Good day to all.
I am having issues attempting to Install Manjaro 24.2.1. I am using a bootable USB to attempt the install. I am able to follow all the steps via the install selecting Erase disk. (Note I am creating a swap drive with hibernation selected and using ext4)
I have installed previously Mint and Elementary without any problems Here are the logs for the install. Please help and thank you for any assistance.
25-02-10 - 10:38:45 [6]: There are 36 jobs, total weight 33
2025-02-10 - 10:38:45 [6]: .. Job 1 "Managing auto-mount settings…" +wt 0.1 tot.wt 0.1
2025-02-10 - 10:38:45 [6]: .. Job 2 "Clearing all temporary mounts…" +wt 0.1 tot.wt 0.2
2025-02-10 - 10:38:45 [6]: .. Job 3 "Clear mounts for partitioning operations on /dev/data" +wt 0.1 tot.wt 0.3
2025-02-10 - 10:38:45 [6]: .. Job 4 "Creating new gpt partition table on /dev/data…" +wt 0.1 tot.wt 0.4
2025-02-10 - 10:38:45 [6]: .. Job 5 "Create new 300MiB partition on /dev/data (data)" +wt 0.1 tot.wt 0.5
2025-02-10 - 10:38:45 [6]: .. Job 6 "Set flags on 300MiB fat32 partition" +wt 0.1 tot.wt 0.6
2025-02-10 - 10:38:45 [6]: .. Job 7 "Create new 1897880MiB partition on /dev/data (data) with entries root" +wt 0.1 tot.wt 0.7
2025-02-10 - 10:38:45 [6]: .. Job 8 "Create new 9012MiB partition on /dev/data (data)" +wt 0.1 tot.wt 0.8
2025-02-10 - 10:38:45 [6]: .. Job 9 "Set partition information" +wt 0.1 tot.wt 0.9
2025-02-10 - 10:38:45 [6]: .. Job 10 "Managing auto-mount settings…" +wt 0.1 tot.wt 1
2025-02-10 - 10:38:45 [6]: .. Job 11 "mount" +wt 1 tot.wt 2
2025-02-10 - 10:38:45 [6]: .. Job 12 "unpackfs" +wt 12 tot.wt 14
2025-02-10 - 10:38:45 [6]: .. Job 13 "networkcfg" +wt 1 tot.wt 15
2025-02-10 - 10:38:45 [6]: .. Job 14 "Generate machine-id." +wt 1 tot.wt 16
2025-02-10 - 10:38:45 [6]: .. Job 15 "Setting timezone to America/Toronto…" +wt 1 tot.wt 17
2025-02-10 - 10:38:45 [6]: .. Job 16 "Setting keyboard model to pc105, layout as us-…" +wt 1 tot.wt 18
2025-02-10 - 10:38:45 [6]: .. Job 17 "localecfg" +wt 1 tot.wt 19
2025-02-10 - 10:38:45 [6]: .. Job 18 "Configuring LUKS key file." +wt 1 tot.wt 20
2025-02-10 - 10:38:45 [6]: .. Job 19 "Configuring encrypted swap." +wt 1 tot.wt 21
2025-02-10 - 10:38:45 [6]: .. Job 20 "fstab" +wt 1 tot.wt 22
2025-02-10 - 10:38:45 [6]: .. Job 21 "initcpiocfg" +wt 1 tot.wt 23
2025-02-10 - 10:38:45 [6]: .. Job 22 "Creating initramfs with mkinitcpio…" +wt 1 tot.wt 24
2025-02-10 - 10:38:45 [6]: .. Job 23 "Configuring <pre>sudo</pre> users…" +wt 0.166667 tot.wt 24.1667
2025-02-10 - 10:38:45 [6]: .. Job 24 "Preparing groups…" +wt 0.166667 tot.wt 24.3333
2025-02-10 - 10:38:45 [6]: .. Job 25 "Create user yonathan" +wt 0.166667 tot.wt 24.5
2025-02-10 - 10:38:45 [6]: .. Job 26 "Set password for user yonathan" +wt 0.166667 tot.wt 24.6667
2025-02-10 - 10:38:45 [6]: .. Job 27 "Set password for user root" +wt 0.166667 tot.wt 24.8333
2025-02-10 - 10:38:45 [6]: .. Job 28 "Set hostname Zeev_Arch" +wt 0.166667 tot.wt 25
2025-02-10 - 10:38:45 [6]: .. Job 29 "displaymanager" +wt 1 tot.wt 26
2025-02-10 - 10:38:45 [6]: .. Job 30 "mhwdcfg" +wt 1 tot.wt 27
2025-02-10 - 10:38:45 [6]: .. Job 31 "hwclock" +wt 1 tot.wt 28
2025-02-10 - 10:38:45 [6]: .. Job 32 "services" +wt 1 tot.wt 29
2025-02-10 - 10:38:45 [6]: .. Job 33 "grubcfg" +wt 1 tot.wt 30
2025-02-10 - 10:38:45 [6]: .. Job 34 "bootloader" +wt 1 tot.wt 31
2025-02-10 - 10:38:45 [6]: .. Job 35 "postcfg" +wt 1 tot.wt 32
2025-02-10 - 10:38:45 [6]: .. Job 36 "Unmounting file systems…" +wt 1 tot.wt 33
2025-02-10 - 10:38:45 [6]: virtual void Calamares::JobThread::run()
2025-02-10 - 10:38:45 [6]: Starting job "Managing auto-mount settings…" ( 1 / 36 )
2025-02-10 - 10:38:45 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
2025-02-10 - 10:38:45 [6]: Set automount to disable
2025-02-10 - 10:38:45 [6]: void Calamares::Partition::querySolidAutoMount(QDBusConnection&, AutoMountInfo&)
2025-02-10 - 10:38:45 [6]: Solid not available: "Not connected to D-Bus server"
2025-02-10 - 10:38:45 [6]: Starting job "Clearing all temporary mounts…" ( 2 / 36 )
2025-02-10 - 10:38:45 [6]: Starting job "Clear mounts for partitioning operations on /dev/data" ( 3 / 36 )
2025-02-10 - 10:38:45 [6]: QStringList getPartitionsForDevice(const QString&)
2025-02-10 - 10:38:45 [6]: Reading from "/proc/partitions" looking for "data"
2025-02-10 - 10:38:45 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
2025-02-10 - 10:38:45 [6]: ClearMountsJob finished. Here's what was done:
"Successfully closed mapper device /dev/mapper/data-swap."
2025-02-10 - 10:38:45 [6]: .. Running QList("udevadm", "settle")
2025-02-10 - 10:38:46 [6]: .. Running QList("sync")
2025-02-10 - 10:38:46 [6]: virtual void Calamares::JobThread::run()
2025-02-10 - 10:38:46 [6]: Starting job "Creating new gpt partition table on /dev/data…" ( 4 / 36 )
2025-02-10 - 10:38:46 [6]: virtual Calamares::JobResult CreatePartitionTableJob::exec()
2025-02-10 - 10:38:46 [6]: Creating new partition table of type "gpt" , uncommitted partitions:
2025-02-10 - 10:38:46 [6]: .. "New Partition"
2025-02-10 - 10:38:46 [6]: .. "unallocated"
2025-02-10 - 10:38:46 [6]: .. Running QList("lsblk")
2025-02-10 - 10:38:46 [6]: .. lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 90.1M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 1.1G 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.8G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 858.9M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 1.8T 0 disk
|-sda1 8:1 0 263.1M 0 part
`-sda2 8:2 0 1.8T 0 part
sdb 8:16 1 28.7G 0 disk /run/miso/bootmnt
|-sdb1 8:17 1 4G 0 part
`-sdb2 8:18 1 4M 0 part
sr0 11:0 1 4.2G 0 rom
2025-02-10 - 10:38:46 [6]: .. Running QList("mount")
2025-02-10 - 10:38:46 [6]: .. mount output:
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=3985800k,nr_inodes=996450,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/sdb on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8)
cowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)
overlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=6065804k,mode=755,inode64)
/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime,errors=continue,threads=single)
overlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,uuid=on,xino=off)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=38,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=430)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=1048576,inode64)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
tmpfs on /run/credentials/systemd-journald.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-udev-load-credentials.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/credentials/systemd-tmpfiles-setup-dev-early.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-sysctl.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-tmpfiles-setup-dev.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)
tmpfs on /run/credentials/systemd-vconsole-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-tmpfiles-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=808772k,nr_inodes=202193,mode=700,uid=1000,gid=1000,inode64)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
2025-02-10 - 10:38:46 [6]: Skipping non-emergency job "Create new 300MiB partition on /dev/data (data)"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Set flags on 300MiB fat32 partition"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Create new 1897880MiB partition on /dev/data (data) with entries root"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Create new 9012MiB partition on /dev/data (data)"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Set partition information"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Managing auto-mount settings…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "mount"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "unpackfs"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "networkcfg"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Generate machine-id."
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Setting timezone to America/Toronto…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Setting keyboard model to pc105, layout as us-…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "localecfg"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Configuring LUKS key file."
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Configuring encrypted swap."
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "fstab"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "initcpiocfg"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Creating initramfs with mkinitcpio…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Configuring <pre>sudo</pre> users…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Preparing groups…"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Create user yonathan"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Set password for user yonathan"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Set password for user root"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "Set hostname Zeev_Arch"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "displaymanager"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "mhwdcfg"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "hwclock"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "services"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "grubcfg"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "bootloader"
2025-02-10 - 10:38:46 [6]: .. Skipping non-emergency job "postcfg"
2025-02-10 - 10:38:46 [6]: .. Starting EMERGENCY JOB "Unmounting file systems…" ( 36 / 36 )
2025-02-10 - 10:38:46 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
2025-02-10 - 10:38:46 [1]: ERROR: Installation failed: "The installer failed to create a partition table on data."
2025-02-10 - 10:38:46 [6]: .. - message: "The installer failed to create a partition table on data."
2025-02-10 - 10:38:46 [6]: .. - details:
Create a new partition table (type: gpt) on ‘/dev/data’
Job: Create new partition table on device ‘/dev/data’
