I am trying to use Oracle VM, and when I add a virtual machine I am not showing operating systems with 64-bit options
Thanks in advance if you can help me out
When I have encountered this, I did not have virtualization enabled in my BIOS. Have you checked that?
Make sure virtualization is turned on in your bios. Depending on your bios it may be called various things but you should look for Intel VT-x or AMD-v depending on your processor.
