When trying to upgrade my system with: sudo pacman -Syu
I am not able to because of the error: installing clang (15.0.7-2) breaks dependency 'clange<15.0' required by include-what-you-use
If I try to update include-what-you-use with yay, I run into the same problem, but then it also says: installing clang (15.0.7-2) breaks dependency 'clange=14.0.6' required by shiboken6
Any ideas on things to try to perform a system update and skip these packages (or to remedy this problem somehow)?
Unfortunately, the browser on my machine isn’t working so I can’t post system info. I’m hoping that a system update would fix this problem
The best thing to do right now is temporarily removing include-what-you-use, update your system packages, reboot then worry about AUR packages later. Maybe IWYU 0.20 is compatible with Clang >=15, but you’ll have to wait until the AUR package maintainer updates it.
