 raid0 /mnt
└─nvme0n1p4 259:5 0 394.9G 0 part
└─md127 9:127 0 789.6G 0 raid0
nvme1n1 259:1 0 476.9G 0 disk
├─nvme1n1p1 259:6 0 5G 0 part
├─nvme1n1p2 259:7 0 75G 0 part
└─nvme1n1p3 259:8 0 394.9G 0 part
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /run/miso/sfs/livefs
loop1
squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2
squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3
squash 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1
ext4 1.0 heavy_files
3b9a3503-2fab-416d-b096-36dd88301e84
sdb iso966 Jolie MANJARO_GNOME_2136
2022-07-29-12-53-38-00 0 100% /run/miso/bootmnt
├─sdb1
│ iso966 Jolie MANJARO_GNOME_2136
│ 2022-07-29-12-53-38-00
└─sdb2
vfat FAT12 MISO_EFI
0511-7795
nvme0n1
├─nvme0n1p1
│ vfat FAT32 CBE5-37B9
├─nvme0n1p2
│ linux_ 1.2 localhost-live:swap
│ 93b54b8c-1f34-bc9d-dfc5-bddf861f6025
│ └─md125
│ swap 1 swap a9c9c542-41d1-45f0-85a0-16528b91d814
├─nvme0n1p3
│ linux_ 1.2 localhost-live:root
│ 9db0b579-ea89-f115-00e9-4587a55b1a62
│ └─md126
│ ext4 1.0 root 8891a3a4-6f4b-4df2-bc0d-7cd9aa837426 129.3G 7% /mnt
└─nvme0n1p4
linux_ 1.2 localhost-live:home
750ec43e-7aae-e82e-34fc-13ff0cac321e
└─md127
ext4 1.0 home a8835ad0-504f-4167-9c1c-edee36b701cc
nvme1n1
├─nvme1n1p1
│ └─md125
├─nvme1n1p2
│ └─md126
└─nvme1n1p3
└─md127
I have already install Manjaro on nvme1n1p2/md126 raid partition.
I want to install grub /boot/EFI on different drive.
Space prepared to install grub is nvme0n1/nvme0n1p1. How can i do that?
Important thing: I must use live USB.
I was trying:
sudo manjaro-chroot -a (pick system)
mount at /mnt
and then:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro /dev/nvme0n1p1 --recheck --verbose
Below info:
[manjaro-gnome boot]# grub-install --target=x86_64-efi --efi-directory=/boot/efi
--bootloader-id=manjaro /dev/nvme0n1/nvme0n1p1 --recheck --verbose
Installing for x86_64-efi platform.
grub-install: info: cannot open `/boot/grub/device.map': No such file or directory.
grub-install: info: /dev/md126 is not present.
grub-install: info: changing current directory to /dev.
grub-install: info: changing current directory to dri.
grub-install: info: changing current directory to by-path.
grub-install: info: changing current directory to md.
grub-install: info: changing current directory to vfio.
grub-install: info: changing current directory to mqueue.
grub-install: info: changing current directory to hugepages.
grub-install: info: changing current directory to pts.
grub-install: info: changing current directory to shm.
grub-install: info: changing current directory to usb.
grub-install: info: changing current directory to bus.
grub-install: info: changing current directory to 004.
grub-install: info: changing current directory to 003.
grub-install: info: changing current directory to 002.
grub-install: info: changing current directory to 001.
grub-install: info: changing current directory to block.
grub-install: info: changing current directory to disk.
grub-install: info: changing current directory to by-label.
grub-install: info: changing current directory to by-partlabel.
grub-install: info: changing current directory to by-uuid.
grub-install: info: changing current directory to by-partuuid.
grub-install: info: changing current directory to by-id.
grub-install: info: changing current directory to by-diskseq.
grub-install: info: changing current directory to char.
grub-install: info: changing current directory to snd.
grub-install: info: changing current directory to mapper.
grub-install: info: changing current directory to net.
grub-install: info: changing current directory to bsg.
grub-install: info: changing current directory to input.
grub-install: info: /dev/nvme0n1p3 is not present.
grub-install: info: Looking for /dev/nvme0n1p3.
grub-install: info: /dev/nvme0n1 is a parent of /dev/nvme0n1p3.
grub-install: info: /dev/nvme0n1p3 starts from 14682112.
grub-install: info: opening the device hostdisk//dev/nvme0n1.
grub-install: info: drive = 0.
grub-install: info: the size of hostdisk//dev/nvme0n1 is 1000215216.
grub-install: info: Scanning for DISKFILTER devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid1x devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid09_be devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid09 devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for dmraid_nv devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for ldm devices on disk hostdisk//dev/nvme0n1.
grub-install: info: scanning hostdisk//dev/nvme0n1 for LDM.
grub-install: info: no LDM signature found.
grub-install: info: Scanning for lvm devices on disk hostdisk//dev/nvme0n1.
grub-install: info: no LVM signature found.
grub-install: info: Found array md/swap.
grub-install: info: Inserting hostdisk//dev/nvme0n1 (+4196352,10485760) into md/swap (mdraid1x)
grub-install: info: Found array md/root.
grub-install: info: Inserting hostdisk//dev/nvme0n1 (+14682112,157286400) into md/root (mdraid1x)
grub-install: info: Found array md/home.
grub-install: info: Inserting hostdisk//dev/nvme0n1 (+171968512,828246016) into md/home (mdraid1x)
grub-install: info: Partition 0 starts from 2048.
grub-install: info: Partition 1 starts from 4196352.
grub-install: info: Partition 2 starts from 14682112.
grub-install: info: /dev/nvme1n1p2 is not present.
grub-install: info: Looking for /dev/nvme1n1p2.
grub-install: info: /dev/nvme1n1 is a parent of /dev/nvme1n1p2.
grub-install: info: /dev/nvme1n1p2 starts from 10487808.
grub-install: info: opening the device hostdisk//dev/nvme1n1.
grub-install: info: drive = 1.
grub-install: info: the size of hostdisk//dev/nvme1n1 is 1000215216.
grub-install: info: Scanning for DISKFILTER devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Scanning for mdraid1x devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Scanning for mdraid09_be devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Scanning for mdraid09 devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Scanning for dmraid_nv devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Scanning for ldm devices on disk hostdisk//dev/nvme1n1.
grub-install: info: scanning hostdisk//dev/nvme1n1 for LDM.
grub-install: info: Scanning for lvm devices on disk hostdisk//dev/nvme1n1.
grub-install: info: Inserting hostdisk//dev/nvme1n1 (+2048,10485760) into md/swap (mdraid1x)
grub-install: info: Inserting hostdisk//dev/nvme1n1 (+10487808,157286400) into md/root (mdraid1x)
grub-install: info: Inserting hostdisk//dev/nvme1n1 (+167774208,828246016) into md/home (mdraid1x)
grub-install: info: Partition 1 starts from 10487808.
grub-install: info: /dev/nvme0n1p3 is present.
grub-install: info: /dev/nvme1n1p2 is present.
grub-install: error: /boot/efi doesn't look like an EFI partition.
[manjaro-gnome boot]# ls
efi intel-ucode.img
grub linux515-x86_64.kver
initramfs-5.15-x86_64-fallback.img memtest86+
initramfs-5.15-x86_64.img vmlinuz-5.15-x86_64
I was tryind too:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro /dev/nvme0n1 --recheck --verbose
Result:
[manjaro-gnome mnt]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro /dev/nvme0n1 --recheck --verbose
Sadly Manjaro installer doesn’t support this type of solution.
Definitely i need support from more experienced users.
Best Regards.
Update:
After mount /dev/nvme0n1p1 to /boot/efi
cd /mnt → where is mount Manjaro
Run grub-install
and looks like grub is installed. I have check this in UEFI and i can pick runner.
But! Still i have some problems.
First:
After run i’m getting error:
error diskfilter writes are not supported
and after click something:
Error: device `<device_id>` not found. Skipping fsck.
mount: /new_root: can't find <device_id>
You are now being dropped into an emergency shell.
I found two solve of this: error diskfilter writes are not supported
But it looks like grub still doesn’t working.
