Input method - current user's input method forced to change?
Not eager to paint.
But I’m not a fan of being forced what I can do, and what I cannot do.
This fcitx5 installation and following issues, clearly overstepped my boundary.
But its still just … poor performance of a package-manager/aur-helper.
Not a secret cabal out to force you to use fcitx5.
Or thats what I think anyways.
Without better knowledge of events - such as by reverting to a backup and performing the upgrade again, maybe comparing with pacman - it is impossible to be sure.
But the fcitx5-uminati just seems highly unlikely.
I hope you’re right.
Anyway, I have uninstalled fcitx5 and relevant dependencies.
My ibus is back and functional.
Let’s hope the next update, there won’t be another fcitx5 issue again.
Well, I am a Plasma user, but on Unstable and also only use pacman+paru … and despite having sdl2-compat, sdl3, etc, I have exactly zero entries for fcitx in my pacman log.
Never installed, never removed, nada.
So infer from that what you will.
I am a Plasma user, and I would like to inform you that not only fcitx5 but also ibus was forcibly introduced in this update. I’ve been a long-time fcitx5 user, so the fcitx5 issue didn’t affect me. However, ibus was also installed during the update. When I check the dependencies, it was not required by any other packages. I just uninstalled ibus after the update, but just don’t know why it was introduced at the first place, as it was not required.
So yeah, it’s definitely not because KDE Plasma decided to force the users to use fcitx5, but for some reason, both ibus and fcitx5 were forcibly added to the system.
Pamac with AUR enabled as well?
A (full?) update log would be the best way to begin figuring out the reason for the added package(s).
I’m an Plasma user. No version of fcitx has ever been on my system and the last mention of ibus in /var/log/pacman.log was it being removed nearly two years ago.
[2023-05-08T16:26:58+0100] [ALPM] removed libibus (1.5.28-3)
Likely the Pamac + AUR explanation is correct. I use pacman and manage the few AUR packages that I use manually.
The footgun that is Pamac + AUR has been discussed numerous times over the years. It’s pretty much guaranteed that eventually something will go wrong when packages get moved from the regular repo to AUR. But if you provide easily accessible footguns to your users then, no matter how many warnings you put on it, you shouldn’t be surprised when some of them turn up complaining about missing feet.
You might get a kick out of
(the whole thing … but especially after the conversation turns to pamac)
Haven’t performed the update yet. Thought I’d share the output of pamac with and without AUR for those who might be interested.
pamac update -a
To install (10):
sdl3
sdl2-compat
webrtc-audio-processing-0.3
libibus
rhash
ibus
cppdap
xcb-imdkit
fcitx5
cmake
pamac update --no-aur
To install (3):
sdl3
sdl2-compat
So definitely getting fcitx5 and ibus with AUR allowed.
But its still not sure the actual why.
There does not appear to be a clear reason for pulling either (or the handful of other extra packages).
Can you make sure to refresh before checking again?
Maybe a mirror sort too?
And clean first?
pamac clean -b -v
sudo pacman-mirrors -f && pamac upgrade --aur --force-refresh
Ran all the commands you requested. Here is the output after a “clean” with a force-refresh
Synchronizing package databases…
Refreshing core.db…
Refreshing extra.db…
Refreshing community.db…
Refreshing multilib.db…
Refreshing core.files…
Refreshing extra.files…
Refreshing community.files…
Refreshing multilib.files…
Refreshing AUR…
Checking sdl2 dependencies…
Resolving dependencies…
Checking inter-conflicts…
Warning: dependency cycle detected:
Warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
To install (10):
sdl3
sdl2-compat
libibus
rhash
ibus
cppdap
xcb-imdkit
fcitx5
cmake
To remove (2):
webrtc-audio-processing extra
sdl2
Not much difference though I do note 2 things … first
This is a deprecated repository and also likely means there are an unknown number of untended pacnews on the system.
With the inclusion of To remove we do have confirmation of the previously existing sdl2 … which may still be the reason for pamac thinking it needs those packages - to build sdl2(AUR) even though it is going to be removed.
Its not great and/or doesnt make a whole lot of sense but it seems like the most likely reason at the moment.
Actually … yeah … it says so right in the output - the first thing it does after refreshing is check sdl2 dependencies for some reason …
This is exactly the kind of ‘cant distinguish or properly prioritize between the repositories and the AUR and fumbles transactions’ that people would talk about.
And in this case its a far reaching impact - untold numbers of users have their input methods broken by an unnecessary addition of fcitx5 (and other packages) because pamac was confused.
Here’s the log on the date of update:
cat /var/log/pacman.log |grep 2025-02-17T         ✔  8s 
[2025-02-17T08:16:42+1000] [PAMAC] synchronizing package lists
[2025-02-17T15:16:41+1000] [PAMAC] synchronizing package lists
[2025-02-17T21:16:41+1000] [PAMAC] synchronizing package lists
[2025-02-17T23:02:57+1000] [PAMAC] synchronizing package lists
[2025-02-17T23:18:46+1000] [PAMAC] synchronizing package lists
[2025-02-17T23:24:20+1000] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-02-17T23:24:21+1000] [ALPM] running '71-dkms-remove.hook'...
[2025-02-17T23:24:21+1000] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod zfs/2.2.7 -k 6.12.11-1-MANJARO
[2025-02-17T23:24:22+1000] [ALPM-SCRIPTLET] ==> depmod 6.12.11-1-MANJARO
[2025-02-17T23:24:25+1000] [ALPM] transaction started
[2025-02-17T23:24:25+1000] [ALPM] removed sdl2 (2.30.11-1)
[2025-02-17T23:24:25+1000] [ALPM] upgraded glibc (2.40+r66+g7d4b6bcae91f-1 -> 2.41+r2+g0a7c7a3e283a-1)
[2025-02-17T23:24:25+1000] [ALPM-SCRIPTLET] Generating locales...
[2025-02-17T23:24:26+1000] [ALPM-SCRIPTLET]   en_AU.UTF-8... done
[2025-02-17T23:24:27+1000] [ALPM-SCRIPTLET]   en_US.UTF-8... done
[2025-02-17T23:24:27+1000] [ALPM-SCRIPTLET]   zh_TW.UTF-8... done
[2025-02-17T23:24:27+1000] [ALPM-SCRIPTLET] Generation complete.
[2025-02-17T23:24:28+1000] [ALPM] upgraded gcc-libs (14.2.1+r134+gab884fffe3fc-2 -> 14.2.1+r730+gc061ad5a36ba-1)
[2025-02-17T23:24:28+1000] [ALPM] upgraded abseil-cpp (20240722.0-1 -> 20240722.1-1)
[2025-02-17T23:24:28+1000] [ALPM] upgraded archlinux-appstream-data (20241214-1 -> 20250202-1)
[2025-02-17T23:24:28+1000] [ALPM] upgraded libpng (1.6.45-1 -> 1.6.46-1)
[2025-02-17T23:24:28+1000] [ALPM] upgraded libsysprof-capture (47.2-1 -> 47.2-2)
[2025-02-17T23:24:28+1000] [ALPM] upgraded freetype2 (2.13.3-1 -> 2.13.3-3)
[2025-02-17T23:24:29+1000] [ALPM] upgraded libx11 (1.8.10-1 -> 1.8.11-1)
[2025-02-17T23:24:29+1000] [ALPM] upgraded qt6-translations (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:29+1000] [ALPM] upgraded xz (5.6.3-1 -> 5.6.4-1)
[2025-02-17T23:24:29+1000] [ALPM] upgraded ca-certificates-mozilla (3.107-1 -> 3.108-1)
[2025-02-17T23:24:29+1000] [ALPM] upgraded curl (8.11.1-3 -> 8.12.1-0)
[2025-02-17T23:24:29+1000] [ALPM] upgraded libelf (0.192-2 -> 0.192-3)
[2025-02-17T23:24:29+1000] [ALPM] upgraded hwdata (0.391-1 -> 0.392-1)
[2025-02-17T23:24:29+1000] [ALPM] upgraded qt6-base (6.8.1-1 -> 6.8.2-1.1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qt6-declarative (6.8.1-3 -> 6.8.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qt6-svg (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qt6-wayland (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:30+1000] [ALPM] installed sdl3 (3.2.2-1)
[2025-02-17T23:24:30+1000] [ALPM] installed sdl2-compat (2.30.52-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded libvorbis (1.3.7-3 -> 1.3.7-4)
[2025-02-17T23:24:30+1000] [ALPM] upgraded liblc3 (1.1.1-1 -> 1.1.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded webrtc-audio-processing-1 (1.3-3 -> 1.3-4)
[2025-02-17T23:24:30+1000] [ALPM] upgraded nss (3.107-1 -> 3.108-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded libtool (2.5.4+r1+gbaa1fe41-1 -> 2.5.4+r1+gbaa1fe41-2)
[2025-02-17T23:24:30+1000] [ALPM] upgraded mpfr (4.2.1-4 -> 4.2.1-5)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qt6-shadertools (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qt6-5compat (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded qca-qt6 (2.3.9-3 -> 2.3.9-4)
[2025-02-17T23:24:30+1000] [ALPM] upgraded ark (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-common (0.10.8-1 -> 0.11.0-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-cal (0.8.1-1 -> 0.8.3-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-compression (0.3.0-1 -> 0.3.1-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-io (0.15.3-1 -> 0.15.4-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-http (0.9.2-1 -> 0.9.3-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-sdkutils (0.2.2-1 -> 0.2.3-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-auth (0.8.1-1 -> 0.8.4-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-checksums (0.2.2-1 -> 0.2.3-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-event-stream (0.5.0-1 -> 0.5.1-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-mqtt (0.11.0-1 -> 0.12.1-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-c-s3 (0.7.9-1 -> 0.7.11-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-crt-cpp (0.29.9-1 -> 0.30.1-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-sdk-cpp-core (1.11.492-1 -> 1.11.497-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-sdk-cpp-iam (1.11.492-1 -> 1.11.497-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded aws-sdk-cpp-s3 (1.11.492-1 -> 1.11.497-1)
[2025-02-17T23:24:30+1000] [ALPM] upgraded b43-fwcutter (019-5 -> 019-6)
[2025-02-17T23:24:30+1000] [ALPM] upgraded baloo-widgets (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:31+1000] [ALPM] upgraded bind (9.20.4-2 -> 9.20.5-1)
[2025-02-17T23:24:31+1000] [ALPM] upgraded binutils (2.43_1+r171+g01da089627be-1 -> 2.43_1+r186+g61f8adadd6db-1)
[2025-02-17T23:24:31+1000] [ALPM] upgraded botan (3.6.1-2 -> 3.7.1-1)
[2025-02-17T23:24:38+1000] [ALPM] upgraded cuda (12.6.3-1 -> 12.8.0-1)
[2025-02-17T23:24:39+1000] [ALPM-SCRIPTLET] - When you uninstall an old, unrequired version of GCC that was previously
[2025-02-17T23:24:39+1000] [ALPM-SCRIPTLET]   required by cuda for the default host compiler ($NVCC_CCBIN), you may need
[2025-02-17T23:24:39+1000] [ALPM-SCRIPTLET]   to source /etc/profile or restart your session.  Additionally, you may need
[2025-02-17T23:24:39+1000] [ALPM-SCRIPTLET]   to clear the build cache of your projects where the old path may be still
[2025-02-17T23:24:39+1000] [ALPM-SCRIPTLET]   recorded.
[2025-02-17T23:24:39+1000] [ALPM] upgraded dhcpcd (10.1.0-1 -> 10.1.0-2)
[2025-02-17T23:24:39+1000] [ALPM] upgraded gcc (14.2.1+r134+gab884fffe3fc-2 -> 14.2.1+r730+gc061ad5a36ba-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded dkms (3.1.4-1 -> 3.1.5-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded libkexiv2 (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded qt6-multimedia-ffmpeg (6.8.1-2 -> 6.8.2-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded qt6-multimedia (6.8.1-2 -> 6.8.2-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded qt6-speech (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:39+1000] [ALPM] upgraded kio-extras (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded dolphin (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded dolphin-plugins (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded gtk3 (1:3.24.43-4 -> 1:3.24.43-4.1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded drawio-desktop (26.0.4-1 -> 26.0.9-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fakeroot (1.36.2-1 -> 1.37-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fcitx5 (5.1.11-2 -> 5.1.12-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fcitx5-qt (5.1.8-5 -> 5.1.9-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fcitx5-rime (5.1.9-1 -> 5.1.10-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded ffmpegthumbs (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded filelight (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fluidsynth (2.4.2-1 -> 2.4.3-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fmt (11.1.2-1 -> 11.1.3-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded freerdp (2:3.10.3-1 -> 2:3.11.0-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded passim (0.1.8-1 -> 0.1.9-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded fwupd (2.0.4-1 -> 2.0.5-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded gcc-fortran (14.2.1+r134+gab884fffe3fc-2 -> 14.2.1+r730+gc061ad5a36ba-1)
[2025-02-17T23:24:40+1000] [ALPM] upgraded xerces-c (3.2.5-2 -> 3.3.0-1)
[2025-02-17T23:24:41+1000] [ALPM] upgraded gdal (3.10.0-6 -> 3.10.1-1)
[2025-02-17T23:24:41+1000] [ALPM] upgraded luajit (2.1.1731601260-1 -> 2.1.1736781742-1)
[2025-02-17T23:24:41+1000] [ALPM] upgraded gegl (0.4.52-1 -> 0.4.52-2)
[2025-02-17T23:24:41+1000] [ALPM] upgraded glibc-locales (2.40+r66+g7d4b6bcae91f-1 -> 2.41+r2+g0a7c7a3e283a-1)
[2025-02-17T23:24:41+1000] [ALPM] upgraded graphviz (12.1.2-2 -> 12.2.1-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gstreamer (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-base-libs (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-libav (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-bad-libs (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded zvbi (0.2.42-1 -> 0.2.43-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-bad (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-base (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded wavpack (5.7.0-1 -> 5.8.1-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded procps-ng (4.0.5-1 -> 4.0.5-2)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-good (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gst-plugins-ugly (1.24.11-2 -> 1.24.12-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded gtk-vnc (1.4.0-1 -> 1.4.0-2)
[2025-02-17T23:24:42+1000] [ALPM] upgraded libkdcraw (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded signon-kwallet-extension (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded qt6-positioning (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded qt6-webchannel (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:42+1000] [ALPM] upgraded noto-fonts (1:2025.01.01-1 -> 1:2025.02.01-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded qt6-webengine (6.8.1-2 -> 6.8.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded kaccounts-integration (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded gwenview (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-ptyprocess (0.7.0-7 -> 0.7.0-8)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-pexpect (4.9.0-3 -> 4.9.0-4)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-prompt_toolkit (3.0.48-2 -> 3.0.50-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-executing (2.1.0-2 -> 2.2.0-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded ipython (8.31.0-1 -> 8.32.0-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-mistune (1:3.1.0-1 -> 1:3.1.1-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded jupyter-nbconvert (7.16.5-1 -> 7.16.6-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-jupyter-events (0.11.0-3 -> 0.12.0-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded python-certifi (2024.12.14-1 -> 2025.01.31-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded jupyterlab (4.3.4-3 -> 4.3.5-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded kaccounts-providers (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded kamera (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded kate (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded kcalc (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:43+1000] [ALPM] upgraded qt6-connectivity (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdeconnect (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdegraphics-mobipocket (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdegraphics-thumbnailers (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded liburing (2.8-1 -> 2.9-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdenetwork-filesharing (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded qt6-networkauth (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdenlive (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kdialog (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded keditbookmarks (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kfind (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kget (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded khelpcenter (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded konsole (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded qt6-tools (6.8.1-2 -> 6.8.2-2)
[2025-02-17T23:24:44+1000] [ALPM] upgraded konversation (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kpmcore (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded ksanecore (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded ksystemlog (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kwalletmanager (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded kwave (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded qt6-sensors (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:44+1000] [ALPM] upgraded layer-shell-qt (6.2.5-1 -> 6.2.5-3)
[2025-02-17T23:24:45+1000] [ALPM] upgraded kwin (6.2.5-1 -> 6.2.5-3)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-glibc (2.40+r66+g7d4b6bcae91f-1 -> 2.41+r2+g0a7c7a3e283a-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-gcc-libs (14.2.1+r134+gab884fffe3fc-2 -> 14.2.1+r730+gc061ad5a36ba-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-curl (8.11.1-3 -> 8.12.1-0)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-libpng (1.6.45-1 -> 1.6.46-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-freetype2 (2.13.3-2 -> 2.13.3-3)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-libx11 (1.8.10-1 -> 1.8.11-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-xz (5.6.3-1 -> 5.6.4-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-gtk3 (1:3.24.43-4 -> 1:3.24.43-4.1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-libvorbis (1.3.7-2 -> 1.3.7-4)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-sqlite (3.47.2-1 -> 3.48.0-2)
[2025-02-17T23:24:45+1000] [ALPM] upgraded lib32-nss (3.107-1 -> 3.108-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libadwaita (1:1.6.3-1 -> 1:1.6.4-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libcurl-gnutls (8.11.1-3 -> 8.12.1-0)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libetonyek (0.1.12-1 -> 0.1.12-2)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libksane (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libktorrent (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libpamac (11.7.2-2 -> 11.7.2-2.1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libslirp (4.8.0-1 -> 4.9.0-1)
[2025-02-17T23:24:45+1000] [ALPM] upgraded libwps (0.4.14-2 -> 0.4.14-3)
[2025-02-17T23:24:46+1000] [ALPM] upgraded linux612 (6.12.11-1 -> 6.12.12-2)
[2025-02-17T23:24:46+1000] [ALPM] upgraded pahole (1:1.28-3 -> 1:1.29-1)
[2025-02-17T23:24:49+1000] [ALPM] upgraded linux612-headers (6.12.11-1 -> 6.12.12-2)
[2025-02-17T23:24:49+1000] [ALPM] upgraded linux612-nvidia (550.144.03-3 -> 550.144.03-4)
[2025-02-17T23:24:49+1000] [ALPM] upgraded memtest86-efi (1:11.1build1000-1 -> 1:11.2build1000-1)
[2025-02-17T23:24:49+1000] [ALPM] upgraded mhwd-nvidia-470xx (470.256.02-9 -> 470.256.02-10)
[2025-02-17T23:24:49+1000] [ALPM] upgraded mhwd-nvidia-390xx (390.157-18 -> 390.157-19)
[2025-02-17T23:24:49+1000] [ALPM] upgraded nodejs (23.4.0-1 -> 23.7.0-1)
[2025-02-17T23:24:50+1000] [ALPM] upgraded noto-fonts-cjk (20230817-2 -> 20240730-1)
[2025-02-17T23:24:51+1000] [ALPM] upgraded noto-fonts-extra (1:2025.01.01-1 -> 1:2025.02.01-1)
[2025-02-17T23:24:51+1000] [ALPM] upgraded npm (11.0.0-1 -> 11.1.0-2)
[2025-02-17T23:24:51+1000] [ALPM] upgraded okular (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded opencv-cuda (4.11.0-1 -> 4.11.0-2)
[2025-02-17T23:24:52+1000] [ALPM] upgraded pacman-contrib (1.10.6-2 -> 1.11.0-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded parallel (20241222-1 -> 20250122-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded partitionmanager (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded perl-dbi (1.646-1 -> 1.647-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded perl-image-exiftool (13.15-1 -> 13.18-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded postgresql-libs (17.2-1 -> 17.2-2)
[2025-02-17T23:24:52+1000] [ALPM] upgraded shiboken6 (6.8.1.1-3 -> 6.8.2.1-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded pyside6 (6.8.1.1-3 -> 6.8.2.1-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded python-yarl (1.9.4-4 -> 1.13.1-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded python-aiohttp (3.10.5-2 -> 3.10.11-1)
[2025-02-17T23:24:52+1000] [ALPM] upgraded python-awkward (2.7.3-1 -> 2.7.4-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-black (24.10.0-3 -> 25.1.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-filelock (3.16.1-2 -> 3.17.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-cachecontrol (1:0.14.1-2 -> 1:0.14.2-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-fonttools (4.55.6-1 -> 4.55.8-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-gdal (3.10.0-6 -> 3.10.1-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-hypothesis (6.123.13-1 -> 6.124.7-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-llvmlite (0.44.0rc1-1 -> 0.44.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-mpi4py (4.0.1-1 -> 4.0.2-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-numba (0.61.0rc1-2 -> 0.61.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-opencv (4.11.0-1 -> 4.11.0-2)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-pillow (11.0.0-3 -> 11.1.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-pip (24.3.1-3 -> 25.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-pydantic-core (1:2.27.2-1 -> 2:2.27.2-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-pylint (3.3.3-1 -> 3.3.4-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded python-pyqt5-sip (12.16.1-2 -> 12.17.0-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded qca-qt5 (2.3.9-3 -> 2.3.9-4)
[2025-02-17T23:24:53+1000] [ALPM] upgraded qt5-tools (5.15.16+kde+r3-4 -> 5.15.16+kde+r3-6)
[2025-02-17T23:24:53+1000] [ALPM] upgraded qt6-imageformats (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:53+1000] [ALPM] upgraded qt6-quicktimeline (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded qt6-quick3d (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded qt6-serialport (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded qt6-virtualkeyboard (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded qt6-websockets (6.8.1-1 -> 6.8.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded rsync (3.4.1-1 -> 3.4.1-2)
[2025-02-17T23:24:54+1000] [ALPM] upgraded ruby-rexml (3.3.9-1 -> 3.4.0-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded skanlite (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded spectacle (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded spirv-llvm-translator (19.1.3-1 -> 19.1.4-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded telegram-desktop (5.10.5-1 -> 5.10.7-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded usbredir (0.14.0-1 -> 0.15.0-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded vim-runtime (9.1.1043-1 -> 9.1.1065-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded vim (9.1.1043-1 -> 9.1.1065-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded wpa_supplicant (2:2.11-2 -> 2:2.11-3)
[2025-02-17T23:24:54+1000] [ALPM] upgraded xorg-xwayland (24.1.4-1 -> 24.1.5-1)
[2025-02-17T23:24:54+1000] [ALPM] upgraded yakuake (24.12.1-1 -> 24.12.2-1)
[2025-02-17T23:24:55+1000] [ALPM] upgraded zenity (4.0.3-1 -> 4.0.5-1)
[2025-02-17T23:24:55+1000] [ALPM] installed libibus (1.5.31-2)
[2025-02-17T23:24:55+1000] [ALPM] installed wayland-protocols (1.39-1)
[2025-02-17T23:24:55+1000] [ALPM] installed ibus (1.5.31-2)
[2025-02-17T23:24:55+1000] [ALPM] transaction completed
[2025-02-17T23:24:57+1000] [ALPM] running '20-systemd-sysusers.hook'...
[2025-02-17T23:24:57+1000] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2025-02-17T23:24:57+1000] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2025-02-17T23:24:58+1000] [ALPM] running '30-systemd-restart-marked.hook'...
[2025-02-17T23:24:58+1000] [ALPM] running '30-systemd-tmpfiles.hook'...
[2025-02-17T23:24:58+1000] [ALPM] running '30-systemd-update.hook'...
[2025-02-17T23:24:58+1000] [ALPM] running '30-update-mime-database.hook'...
[2025-02-17T23:24:58+1000] [ALPM] running '40-update-ca-trust.hook'...
[2025-02-17T23:24:59+1000] [ALPM] running '60-depmod.hook'...
[2025-02-17T23:25:00+1000] [ALPM] running '70-dkms-install.hook'...
[2025-02-17T23:25:01+1000] [ALPM-SCRIPTLET] ==> dkms install --no-depmod zfs/2.2.7 -k 6.12.12-2-MANJARO
[2025-02-17T23:25:49+1000] [ALPM-SCRIPTLET] ==> depmod 6.12.12-2-MANJARO
[2025-02-17T23:25:52+1000] [ALPM] running '80-cronie.hook'...
[2025-02-17T23:25:52+1000] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET] ==> Starting build: '6.12.12-2-MANJARO'
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2025-02-17T23:25:53+1000] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2025-02-17T23:25:55+1000] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET]   -> Running build hook: [mdadm_udev]
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET] Custom /etc/mdadm.conf file will be used in initramfs for assembling arrays.
[2025-02-17T23:25:56+1000] [ALPM-SCRIPTLET]   -> Running build hook: [zfs]
[2025-02-17T23:25:57+1000] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2025-02-17T23:25:57+1000] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2025-02-17T23:25:57+1000] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2025-02-17T23:25:58+1000] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-02-17T23:25:59+1000] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET] ==> Starting build: '6.12.12-2-MANJARO'
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2025-02-17T23:26:00+1000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-02-17T23:26:05+1000] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-02-17T23:26:06+1000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-02-17T23:26:08+1000] [ALPM-SCRIPTLET]   -> Running build hook: [mdadm_udev]
[2025-02-17T23:26:08+1000] [ALPM-SCRIPTLET] Custom /etc/mdadm.conf file will be used in initramfs for assembling arrays.
[2025-02-17T23:26:08+1000] [ALPM-SCRIPTLET]   -> Running build hook: [zfs]
[2025-02-17T23:26:08+1000] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2025-02-17T23:26:09+1000] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2025-02-17T23:26:09+1000] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2025-02-17T23:26:10+1000] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2025-02-17T23:26:11+1000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-02-17T23:26:12+1000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
[2025-02-17T23:26:12+1000] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2025-02-17T23:26:13+1000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-02-17T23:26:13+1000] [ALPM] running '90-nvidia-utils.hook'...
[2025-02-17T23:26:13+1000] [ALPM] running '90-update-appstream-cache.hook'...
[2025-02-17T23:26:14+1000] [ALPM-SCRIPTLET] ✔ Metadata cache was updated successfully.
[2025-02-17T23:26:14+1000] [ALPM] running '99-update-grub.hook'...
[2025-02-17T23:26:14+1000] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2025-02-17T23:26:14+1000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.12-x86_64
[2025-02-17T23:26:14+1000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2025-02-17T23:26:15+1000] [ALPM-SCRIPTLET] done
[2025-02-17T23:26:15+1000] [ALPM] running 'dbus-reload.hook'...
[2025-02-17T23:26:15+1000] [ALPM] running 'dconf-update.hook'...
[2025-02-17T23:26:15+1000] [ALPM] running 'detect-old-perl-modules.hook'...
[2025-02-17T23:26:15+1000] [ALPM] running 'fontconfig.hook'...
[2025-02-17T23:26:15+1000] [ALPM] running 'fontconfig-32.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'glib-compile-schemas.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'gtk4-querymodules.hook'...
[2025-02-17T23:26:16+1000] [ALPM] running 'memtest86-efi-update.hook'...
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] MemTest86 is installed into /boot/EFI/memtest86/ directory.
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] '/usr/share/memtest86-efi/blacklist.cfg' -> '/boot/EFI/memtest86/blacklist.cfg'
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] '/usr/share/memtest86-efi/mt86.png' -> '/boot/EFI/memtest86/mt86.png'
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] '/usr/share/memtest86-efi/unifont.bin' -> '/boot/EFI/memtest86/unifont.bin'
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] '/usr/share/memtest86-efi/bootx64.efi' -> '/boot/EFI/memtest86/memtestx64.efi'
[2025-02-17T23:26:16+1000] [ALPM-SCRIPTLET] MemTest86 has been updated in ESP.
[2025-02-17T23:26:16+1000] [ALPM] running 'rebuild-detector.hook'...
[2025-02-17T23:26:27+1000] [ALPM-SCRIPTLET] foreign     agisoft-metashape-pro
[2025-02-17T23:26:27+1000] [ALPM-SCRIPTLET] foreign     masterpdfeditor
[2025-02-17T23:26:27+1000] [ALPM-SCRIPTLET] foreign     zoom
[2025-02-17T23:26:27+1000] [ALPM-SCRIPTLET] foreign     zotero-bin
[2025-02-17T23:26:27+1000] [ALPM] running 'sdboot-kernel-update.hook'...
[2025-02-17T23:26:27+1000] [ALPM] running 'texinfo-install.hook'...
[2025-02-17T23:26:28+1000] [ALPM] running 'update-desktop-database.hook'...
[2025-02-17T23:26:28+1000] [ALPM] running 'xorg-mkfontscale.hook'...
[2025-02-17T23:28:40+1000] [ALPM] transaction started
[2025-02-17T23:28:40+1000] [ALPM] removed wayland-protocols (1.39-1)
[2025-02-17T23:28:41+1000] [ALPM] transaction completed
[2025-02-17T23:28:41+1000] [ALPM] running '30-systemd-update.hook'...
[2025-02-17T23:29:30+1000] [ALPM] transaction started
[2025-02-17T23:29:30+1000] [ALPM] removed ibus (1.5.31-2)
[2025-02-17T23:29:30+1000] [ALPM] transaction completed
[2025-02-17T23:29:30+1000] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running '30-systemd-update.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'dconf-update.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'glib-compile-schemas.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'gtk4-querymodules.hook'...
[2025-02-17T23:29:31+1000] [ALPM] running 'update-desktop-database.hook'...
[2025-02-17T23:29:41+1000] [ALPM] transaction started
[2025-02-17T23:29:41+1000] [ALPM] removed libibus (1.5.31-2)
[2025-02-17T23:29:41+1000] [ALPM] transaction completed
[2025-02-17T23:29:41+1000] [ALPM] running '30-systemd-update.hook'...
Your log is not comparable because you already had fcitx5 installed.
Yeah but ibus was also installed for some reason. Could be a AUR thing because I enabled it in pamac. However, sdl2 doesn’t seems to depend on them either.
Oh, right.
Unfortunately pamac seems to create less useful logs in pacman.log …
But it would appear that, regardless of parsing the depends earlier - if the previous output is to be believed, the installation of those depends still occurs at the end of the transaction.
It is similarly unclear which package(s) caused the deps (ibus) to be installed.
I don’t understand where the confusion is coming from regarding ibus.
sdl2
makedepends=('alsa-lib' 'dbus' 'mesa' 'libpulse' 'libxrandr' 'libxinerama' 'wayland' 'libxkbcommon'
             'wayland-protocols' 'ibus' 'fcitx5' 'libxss' 'cmake' 'jack' 'ninja' 'pipewire'
             'libdecor' 'vulkan-driver' 'vulkan-headers' 'libsamplerate')
To confirm the issue it’s easier to check pamac history, there the update ends with:
2025-02-17T10:16:34+0300] [ALPM] installed cmake (3.31.5-1)
[2025-02-17T10:16:33+0300] [ALPM] installed fcitx5 (5.1.12-1)
[2025-02-17T10:16:33+0300] [ALPM] installed jsoncpp (1.9.6-3)
[2025-02-17T10:16:33+0300] [ALPM] installed rhash (1.4.4-1)
[2025-02-17T10:16:33+0300] [ALPM] installed cppdap (1.58.0-2)
[2025-02-17T10:16:33+0300] [ALPM] installed wayland-protocols (1.39-1)
[2025-02-17T10:16:33+0300] [ALPM] installed xcb-imdkit (1.0.9-1)
[2025-02-17T10:16:33+0300] [ALPM] installed ninja (1.12.1-2)
[2025-02-17T10:16:33+0300] [ALPM] installed ibus (1.5.31-2)
[2025-02-17T10:16:32+0300] [ALPM] installed libibus (1.5.31-2)
[2025-02-17T10:16:32+0300] [ALPM] upgraded zenity (4.0.3-1 -> 4.0.5-1)
Then remove fcitx5 and remove orphans.
