Hi, I have tried to install this item both from terminal and add/remove software. I am not a experience user so I need help please. This is the error message I get:
==> Starting build()…
/var/cache/private/pamac/mbpfan-git/PKGBUILD: line 33: make: command not found
==> ERROR: A failure occurred in build().
Aborting…
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 2.193s
CPU time consumed: 1.663s
pamac install base-devel
Thank you very much for the fast answer. I worked perfect.
Why not add this to iso’s we are getting this question every day.
