I’m encountering the following bug while trying to run some python script:
Inconsistency detected by ld.so: ../sysdeps/x86_64/dl-machine.h: 541: elf_machine_rela_relative: Assertion `ELFW(R_TYPE) (reloc->r_info) == R_X86_64_RELATIVE' failed!
Nothing other than rebooting fixes this. Thereafter, the same code works fine but I encounter this error after sometime nevertheless.
Truncated Output of sudo dmesg -T -H
+0.000005] microcode: CPU2: patch_level=0x0a201009
[ +0.000002] microcode: CPU3: patch_level=0x0a201009
[ +0.000002] microcode: CPU4: patch_level=0x0a201009
[ +0.000005] microcode: CPU5: patch_level=0x0a201009
[ +0.000005] microcode: CPU6: patch_level=0x0a201009
[ +0.000005] microcode: CPU7: patch_level=0x0a201009
[ +0.000002] microcode: CPU8: patch_level=0x0a201009
[ +0.000004] microcode: CPU9: patch_level=0x0a201009
[ +0.000004] microcode: CPU10: patch_level=0x0a201009
[ +0.000004] microcode: CPU11: patch_level=0x0a201009
[ +0.000005] microcode: CPU12: patch_level=0x0a201009
[ +0.000004] microcode: CPU13: patch_level=0x0a201009
[ +0.000005] microcode: CPU14: patch_level=0x0a201009
[ +0.000004] microcode: CPU15: patch_level=0x0a201009
[ +0.000020] microcode: Microcode Update Driver: v2.2.
[ +0.000105] *** VALIDATE rdt ***
[ +0.000002] resctrl: L3 allocation detected
[ +0.000000] resctrl: L3DATA allocation detected
[ +0.000000] resctrl: L3CODE allocation detected
[ +0.000001] resctrl: MB allocation detected
[ +0.000000] resctrl: L3 monitoring detected
[ +0.000001] IPI shorthand broadcast: enabled
[ +0.000005] sched_clock: Marking stable (464312705, 313566947)->(780217744, -2338092)
[ +0.000086] registered taskstats version 1
[ +0.000004] Loading compiled-in X.509 certificates
[ +0.001302] Loaded X.509 cert 'Build time autogenerated kernel key: 3b36beaa488fa719f8f2bdaddc172d1515d569ce'
[ +0.000033] zswap: loaded using pool lzo/zbud
[ +0.000095] Key type ._fscrypt registered
[ +0.000000] Key type .fscrypt registered
[ +0.001834] Key type big_key registered
[ +0.000002] AppArmor: AppArmor sha1 policy hashing enabled
[ +0.000229] PM: Magic number: 0:206:212
[ +0.000021] acpi device:63: hash matches
[ +0.000064] rtc_cmos 00:02: setting system clock to 2020-12-21T04:13:04 UTC (1608523984)
[ +0.208096] nvme nvme0: 32/0/0 default/read/poll queues
[ +0.004713] nvme0n1: p1 p2 p3
[ +0.001058] Freeing unused decrypted memory: 2040K
[ +0.000194] Freeing unused kernel image memory: 1644K
[ +0.013702] Write protecting the kernel read-only data: 18432k
[ +0.000378] Freeing unused kernel image memory: 2008K
[ +0.004594] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ +0.000001] Run /init as init process
[ +0.040170] SCSI subsystem initialized
[ +0.001433] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[ +0.000004] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 1
[ +0.000154] xhci_hcd 0000:2a:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ +0.000431] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ +0.000001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb1: Product: xHCI Host Controller
[ +0.000000] usb usb1: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000001] usb usb1: SerialNumber: 0000:2a:00.1
[ +0.000052] hub 1-0:1.0: USB hub found
[ +0.000009] hub 1-0:1.0: 6 ports detected
[ +0.000147] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[ +0.000001] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 2
[ +0.000001] xhci_hcd 0000:2a:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ +0.000023] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ +0.000008] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ +0.000000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb2: Product: xHCI Host Controller
[ +0.000000] usb usb2: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000000] usb usb2: SerialNumber: 0000:2a:00.1
[ +0.000034] hub 2-0:1.0: USB hub found
[ +0.000006] hub 2-0:1.0: 4 ports detected
[ +0.000038] usb: port power management may be unreliable
[ +0.000077] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[ +0.000002] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 3
[ +0.000150] xhci_hcd 0000:2a:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ +0.000294] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ +0.000000] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000000] usb usb3: Product: xHCI Host Controller
[ +0.000001] usb usb3: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000001] usb usb3: SerialNumber: 0000:2a:00.3
[ +0.000046] hub 3-0:1.0: USB hub found
[ +0.000010] hub 3-0:1.0: 6 ports detected
[ +0.000147] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[ +0.000001] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 4
[ +0.000001] xhci_hcd 0000:2a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ +0.000008] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ +0.000008] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ +0.000000] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb4: Product: xHCI Host Controller
[ +0.000000] usb usb4: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000000] usb usb4: SerialNumber: 0000:2a:00.3
[ +0.000034] hub 4-0:1.0: USB hub found
[ +0.000007] hub 4-0:1.0: 4 ports detected
[ +0.000089] libata version 3.00 loaded.
[ +0.000030] xhci_hcd 0000:2f:00.3: xHCI Host Controller
[ +0.000002] xhci_hcd 0000:2f:00.3: new USB bus registered, assigned bus number 5
[ +0.000102] xhci_hcd 0000:2f:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ +0.000226] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ +0.000000] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb5: Product: xHCI Host Controller
[ +0.000000] usb usb5: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000001] usb usb5: SerialNumber: 0000:2f:00.3
[ +0.000037] hub 5-0:1.0: USB hub found
[ +0.000004] hub 5-0:1.0: 4 ports detected
[ +0.000088] xhci_hcd 0000:2f:00.3: xHCI Host Controller
[ +0.000001] xhci_hcd 0000:2f:00.3: new USB bus registered, assigned bus number 6
[ +0.000001] xhci_hcd 0000:2f:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ +0.000006] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ +0.000008] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ +0.000000] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb6: Product: xHCI Host Controller
[ +0.000000] usb usb6: Manufacturer: Linux 5.4.80-2-MANJARO xhci-hcd
[ +0.000001] usb usb6: SerialNumber: 0000:2f:00.3
[ +0.000032] hub 6-0:1.0: USB hub found
[ +0.000004] hub 6-0:1.0: 4 ports detected
[ +0.000795] ahci 0000:26:00.0: version 3.0
[ +0.000094] ahci 0000:26:00.0: SSS flag set, parallel bus scan disabled
[ +0.000042] ahci 0000:26:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ +0.000001] ahci 0000:26:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc
[ +0.003436] scsi host0: ahci
[ +0.000141] scsi host1: ahci
[ +0.000028] ata1: SATA max UDMA/133 abar m512@0xfc800000 port 0xfc800100 irq 93
[ +0.000003] ata2: SATA max UDMA/133 abar m512@0xfc800000 port 0xfc800180 irq 93
[ +0.000132] ahci 0000:2b:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ +0.000002] ahci 0000:2b:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ +0.000093] scsi host2: ahci
[ +0.000027] ata3: SATA max UDMA/133 abar m2048@0xfc500000 port 0xfc500100 irq 94
[ +0.000125] ahci 0000:2c:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ +0.000001] ahci 0000:2c:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ +0.000090] scsi host3: ahci
[ +0.000025] ata4: SATA max UDMA/133 abar m2048@0xfc400000 port 0xfc400100 irq 95
[ +0.314654] ata3: SATA link down (SStatus 0 SControl 300)
[ +0.000281] ata4: SATA link down (SStatus 0 SControl 300)
[ +0.007440] usb 3-5: new full-speed USB device number 2 using xhci_hcd
[ +0.000003] usb 5-3: new full-speed USB device number 2 using xhci_hcd
[ +0.000003] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[ +0.154140] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ +0.001606] ata1.00: ATA-8: ST32000644NS, KA06, max UDMA/133
[ +0.000001] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32)
[ +0.001210] usb 3-5: New USB device found, idVendor=1462, idProduct=7c37, bcdDevice= 0.01
[ +0.000001] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000001] usb 3-5: Product: MYSTIC LIGHT
[ +0.000000] usb 3-5: Manufacturer: MSI
[ +0.000001] usb 3-5: SerialNumber: A02019050806
[ +0.000157] usb 1-4: New USB device found, idVendor=8087, idProduct=0aa7, bcdDevice= 0.01
[ +0.000001] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.000471] ata1.00: configured for UDMA/133
[ +0.000094] scsi 0:0:0:0: Direct-Access ATA ST32000644NS KA06 PQ: 0 ANSI: 5
[ +0.004910] usb 5-3: New USB device found, idVendor=1532, idProduct=0228, bcdDevice= 2.00
[ +0.000000] usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000001] usb 5-3: Product: Razer BlackWidow Elite
[ +0.000000] usb 5-3: Manufacturer: Razer
[ +0.008274] hidraw: raw HID events driver (C) Jiri Kosina
[ +0.029761] usbcore: registered new interface driver usbhid
[ +0.000001] usbhid: USB HID core driver
[ +0.001202] input: MSI MYSTIC LIGHT as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.3/usb3/3-5/3-5:1.0/0003:1462:7C37.0001/input/input2
[ +0.000049] hid-generic 0003:1462:7C37.0001: input,hiddev0,hidraw0: USB HID v1.10 Device [MSI MYSTIC LIGHT ] on usb-0000:2a:00.3-5/input0
[ +0.000060] input: Razer Razer BlackWidow Elite as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.0/0003:1532:0228.0002/input/input3
[ +0.055568] hid-generic 0003:1532:0228.0002: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer BlackWidow Elite] on usb-0000:2f:00.3-3/input0
[ +0.000085] input: Razer Razer BlackWidow Elite Keyboard as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.1/0003:1532:0228.0003/input/input4
[ +0.033209] usb 3-6: new high-speed USB device number 3 using xhci_hcd
[ +0.023358] input: Razer Razer BlackWidow Elite Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.1/0003:1532:0228.0003/input/input5
[ +0.000013] input: Razer Razer BlackWidow Elite System Control as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.1/0003:1532:0228.0003/input/input6
[ +0.000011] input: Razer Razer BlackWidow Elite as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.1/0003:1532:0228.0003/input/input7
[ +0.000033] hid-generic 0003:1532:0228.0003: input,hidraw2: USB HID v1.11 Keyboard [Razer Razer BlackWidow Elite] on usb-0000:2f:00.3-3/input1
[ +0.000047] input: Razer Razer BlackWidow Elite as /devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3:1.2/0003:1532:0228.0004/input/input8
[ +0.000032] hid-generic 0003:1532:0228.0004: input,hidraw3: USB HID v1.11 Mouse [Razer Razer BlackWidow Elite] on usb-0000:2f:00.3-3/input2
[ +0.066507] tsc: Refined TSC clocksource calibration: 3799.999 MHz
[ +0.000005] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d8cadf3fd9, max_idle_ns: 881590557866 ns
[ +0.000240] clocksource: Switched to clocksource tsc
[ +0.052808] usb 3-6: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
[ +0.000001] usb 3-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0.000001] usb 3-6: Product: USB2.0 Hub
[ +0.036700] ata2: SATA link down (SStatus 0 SControl 300)
[ +0.001747] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ +0.000006] sd 0:0:0:0: [sda] Write Protect is off
[ +0.000001] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ +0.000009] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ +0.000036] hub 3-6:1.0: USB hub found
[ +0.000605] hub 3-6:1.0: 4 ports detected
[ +0.067626] sda: sda1
[ +0.000351] sd 0:0:0:0: [sda] Attached SCSI disk
[ +0.060847] random: fast init done
[ +0.154930] PM: Image not found (code -22)
[ +0.038613] EXT4-fs (nvme0n1p2): recovery complete
[ +0.000226] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ +0.057826] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 >
[ +0.014109] systemd[1]: Detected architecture x86-64.
[ +0.034363] systemd[1]: Set hostname to <t2k2>.
[ +0.075035] systemd[1]: Queued start job for default target Graphical Interface.
[ +0.000609] systemd[1]: Created slice system-getty.slice.
[ +0.000125] systemd[1]: Created slice system-modprobe.slice.
[ +0.000083] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ +0.000109] systemd[1]: Created slice User and Session Slice.
[ +0.000022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ +0.000016] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ +0.000118] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ +0.000018] systemd[1]: Reached target Local Encrypted Volumes.
[ +0.000005] systemd[1]: Reached target Login Prompts.
[ +0.000012] systemd[1]: Reached target Paths.
[ +0.000006] systemd[1]: Reached target Remote File Systems.
[ +0.000005] systemd[1]: Reached target Slices.
[ +0.000033] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ +0.000130] systemd[1]: Listening on LVM2 metadata daemon socket.
[ +0.000109] systemd[1]: Listening on LVM2 poll daemon socket.
[ +0.000665] systemd[1]: Listening on Process Core Dump Socket.
[ +0.000051] systemd[1]: Listening on Journal Audit Socket.
[ +0.000033] systemd[1]: Listening on Journal Socket (/dev/log).
[ +0.000034] systemd[1]: Listening on Journal Socket.
[ +0.000037] systemd[1]: Listening on udev Control Socket.
[ +0.000025] systemd[1]: Listening on udev Kernel Socket.
[ +0.000331] systemd[1]: Mounting Huge Pages File System...
[ +0.000307] systemd[1]: Mounting POSIX Message Queue File System...
[ +0.000306] systemd[1]: Mounting Kernel Debug File System...
[ +0.000311] systemd[1]: Mounting Kernel Trace File System...
[ +0.000350] systemd[1]: Starting Load AppArmor profiles...
[ +0.000382] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ +0.000303] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ +0.000345] systemd[1]: Starting Load Kernel Module drm...
[ +0.000595] systemd[1]: Starting Set Up Additional Binary Formats...
[ +0.000021] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ +0.000656] systemd[1]: Starting Journal Service...
[ +0.000554] systemd[1]: Starting Load Kernel Modules...
[ +0.000292] systemd[1]: Starting Remount Root and Kernel File Systems...
[ +0.000018] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ +0.000317] systemd[1]: Starting Coldplug All udev Devices...
[ +0.000510] systemd[1]: Mounted Huge Pages File System.
[ +0.000051] systemd[1]: Mounted POSIX Message Queue File System.
[ +0.000049] systemd[1]: Mounted Kernel Debug File System.
[ +0.000042] systemd[1]: Mounted Kernel Trace File System.
[ +0.000169] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ +0.000103] systemd[1]: modprobe@drm.service: Succeeded.
[ +0.000116] systemd[1]: Finished Load Kernel Module drm.
[ +0.000050] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 341 (systemd-binfmt)
[ +0.000378] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ +0.000397] random: lvm: uninitialized urandom read (4 bytes read)
[ +0.000517] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ +0.000046] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[ +0.000382] systemd[1]: Finished Remount Root and Kernel File Systems.
[ +0.000108] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ +0.000538] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ +0.000294] systemd[1]: Starting Load/Save Random Seed...
[ +0.000028] systemd[1]: Condition check resulted in Create System Users being skipped.
[ +0.000308] systemd[1]: Starting Create Static Device Nodes in /dev...
[ +0.000199] systemd[1]: Finished Set Up Additional Binary Formats.
[ +0.002904] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ +0.003418] mc: Linux media interface: v0.10
[ +0.003305] systemd[1]: Finished Create Static Device Nodes in /dev.
[ +0.000697] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ +0.003992] videodev: Linux video capture interface: v2.00
[ +0.013925] systemd[1]: Finished Coldplug All udev Devices.
[ +0.003271] audit: type=1400 audit(1608523986.118:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=355 comm="apparmor_parser"
[ +0.000056] audit: type=1400 audit(1608523986.118:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=355 comm="apparmor_parser"
[ +0.006975] audit: type=1400 audit(1608523986.125:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=357 comm="apparmor_parser"
[ +0.009635] audit: type=1400 audit(1608523986.135:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=358 comm="apparmor_parser"
[ +0.004852] audit: type=1400 audit(1608523986.141:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=359 comm="apparmor_parser"
[ +0.065817] nvidia: loading out-of-tree module taints kernel.
[ +0.000004] nvidia: module license 'NVIDIA' taints kernel.
[ +0.000001] Disabling lock debugging due to kernel taint
[ +0.003949] audit: type=1400 audit(1608523986.211:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=356 comm="apparmor_parser"
[ +0.000124] audit: type=1400 audit(1608523986.211:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=356 comm="apparmor_parser"
[ +0.000957] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ +0.000223] systemd[1]: Finished Load AppArmor profiles.
[ +0.000021] audit: type=1130 audit(1608523986.211:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000459] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ +0.003495] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ +0.000224] nvidia 0000:2d:00.0: enabling device (0002 -> 0003)
[ +0.000067] nvidia 0000:2d:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ +0.003481] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
[ +0.000022] audit: type=1130 audit(1608523986.218:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd.apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.010730] systemd[1]: Started Journal Service.
[ +0.026656] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
[ +0.007632] Linux agpgart interface v0.103
[ +0.034720] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 455.45.01 Thu Nov 5 22:55:44 UTC 2020
[ +0.001479] [drm] [nvidia-drm] [GPU ID 0x00002d00] Loading driver
[ +0.000001] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:2d:00.0 on minor 0
[ +0.009048] random: mktemp: uninitialized urandom read (6 bytes read)
[ +0.000034] random: mktemp: uninitialized urandom read (6 bytes read)
[ +0.011361] random: crng init done
[ +0.000001] random: 7 urandom warning(s) missed due to ratelimiting
[ +0.009569] Adding 36154128k swap on /dev/nvme0n1p3. Priority:-2 extents:1 across:36154128k SSFS
[ +0.006366] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ +0.000001] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ +0.000066] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ +0.000401] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ +0.001762] i2c /dev entries driver
[ +0.000005] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ +0.000053] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ +0.000005] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ +0.000236] cryptd: max_cpu_qlen set to 1000
[ +0.006958] AVX2 version of gcm_enc/dec engaged.
[ +0.000000] AES CTR mode by8 optimization enabled
[ +0.005157] snd_hda_intel 0000:2d:00.1: enabling device (0000 -> 0002)
[ +0.000081] snd_hda_intel 0000:2d:00.1: Disabling MSI
[ +0.000010] snd_hda_intel 0000:2d:00.1: Handle vga_switcheroo audio client
[ +0.000074] snd_hda_intel 0000:2f:00.4: enabling device (0000 -> 0002)
[ +0.000583] r8169 0000:27:00.0: enabling device (0000 -> 0003)
[ +0.031141] libphy: r8169: probed
[ +0.000180] r8169 0000:27:00.0 eth0: RTL8168h/8111h, 2c:f0:5d:8c:e9:78, XID 541, IRQ 100
[ +0.000002] r8169 0000:27:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ +0.037054] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ +0.000418] r8169 0000:27:00.0 enp39s0: renamed from eth0
[ +0.000973] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ +0.002307] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ +0.000002] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ +0.000001] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ +0.000000] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ +0.000001] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ +0.000000] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ +0.000001] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ +0.000001] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ +0.000001] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ +0.083109] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input10
[ +0.000059] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input11
[ +0.000058] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input12
[ +0.000063] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input13
[ +0.000056] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input14
[ +0.000050] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input15
[ +0.000049] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input16
[ +0.004792] Intel(R) Wireless WiFi driver for Linux
[ +0.000002] Copyright(c) 2003- 2015 Intel Corporation
[ +0.000109] iwlwifi 0000:29:00.0: enabling device (0000 -> 0002)
[ +0.002348] kvm: disabled by bios
[ +0.003024] iwlwifi 0000:29:00.0: loaded firmware version 29.198743027.0 op_mode iwlmvm
[ +0.068224] EXT4-fs (sda1): recovery complete
[ +0.041666] kvm: disabled by bios
[ +0.003590] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ +0.115886] kvm: disabled by bios
[ +0.001854] iwlwifi 0000:29:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[ +0.017604] iwlwifi 0000:29:00.0: base HW address: 34:2e:b7:7c:27:1b
[ +0.028904] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ +0.000193] thermal thermal_zone0: failed to read out thermal zone (-61)
[ +0.063341] kvm: disabled by bios
[ +0.003769] iwlwifi 0000:29:00.0 wlp41s0: renamed from wlan0
[ +0.042838] Generic FE-GE Realtek PHY r8169-2700:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-2700:00, irq=IGNORE)
[ +0.042195] kvm: disabled by bios
[ +0.062716] r8169 0000:27:00.0 enp39s0: Link is Down
[ +0.016114] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.1/sound/card0/input17
[ +0.000045] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.1/sound/card0/input18
[ +0.000032] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.1/sound/card0/input19
[ +0.000031] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.1/sound/card0/input20
[ +0.066390] loop: module loaded
[ +0.001516] kvm: disabled by bios
[ +0.118949] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ +0.000258] kvm: disabled by bios
[ +0.133889] kvm: disabled by bios
[ +0.112546] mousedev: PS/2 mouse device common for all mice
[ +0.000418] kvm: disabled by bios
[ +0.089539] kvm: disabled by bios
[ +0.006909] Bluetooth: Core ver 2.22
[ +0.000011] NET: Registered protocol family 31
[ +0.000001] Bluetooth: HCI device and connection manager initialized
[ +0.000003] Bluetooth: HCI socket layer initialized
[ +0.000001] Bluetooth: L2CAP socket layer initialized
[ +0.000001] Bluetooth: SCO socket layer initialized
[ +0.118656] usbcore: registered new interface driver btusb
[ +0.002312] kvm: disabled by bios
[ +0.012581] Bluetooth: hci0: read Intel version: 370810225019140f00
[ +0.000460] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[ +0.005615] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ +0.000002] Bluetooth: BNEP filters: protocol multicast
[ +0.000002] Bluetooth: BNEP socket layer initialized
[ +0.143589] kvm: disabled by bios
[ +0.147288] kvm: disabled by bios
[ +0.120087] kvm: disabled by bios
[ +0.106613] kvm: disabled by bios
[ +0.049342] Bluetooth: hci0: Intel firmware patch completed and activated
[ +0.057208] kvm: disabled by bios
[ +0.088576] NET: Registered protocol family 38
[ +1.596681] kauditd_printk_skb: 34 callbacks suppressed
[ +0.000001] audit: type=1100 audit(1608523990.008:45): pid=1125 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? termin>
[ +0.000003] audit: type=1101 audit(1608523990.008:46): pid=1125 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=?>
[ +0.000401] audit: type=1103 audit(1608523990.008:47): pid=1125 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? re>
[ +0.014835] audit: type=1130 audit(1608523990.021:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.006588] audit: type=1101 audit(1608523990.028:49): pid=1127 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=>
[ +0.000010] audit: type=1103 audit(1608523990.028:50): pid=1127 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000021] audit: type=1006 audit(1608523990.028:51): pid=1127 uid=0 subj==unconfined old-auid=4294967295 auid=967 tty=(none) old-ses=4294967295 ses=1 res=1
[ +0.000823] audit: type=1105 audit(1608523990.028:52): pid=1127 uid=0 auid=967 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env>
[ +0.060360] audit: type=1130 audit(1608523990.088:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.003730] audit: type=1105 audit(1608523990.095:54): pid=1125 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=>
[ +6.053308] kauditd_printk_skb: 4 callbacks suppressed
[ +0.000001] audit: type=1100 audit(1608523996.148:59): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="toshi" exe="/usr/lib/sddm>
[ +0.000605] audit: type=1101 audit(1608523996.148:60): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="toshi" exe="/usr/lib/sddm/sddm-helper" hostnam>
[ +0.000150] audit: type=1103 audit(1608523996.148:61): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="toshi" exe="/usr/lib/sddm/sddm-h>
[ +0.000028] audit: type=1006 audit(1608523996.148:62): pid=1195 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ +0.016183] audit: type=1130 audit(1608523996.165:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.004560] audit: type=1101 audit(1608523996.168:64): pid=1197 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="toshi" exe="/usr/lib/systemd/systemd" hostname>
[ +0.000014] audit: type=1103 audit(1608523996.168:65): pid=1197 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="toshi" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000030] audit: type=1006 audit(1608523996.168:66): pid=1197 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ +0.000495] audit: type=1105 audit(1608523996.168:67): pid=1197 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_en>
[ +0.067348] audit: type=1130 audit(1608523996.235:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.085527] fuse: init (API version 7.31)
[ +0.000034] *** VALIDATE fuse ***
[ +0.000010] *** VALIDATE fuse ***
[ +0.602526] Bluetooth: RFCOMM TTY layer initialized
[ +0.000003] Bluetooth: RFCOMM socket layer initialized
[ +0.000003] Bluetooth: RFCOMM ver 1.11
[ +1.507043] wlp41s0: authenticate with c4:71:54:48:b0:10
[ +0.004011] wlp41s0: send auth to c4:71:54:48:b0:10 (try 1/3)
[ +0.008812] wlp41s0: authenticated
[ +0.002384] wlp41s0: associate with c4:71:54:48:b0:10 (try 1/3)
[ +0.010636] wlp41s0: RX AssocResp from c4:71:54:48:b0:10 (capab=0x411 status=0 aid=4)
[ +0.003318] wlp41s0: associated
[ +0.129215] IPv6: ADDRCONF(NETDEV_CHANGE): wlp41s0: link becomes ready
[ +3.482040] input: BluetoothMouse3600 Mouse as /devices/virtual/misc/uhid/0005:045E:0916.0005/input/input21
[ +0.000075] input: BluetoothMouse3600 Consumer Control as /devices/virtual/misc/uhid/0005:045E:0916.0005/input/input22
[ +0.000040] hid-generic 0005:045E:0916.0005: input,hidraw4: BLUETOOTH HID v1.10 Mouse [BluetoothMouse3600] on 34:2e:b7:7c:27:1f
[ +4.328966] kauditd_printk_skb: 6 callbacks suppressed
[ +0.000001] audit: type=1131 audit(1608524006.401:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.007568] audit: type=1131 audit(1608524006.408:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +2.630524] audit: type=1131 audit(1608524009.041:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[ +8.689132] audit: type=1131 audit(1608524018.329:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +17.696375] input: BluetoothMouse3600 Mouse as /devices/virtual/misc/uhid/0005:045E:0916.0006/input/input23
[ +0.000086] input: BluetoothMouse3600 Consumer Control as /devices/virtual/misc/uhid/0005:045E:0916.0006/input/input24
[ +0.000053] hid-generic 0005:045E:0916.0006: input,hidraw4: BLUETOOTH HID v1.10 Mouse [BluetoothMouse3600] on 34:2e:b7:7c:27:1f
[Dec20 23:16] nvidia-uvm: Loaded the UVM driver, major device number 237.
[Dec20 23:28] audit: type=1130 audit(1608524904.753:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
[ +0.000004] audit: type=1131 audit(1608524904.753:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
[Dec20 23:39] audit: type=1100 audit(1608525553.707:81): pid=4887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="toshi" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[Dec21 00:00] audit: type=1130 audit(1608526800.609:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.007713] audit: type=1131 audit(1608526800.615:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.001486] audit: type=1130 audit(1608526800.619:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
[ +0.011213] audit: type=1130 audit(1608526800.629:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000003] audit: type=1131 audit(1608526800.629:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.417744] audit: type=1130 audit(1608526801.045:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000003] audit: type=1131 audit(1608526801.045:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +1.020335] audit: type=1130 audit(1608526802.065:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000004] audit: type=1131 audit(1608526802.065:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Dec21 00:13] audit: type=1130 audit(1608527599.249:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[ +10.382332] audit: type=1131 audit(1608527609.632:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[Dec21 00:20] audit: type=1100 audit(1608528029.762:93): pid=7146 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="toshi" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ +4.648717] input: BluetoothMouse3600 Mouse as /devices/virtual/misc/uhid/0005:045E:0916.0007/input/input25
[ +0.000084] input: BluetoothMouse3600 Consumer Control as /devices/virtual/misc/uhid/0005:045E:0916.0007/input/input26
[ +0.000047] hid-generic 0005:045E:0916.0007: input,hidraw4: BLUETOOTH HID v1.10 Mouse [BluetoothMouse3600] on 34:2e:b7:7c:27:1f
[ +3.666675] input: Obsidian (AVRCP) as /devices/virtual/input/input27
[Dec21 00:24] python[3102]: segfault at 2e7 ip 00007f34b410c404 sp 00007ffc152ec810 error 6 in libpython3.8.so.1.0[7f34b4100000+1e7000]
[ +0.000019] Code: 45 24 e9 2f 34 0b 00 4c 89 54 24 28 4c 89 44 24 20 4c 89 1c 24 e8 1c 13 0a 00 4c 8b 54 24 28 4c 8b 44 24 20 4c 8b 1c 24 eb c8 <48> 83 2f 01 74 12 48 83 fb 01 0f 85 48 33 0b 00 8b 45 24 e9 f4 33
[ +0.000083] audit: type=1701 audit(1608528279.393:94): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=3102 comm="python" exe="/usr/bin/python3.8" sig=11 res=1
[ +0.023213] audit: type=1130 audit(1608528279.416:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-7463-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[ +1.332774] audit: type=1131 audit(1608528280.746:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-7463-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[ +0.014505] BUG: Bad page map in process python pte:800000063a00b045 pmd:6488cb067
[ +0.000005] page:fffff8a2d8e802c0 refcount:1 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000002] flags: 0x2ffff0000000008(dirty)
[ +0.000002] raw: 02ffff0000000008 dead000000000100 dead000000000122 0000000000000000
[ +0.000001] raw: 0000000000000000 0000000000000000 00000001fffffffe 0000000000000000
[ +0.000000] page dumped because: bad pte
[ +0.000001] addr:0000558c47ff8000 vm_flags:00100073 anon_vma:ffff95f78be98b00 mapping:0000000000000000 index:558c47ff8
[ +0.000004] file:(null) fault:0x0 mmap:0x0 readpage:0x0
[ +0.000002] CPU: 3 PID: 7509 Comm: python Tainted: P OE 5.4.80-2-MANJARO #1
[ +0.000001] Hardware name: Micro-Star International Co., Ltd. MS-7C37/MPG X570 GAMING EDGE WIFI (MS-7C37), BIOS 1.D1 11/13/2020
[ +0.000001] Call Trace:
[ +0.000014] dump_stack+0x64/0x88
[ +0.000007] print_bad_pte.cold+0x95/0xbf
[ +0.000002] unmap_page_range+0x856/0xde0
[ +0.000002] unmap_vmas+0x70/0xd0
[ +0.000001] exit_mmap+0xbe/0x1b0
[ +0.000005] mmput+0x49/0x110
[ +0.000003] flush_old_exec+0x33c/0x780
[ +0.000006] load_elf_binary+0x33d/0x1710
[ +0.000005] ? __check_object_size+0x56/0x147
[ +0.000006] ? _copy_from_user+0x3e/0x60
[ +0.000001] ? copy_strings.isra.0+0x24a/0x410
[ +0.000004] ? preempt_count_add+0x68/0xa0
[ +0.000006] ? _raw_read_unlock+0x18/0x30
[ +0.000001] ? load_misc_binary+0x24a/0x453
[ +0.000001] search_binary_handler.part.0+0x5b/0x220
[ +0.000001] __do_execve_file+0x594/0x960
[ +0.000001] do_execve+0x27/0x30
[ +0.000002] __x64_sys_execve+0x27/0x30
[ +0.000006] do_syscall_64+0x49/0x90
[ +0.000001] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ +0.000002] RIP: 0033:0x7f6852e023cb
[ +0.000006] Code: Bad RIP value.
[ +0.000000] RSP: 002b:00007ffed8f9f128 EFLAGS: 00000246 ORIG_RAX: 000000000000003b
[ +0.000001] RAX: ffffffffffffffda RBX: 00007f6852bbd6c8 RCX: 00007f6852e023cb
[ +0.000001] RDX: 0000558c3f8929b0 RSI: 00007f67267464b0 RDI: 00007f6726870330
[ +0.000000] RBP: 00007f67267464b0 R08: 0000000000000000 R09: 00007ffed8f9f060
[ +0.000001] R10: 0000000000000000 R11: 0000000000000246 R12: 00007f6726870340
[ +0.000000] R13: 0000000000000000 R14: 0000000000000017 R15: 0000000000000000
[ +0.000002] BUG: Bad page map in process python pte:800000063a00a045 pmd:6488cb067
[ +0.000000] page:fffff8a2d8e80280 refcount:1 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000001] flags: 0x2ffff0000000008(dirty)
[ +0.000000] raw: 02ffff0000000008 dead000000000100 dead000000000122 0000000000000000
[ +0.000000] addr:0000558c47ff9000 vm_flags:00100073 anon_vma:ffff95f78be98b00 mapping:0000000000000000 index:558c47ff9
[ +0.000001] file:(null) fault:0x0 mmap:0x0 readpage:0x0
[ +0.000001] CPU: 3 PID: 7509 Comm: python Tainted: P B OE 5.4.80-2-MANJARO #1
[ +0.000000] Hardware name: Micro-Star International Co., Ltd. MS-7C37/MPG X570 GAMING EDGE WIFI (MS-7C37), BIOS 1.D1 11/13/2020
[ +0.000000] Call Trace:
[ +0.000001] dump_stack+0x64/0x88
[ +0.000001] print_bad_pte.cold+0x95/0xbf
[ +0.000001] unmap_page_range+0x856/0xde0
[ +0.000001] unmap_vmas+0x70/0xd0
[ +0.000001] mmput+0x49/0x110
[ +0.000001] flush_old_exec+0x33c/0x780
[ +0.000000] load_elf_binary+0x33d/0x1710
[ +0.000001] ? __check_object_size+0x56/0x147
[ +0.000001] ? _copy_from_user+0x3e/0x60
[ +0.000000] ? copy_strings.isra.0+0x24a/0x410
[ +0.000001] ? preempt_count_add+0x68/0xa0
[ +0.000001] ? _raw_read_unlock+0x18/0x30
[ +0.000000] __do_execve_file+0x594/0x960
[ +0.000001] __x64_sys_execve+0x27/0x30
[ +0.000001] do_syscall_64+0x49/0x90
[ +0.000000] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ +0.000001] RIP: 0033:0x7f6852e023cb
[ +0.000001] Code: Bad RIP value.
[ +0.000000] RDX: 0000558c3f8929b0 RSI: 00007f67267464b0 RDI: 00007f6726870330
[ +0.000001] BUG: Bad page map in process python pte:800000063a00d045 pmd:6488cb067
[ +0.000001] page:fffff8a2d8e80340 refcount:2 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000000] flags: 0x2ffff0000400008(dirty|uncached)
[ +0.000001] raw: 02ffff0000400008 dead000000000100 dead000000000122 0000000000000000
[ +0.000000] raw: 0000000000000000 0000000000000000 00000002fffffffe 0000000000000000
[ +0.000001] page dumped because: bad pte
[ +0.000000] addr:0000558c47ffd000 vm_flags:00100073 anon_vma:ffff95f78be98b00 mapping:0000000000000000 index:558c47ffd
[ +0.000000] dump_stack+0x64/0x88
[ +0.000001] load_elf_binary+0x33d/0x1710
[ +0.000000] ? __check_object_size+0x56/0x147
[ +0.000000] ? _raw_read_unlock+0x18/0x30
[ +0.000000] search_binary_handler.part.0+0x5b/0x220
[ +0.000000] do_syscall_64+0x49/0x90
[ +0.000000] RIP: 0033:0x7f6852e023cb
[ +0.000001] BUG: Bad page map in process python pte:800000063a00c045 pmd:6488cb067
[ +0.000000] page:fffff8a2d8e80300 refcount:2 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000000] addr:0000558c47ffe000 vm_flags:00100073 anon_vma:ffff95f78be98b00 mapping:0000000000000000 index:558c47ffe
[ +0.000000] CPU: 3 PID: 7509 Comm: python Tainted: P B OE 5.4.80-2-MANJARO #1
[ +0.000000] flush_old_exec+0x33c/0x780
[ +0.000000] ? _copy_from_user+0x3e/0x60
[ +0.000000] ? preempt_count_add+0x68/0xa0
[ +0.000001] RSP: 002b:00007ffed8f9f128 EFLAGS: 00000246 ORIG_RAX: 000000000000003b
[ +0.000000] RAX: ffffffffffffffda RBX: 00007f6852bbd6c8 RCX: 00007f6852e023cb
[ +0.000000] R10: 0000000000000000 R11: 0000000000000246 R12: 00007f6726870340
[ +0.000001] R13: 0000000000000000 R14: 0000000000000017 R15: 0000000000000000
[ +0.000001] BUG: Bad page map in process python pte:800000063a00b045 pmd:6488cb067
[ +0.000000] page:fffff8a2d8e802c0 refcount:1 mapcount:-2 mapping:0000000000000000 index:0x0
[ +0.000000] flags: 0x2ffff0000000008(dirty)
[ +0.000001] raw: 0000000000000000 0000000000000000 00000001fffffffd 0000000000000000
[ +0.000000] addr:0000558c47fff000 vm_flags:00100073 anon_vma:ffff95f78be98b00 mapping:0000000000000000 index:558c47fff
[ +0.000000] ? load_misc_binary+0x24a/0x453
[ +0.000000] do_execve+0x27/0x30
[ +0.000000] Code: Bad RIP value.
[ +0.017059] BUG: Bad page state in process python pfn:63a00c
[ +0.000002] page:fffff8a2d8e80300 refcount:0 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000001] flags: 0x2ffff0000000000()
[ +0.000002] raw: 02ffff0000000000 dead000000000100 dead000000000122 0000000000000000
[ +0.000001] raw: 0000000000000000 0000000000000000 00000000fffffffe 0000000000000000
[ +0.000000] page dumped because: nonzero mapcount
[ +0.000001] Modules linked in: nvidia_uvm(OE) uhid ccm rfcomm fuse cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel bluetooth ecdh_generic input_leds mousedev ecc joydev squashfs loop iwlmvm snd_hda_codec_hdmi mac>
[ +0.000032] scsi_mod
[ +0.000003] CPU: 3 PID: 7509 Comm: python Tainted: P B OE 5.4.80-2-MANJARO #1
[ +0.000006] dump_stack+0x64/0x88
[ +0.000003] bad_page.cold+0x7f/0xb0
[ +0.000002] free_pcppages_bulk+0x184/0x300
[ +0.000002] free_unref_page_list+0x166/0x200
[ +0.000002] release_pages+0x397/0x410
[ +0.000003] tlb_flush_mmu+0x49/0x270
[ +0.000001] tlb_finish_mmu+0x3d/0x70
[ +0.000001] exit_mmap+0xde/0x1b0
[ +0.000004] mmput+0x49/0x110
[ +0.000002] flush_old_exec+0x33c/0x780
[ +0.000003] load_elf_binary+0x33d/0x1710
[ +0.000002] ? __check_object_size+0x56/0x147
[ +0.000002] ? _copy_from_user+0x3e/0x60
[ +0.000002] ? copy_strings.isra.0+0x24a/0x410
[ +0.000002] ? preempt_count_add+0x68/0xa0
[ +0.000002] ? _raw_read_unlock+0x18/0x30
[ +0.000002] ? load_misc_binary+0x24a/0x453
[ +0.000002] __do_execve_file+0x594/0x960
[ +0.000002] do_execve+0x27/0x30
[ +0.000002] do_syscall_64+0x49/0x90
[ +0.000002] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ +0.000004] Code: Bad RIP value.
[ +0.000002] RAX: ffffffffffffffda RBX: 00007f6852bbd6c8 RCX: 00007f6852e023cb
[ +0.000001] RBP: 00007f67267464b0 R08: 0000000000000000 R09: 00007ffed8f9f060
[ +0.000002] BUG: Bad page state in process python pfn:63a00d
[ +0.000001] page:fffff8a2d8e80340 refcount:0 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000001] raw: 02ffff0000000000 dead000000000100 dead000000000122 0000000000000000
[ +0.000016] scsi_mod
[ +0.000002] CPU: 3 PID: 7509 Comm: python Tainted: P B OE 5.4.80-2-MANJARO #1
[ +0.000002] dump_stack+0x64/0x88
[ +0.000001] bad_page.cold+0x7f/0xb0
[ +0.000001] free_pcppages_bulk+0x184/0x300
[ +0.000001] release_pages+0x397/0x410
[ +0.000002] tlb_flush_mmu+0x49/0x270
[ +0.000002] tlb_finish_mmu+0x3d/0x70
[ +0.000003] mmput+0x49/0x110
[ +0.000002] Code: Bad RIP value.
[ +0.000002] BUG: Bad page state in process python pfn:63a00a
[ +0.000000] page:fffff8a2d8e80280 refcount:0 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000000] Modules linked in: nvidia_uvm(OE) uhid ccm rfcomm fuse cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel bluetooth ecdh_generic input_leds mousedev ecc joydev squashfs loop iwlmvm snd_hda_codec_hdmi mac>
[ +0.000018] scsi_mod
[ +0.000002] bad_page.cold+0x7f/0xb0
[ +0.000001] free_unref_page_list+0x166/0x200
[ +0.000002] mmput+0x49/0x110
[ +0.000001] BUG: Bad page state in process python pfn:63a00b
[ +0.000001] page:fffff8a2d8e802c0 refcount:-1 mapcount:-2 mapping:0000000000000000 index:0x0
[ +0.000000] raw: 02ffff0000000000 dead000000000100 dead000000000122 0000000000000000
[ +0.000001] raw: 0000000000000000 0000000000000000 fffffffffffffffd 0000000000000000
[ +0.000001] page dumped because: nonzero _refcount
[ +0.000015] scsi_mod
[ +0.000002] load_elf_binary+0x33d/0x1710
[ +0.000350] BUG: Bad rss-counter state mm:0000000057c7de3b type:MM_FILEPAGES val:-8
[ +0.000001] BUG: Bad rss-counter state mm:0000000057c7de3b type:MM_ANONPAGES val:8
[Dec21 00:25] BUG: Bad page map in process kwin_x11 pte:800000063a00e06f pmd:6246c9067
[ +0.000001] page:fffff8a2d8e80380 refcount:1 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000001] flags: 0x2ffff000040000a(referenced|dirty|uncached)
[ +0.000002] raw: 02ffff000040000a dead000000000100 dead000000000122 0000000000000000
[ +0.000000] raw: 0000000000000000 0000000000000000 00000001fffffffe 0000000000000000
[ +0.000001] addr:00007f9536d27000 vm_flags:140440fb anon_vma:0000000000000000 mapping:ffff95fa22183da0 index:128
[ +0.000135] file:nvidiactl fault:nvidia_fault [nvidia] mmap:nvidia_frontend_mmap [nvidia] readpage:0x0
[ +0.000001] CPU: 0 PID: 1282 Comm: kwin_x11 Tainted: P B OE 5.4.80-2-MANJARO #1
[ +0.000005] dump_stack+0x64/0x88
[ +0.000002] print_bad_pte.cold+0x95/0xbf
[ +0.000061] ? _nv039042rm+0xa1/0x190 [nvidia]
[ +0.000001] unmap_region+0xc2/0x130
[ +0.000001] __do_munmap+0x267/0x4f0
[ +0.000001] __vm_munmap+0x67/0xb0
[ +0.000001] __x64_sys_munmap+0x28/0x30
[ +0.000001] RIP: 0033:0x7f95f981bf9b
[ +0.000001] Code: 8b 15 d9 6e 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb 89 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa b8 0b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d a5 6e 0c 00 f7 d8 64 89 01 48
[ +0.000001] RSP: 002b:00007fffb6884038 EFLAGS: 00000246 ORIG_RAX: 000000000000000b
[ +0.000000] RAX: ffffffffffffffda RBX: 00005564b9f37140 RCX: 00007f95f981bf9b
[ +0.000001] RDX: 00007f95f98ab354 RSI: 0000000000400000 RDI: 00007f9536bff000
[ +0.000000] RBP: 00007f9536bff000 R08: 00007fffb6884060 R09: 00007fffb6884078
[ +0.000000] R10: 00000000c1d00017 R11: 0000000000000246 R12: 00000000c1d00017
[ +0.000000] R13: 00000000beef0004 R14: 00005564b9468290 R15: 0000000000000000
[ +0.000244] BUG: Bad page state in process kwin_x11 pfn:63a00e
[ +0.000001] page:fffff8a2d8e80380 refcount:0 mapcount:-1 mapping:0000000000000000 index:0x0
[ +0.000000] flags: 0x2ffff0000000000()
[ +0.000024] scsi_mod
[ +0.000001] free_unref_page+0xa2/0xb0
[ +0.000059] nv_free_system_pages+0xff/0x270 [nvidia]
[ +0.000059] nv_free_pages+0x7c/0x80 [nvidia]
[ +0.000067] _nv032025rm+0x81/0xf0 [nvidia]
[ +0.000125] ? _nv027848rm+0x3b0/0x4b0 [nvidia]
[ +0.000087] ? _nv027824rm+0x26b/0x8d0 [nvidia]
[ +0.000078] ? _nv002768rm+0x9/0x20 [nvidia]
[ +0.000074] ? _nv003460rm+0x1b/0x80 [nvidia]
[ +0.000073] ? _nv011670rm+0x6d2/0x720 [nvidia]
[ +0.000072] ? _nv036870rm+0xb5/0x130 [nvidia]
[ +0.000072] ? _nv036869rm+0x348/0x4a0 [nvidia]
[ +0.000089] ? _nv035440rm+0xc7/0x170 [nvidia]
[ +0.000086] ? _nv035441rm+0x42/0x70 [nvidia]
[ +0.000087] ? _nv007652rm+0x4b/0x90 [nvidia]
[ +0.000066] ? _nv000710rm+0x4ef/0x880 [nvidia]
[ +0.000002] ? _raw_spin_unlock_irqrestore+0x20/0x40
[ +0.000063] ? rm_ioctl+0x54/0xb0 [nvidia]
[ +0.000057] ? nvidia_ioctl+0x10/0x900 [nvidia]
[ +0.000058] ? nvidia_ioctl+0x5b7/0x900 [nvidia]
[ +0.000057] ? nvidia_frontend_unlocked_ioctl+0x37/0x50 [nvidia]
[ +0.000001] ? do_vfs_ioctl+0x3eb/0x6c0
[ +0.000001] ? ksys_ioctl+0x5e/0x90
[ +0.000001] ? __x64_sys_ioctl+0x16/0x20
[ +0.000001] ? do_syscall_64+0x49/0x90
[ +0.000001] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ +0.000036] NVRM: VM: nv_free_system_pages: page count != initial page count (0,1)
[ +27.521237] ThreadPoolForeg[7280]: segfault at 87c ip 000055b7ae13f332 sp 00007f1d57bd4360 error 4 in code[55b7acc94000+57ee000]
[ +0.000018] Code: 4c 21 f3 48 09 d3 49 89 dc 49 81 e4 00 00 fc ff 89 d1 c0 e9 02 be 01 00 00 00 d3 e6 4d 8b 44 24 10 c1 ea 07 81 e2 ff 07 00 00 <41> 8b 04 90 89 c1 21 f1 39 f1 0f 85 ca 00 00 00 49 8b 44 24 08 a8
[ +0.000032] audit: type=1701 audit(1608528350.146:97): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=2954 comm="ThreadPoolForeg" exe="/opt/visual-studio-code/code" sig=11 res=1
[ +0.010720] audit: type=1130 audit(1608528350.156:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-7798-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[ +1.940910] audit: type=1131 audit(1608528352.099:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-7798-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
[Dec21 00:29] input: Obsidian (AVRCP) as /devices/virtual/input/input28
[Dec21 00:33] audit: type=1100 audit(1608528803.241:100): pid=8307 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="toshi" exe="/usr/bin/sudo" hostname=? addr=? te>
[ +0.000626] audit: type=1101 audit(1608528803.241:101): pid=8307 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="toshi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res>
[ +0.000156] audit: type=1110 audit(1608528803.244:102): pid=8307 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
[ +0.002500] audit: type=1105 audit(1608528803.244:103): pid=8307 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/>
[ +22.495166] audit: type=1106 audit(1608528825.741:104): pid=8307 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
[ +0.000092] audit: type=1104 audit(1608528825.741:105): pid=8307 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
[ +1.838862] audit: type=1101 audit(1608528827.581:106): pid=8317 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="toshi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res>
[ +0.000207] audit: type=1110 audit(1608528827.581:107): pid=8317 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? termi>
[ +0.002051] audit: type=1105 audit(1608528827.581:108): pid=8317 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/>
[ +0.015268] audit: type=1106 audit(1608528827.597:109): pid=8317 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
[ +0.000088] audit: type=1104 audit(1608528827.597:110): pid=8317 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? termi>
[Dec21 00:34] audit: type=1101 audit(1608528868.887:111): pid=8327 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="toshi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res>
[ +0.000145] audit: type=1110 audit(1608528868.887:112): pid=8327 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? termi>
[ +0.001874] audit: type=1105 audit(1608528868.891:113): pid=8327 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/>
[ +0.005187] audit: type=1106 audit(1608528868.894:114): pid=8327 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev>
[ +0.000042] audit: type=1104 audit(1608528868.894:115): pid=8327 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? termi>
inxi -Faz
System: Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=ea7605c0-b50c-450a-9352-4eb157326167 rw quiet apparmor=1
security=apparmor resume=UUID=e2bf2cd5-6f9a-461f-aece-916853371e98 udev.log_priority=3 idle=nomwait nomodeset
nouveau.modeset=0
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.D1 date: 11/13/2020
CPU: Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25) model-id: 21 (33)
stepping: N/A microcode: A201009 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121633
Speed: 2056 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2303 2: 2105 3: 2055 4: 2057 5: 2055
6: 2056 7: 2051 8: 3582 9: 2055 10: 2055 11: 2055 12: 2057 13: 2056 14: 3596 15: 2372 16: 3576
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 2d:00.0 chip ID: 10de:2204
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7") s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: GeForce RTX 3090/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 2d:00.1 chip ID: 10de:1aef
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 2f:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.4.80-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI X570-A PRO driver: r8169
v: kernel port: d000 bus ID: 27:00.0 chip ID: 10ec:8168
IF: enp39s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: d000 bus ID: 29:00.0
chip ID: 8086:24fb
IF: wlp41s0 state: up mac: <filter>
Drives: Local Storage: total: 2.27 TiB used: 431.41 GiB (18.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0 size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 111110WD scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST32000644NS size: 1.82 TiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: KA06 scheme: GPT
Partition: ID-1: / raw size: 430.99 GiB size: 423.22 GiB (98.20%) used: 61.68 GiB (14.6%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 34.48 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 0.0 C mobo: N/A gpu: nvidia temp: 40 C
Info: Processes: 354 Uptime: 1h 36m Memory: 31.35 GiB used: 4.70 GiB (15.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1392 lib: 360 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.08
journalctl didn’t seem to reflect anything related.
