maybe my fault. I think the complete command is ‘sudo manjaro-chroot -a’.
I took it form https://forum.manjaro.org/t/how-do-i-chroot-into-my-system-and-update-my-kernel/129729
HP
HP
Thanks
the second one solve my problem but idk if i have to do the first one or update my kernel
Hey, I have the same problem today but for me it still doesnt work, maybe someone cold helb pls ![]()
What I did so far:
su
etc/mkinitcpio.conf
and heres my problem, it says etc/mkinitcpio.conf no Permission
what can I do?
if you successfully chrooted, just install a newer kernel:
mhwd-kernel -i linux510
or if you want to edit the mkinitcpio, use nano:
nano /etc/mkinitcpio.conf
edit it as instructed here, save it with ctrl+x, press ‘y’, then enter and update it:
mkinitcpio -P && update-grub
exit chroot and reboot
Thank you very much for the help!!
changing the #COMPRESSION=“gzip”
worked for me, i wish there would have been a warning or something
like please install kernal 5.1 or newer
Just update mkinitcpio 35.2-2 which has gzip set by default.
Do not need to fix it manually.
Thanks for your help @Zesko, @brahma and @hape! I’m back in my system. The new mkinitcipio comes after reboot via update. But i changed to 6.1 today too.
