Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a73e276e-c6af-48b4-b7ca-dd7c73fdade5 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: NBLB-WAX9N v: M1070
serial: <superuser required>
Mobo: HUAWEI model: NBLB-WAX9N-PCB-B2 v: M1070
serial: <superuser required> UEFI: HUAWEI v: 1.35 date: 06/23/2021
ID-1: BAT1 charge: 29.6 Wh (52.4%) condition: 56.5/55.3 Wh (102.1%)
volts: 15.4 min: 15.3 model: Sunwoda-H HB4692Z9ECW-41 type: Li-ion
serial: <filter> status: Discharging cycles: 1
RAM: total: 7.51 GiB used: 2.19 GiB (29.1%)
RAM Report:
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 918 high: 1000 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 946 8: 1000 bogomips: 33615
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: QUANTA driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Quanta HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 0408:1042 class-ID: fe01 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 506.24 GiB used: 8.79 GiB (1.7%)
model: PC SN530 SDBPNPZ-512G size: 476.94 GiB block-size: physical: 512 B
rev: 21117000 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Intenso model: Ultra Line
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.01 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 8.79 GiB (1.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a73e276e-c6af-48b4-b7ca-dd7c73fdade5
label: NO_LABEL uuid: 595B-2C24
ID-1: /dev/sda1 maj-min: 8:1 size: 3.56 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8D59-F16D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Quanta HD Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:1042
Device-2: 1-10:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:2 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 800mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 38.0 C pch: 34.0 C mobo: N/A
Processes: 247 Uptime: 8m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1197 lib: 330 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
please let me know if i need to do anything else
