I get the following message when trying to shutdown:
INFO: task kworker/5:3:434 blocked for more than 368 seconds
Tainted: G OE 5.12.16-1-MANJARO #1
Here’s my inxi
$ inxi -Fxxxz
System: Kernel: 5.12.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.3
tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05 serial: <filter>
Chassis: type: 31 v: IdeaPad Flex 5 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: EECN35WW
date: 04/16/2021
Battery: ID-1: BAT0 charge: 31.6 Wh (60.2%) condition: 52.5/52.5 Wh (100.0%) volts: 11.6 min: 11.5
model: Celxpert L19C3PD6 type: Li-poly serial: <filter> status: Unknown cycles: 1
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2
rev: 1 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31958
Speed: 3828 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 3828 2: 2052
3: 1756 4: 2321 5: 2547 6: 2594 7: 2437 8: 3393
Graphics: Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:1636
class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 174f:243f
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu
resolution: 2560x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.16-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8822ce v: N/A port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f3u1u4 state: down mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled rfk-block: hardware: no
software: yes address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 94.62 GiB (19.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 3L1QEXF7 scheme: GPT
Partition: ID-1: / size: 451.77 GiB used: 94.6 GiB (20.9%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 16.9 MiB (5.6%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 16.58 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 45.6 C mobo: 35.0 C gpu: amdgpu temp: 37.0 C
Info: Processes: 222 Uptime: 2m wakeups: 5 Memory: 15.07 GiB used: 1001 MiB (6.5%) Init: systemd
v: 248 Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1398 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.05
I think that it’s related to the Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:3
This only happens when the USB/ethernet dongle is connected to the laptop.
My laptop doesn’t have an rj45 plug and I need to connect to an internal network.
Any suggestion on what to do?
Thank you
