initcpio need shutdown in HOOKS against random hangs during poweroff.
Branch: unstable
Systemd: systemd 245.5-2
ISSUE
Device can randomly hangs during reboot or shutdown proccess, Power Button pressing 5 seconds only helps here.
WORKAROUND
Adding to HOOKS array shutdown hook and refresh kernels.
QUOTE:
The work-around for now appears to edit /etc/mkinitcpio.conf and look for the following line:
HOOKS="base udev autodetect modconf block keyboard keymap filesystems"
Add the shutdown hook like so:
HOOKS="base udev autodetect modconf block keyboard keymap filesystems shutdown"
Afterwards, regenerate the initramfs as follows:
sudo mkinitcpio -P
Upon reboot and a 2nd shutdown, the problem seems to go away. The developers (either archlinux or systemd) might want to check to ensure this is a regression or intended behavior.
I am surprised that the [shutdown] hook isn't in there already, just as I am equally surprised that the [usr] hook is also missing. :astonished:
I had already requested that those two hooks would be added at least a month before the release of the 19.0 Kyria images, and I even wrote ─ per @philm's request ─ an ad hoc inclusion routine for those two hooks, notwithstanding that I don't know Python and that I had to figure out the syntax on the fly.
:thinking:
is needed for and where exactly put in?
Needed if you have /usr on a separate partition (as I have). It makes sure that /usr is mounted in early userspace, because without it, GNU/Linux systems with a full /usr merge ─ like Manjaro and Arch ─ won't boot, given that systemd cannot be found then.
As for where to put it, here's where I put it on my system...:
HOOKS="base udev autodetect modconf block keyboard keymap filesystems usr shutdown"
Ironic notice xD
Yes, although it must also be said that the [fsck] hook should not be included if you use btrfs. :wink:
ext4 here (classics)
