I just did a fresh install with the “erase entire disk” option. There’s only my new manjaro installation and when I reboot the ThinkPad T540p, it won’t load GRUB and appears to be going to network boot. I checked my boot order and the HDD is definitely first.
I was able to get the following info from a terminal by using the Live USB:
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2116 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20BFS02H00 v: ThinkPad T540p serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20BFS02H00 serial: <filter> UEFI-[Legacy]: LENOVO v: GMET87WW (2.35 ) date: 03/20/2019
Battery: ID-1: BAT0 charge: 74.3 Wh (100.0%) condition: 74.3/99.5 Wh (74.7%) volts: 12.8 min: 11.1 model: LGC 45N1153
type: Li-ion serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i5-4300M bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 20760
Speed: 798 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 798 2: 798 3: 1192 4: 2596
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-12:5 chip-ID: 04f2:b39a class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel port: 4080 bus-ID: 00:19.0
chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:08b2 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-11:4 chip-ID: 8087:07dc
class-ID: e001
Drives: Local Storage: total: 502.94 GiB used: 0 KiB (0.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SC32G size: 29.72 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT015-1DJ142 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM7 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Edge size: 7.45 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.26 scheme: MBR
Partition: Message: No partition data found.
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2074
Info: Processes: 231 Uptime: 2m wakeups: 2 Memory: 7.46 GiB used: 2.18 GiB (29.3%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1234 lib: 333 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.07
Model: ATA ST500LT015-1DJ14 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 500GB 500GB primary ext4 boot
Model: SanDisk Cruzer Edge (scsi)
Disk /dev/sdb: 8004MB
Disk Flags:
2 3475MB 3479MB 4194kB primary esp
Model: SD SC32G (sd/mmc)
Disk /dev/mmcblk0: 31.9GB
Disk Flags:
1 4194kB 31.9GB 31.9GB primary fat32 lba
EFI variables are not supported on this system.
bios
