I’m not sure what caused it but I was playing with GPU drivers earlier to the issue which may have caused the issue. After a while I then rebooted and booted to Windows (i have a dual boot) and when I tried to switch back, Manjaro is stuck on the boot screen (the 3 dot animation moves for the first minute then stops).
I tried following the steps at (can’t include links, stupid but it was a post detailing someone with a similar issue and asking to edit the boot flags) and by removing splash quiet
and adding 3
it booted to the terminal without issues.
I then try rebooting without splash and quiet. The terminal shows its loading components and then it goes to a back screen with a very fast blinking cursor.
Any advice? I’d rather not have to reinstall Manjaro and restore all my configurations. Thank you.
