Hello! Is there a way to install Manjaro Pahvo using btrfs instead of ext4?
I saw some older information about how to do it with the Architect installer, but I don’t see that available for download anymore.
Yes, there’s an option now in the calamares installer.
You need to use manual partitioning.
I installed it yesterday, no manual partitioning was required. Though updating with pacman now creates a backup using btrfs snapshots. Maybe it is more reliable in case of serious problems, but is slow for sure.
Found it, thanks!
FYI: for anyone else who might end up here looking for it, it’s under the “Erase Disk” option
