Impossible to pair any bluetooth device
Hello here.
I made a fresh Manjaro installation, and since I cannot detect any bt device (though, I could detect it on the same PC with the previous installation.
Some insights below :
    ~  inxi --admin --verbosity=7 --filter --no-host --width         ✔  1m 1s 
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7104311a-d4cd-429a-b33e-fb821fbddc80 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop System: LENOVO product: 30BFS1C300 v: ThinkStation P520
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: LENOVO model: 1036 v: SDK0Q40112 WIN 3305668464318
    part-nu: LENOVO_MT_30BF_BU_Think_FM_ThinkStation P520
    uuid: <superuser required> UEFI: LENOVO v: S03KT58A date: 03/01/2023
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.21 GiB used: 2.72 GiB (17.8%)
  Array-1: capacity: 3 TiB note: check slots: 8 modules: 1 EC: Single-bit ECC
    max-module-size: 384 GiB note: est.
  Device-1: CPU1_DIMM_1 type: no module installed
  Device-2: CPU1_DIMM_2 type: no module installed
  Device-3: CPU1_DIMM_3 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 72 manufacturer: Samsung part-no: M393A2K43BB1-CTD
    serial: <filter>
  Device-4: CPU1_DIMM_4 type: no module installed
  Device-5: CPU1_DIMM_5 type: no module installed
  Device-6: CPU1_DIMM_6 type: no module installed
  Device-7: CPU1_DIMM_7 type: no module installed
  Device-8: CPU1_DIMM_8 type: no module installed
  Info: model: Intel Xeon W-2125 bits: 64 type: MT MCP arch: Skylake level: v4
    note: check process: Intel 14nm family: 6 model-id: 0x55 (85) stepping: 4
    microcode: 0x2007006
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 4 MiB
    desc: 4x1024 KiB L3: 8.2 MiB desc: 1x8.2 MiB
  Speed (MHz): avg: 1200 min/max: 1200/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
    7: 1200 8: 1200 bogomips: 64026
    arch_capabilities arch_perfmon art avx avx2 avx512bw avx512cd avx512dq
    avx512f avx512vl bmi1 bmi2 bts cat_l3 cdp_l3 clflush clflushopt clwb cmov
    constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total
    cqm_occup_llc cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
    hwp_act_window hwp_epp hwp_pkg_req ibpb ibrs ida intel_ppin intel_pt
    invpcid lahf_lm lm mba mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdt_a rdtscp rep_good rtm sdbg
    sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
    vulnerable
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA GP106GL [Quadro P2000] driver: nvidia v: 550.135
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
    2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
    off: DP-4 empty: DP-1,DP-2,DP-3 bus-ID: 65:00.0 chip-ID: 10de:1c30
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1080 s-dpi: 81 s-size: 803x343mm (31.61x13.50")
    s-diag: 873mm (34.38") monitors: <missing: xrandr>
  Monitor-1: DP-4 size-res: N/A modes: N/A
  Monitor-2: Unknown-1 size-res: N/A modes: 2560x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: Quadro P2000/PCIe/SSE2
    memory: 4.88 GiB
  API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
    name: Quadro P2000 driver: nvidia v: 550.135 device-ID: 10de:1c30
    surfaces: xcb,xlib
  Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 65:00.1
    chip-ID: 10de:10f1 class-ID: 0403
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  Device-2: TP-Link Archer T4U ver.3 driver: rtl88x2bu type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:6 chip-ID: 2357:0115
    class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u14 state: up mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 2357:0604
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 2.16 TiB used: 66.63 GiB (3.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L7
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1L2QEXD7 temp: 22.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC63 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD-RAM GHC0N rev: MA02
    dev-links: cdrom
  Features: speed: 8 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 66.63 GiB (7.3%)
    fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 7104311a-d4cd-429a-b33e-fb821fbddc80
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: FA66-1AE3
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 64FF-2A4D
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 73.48 GiB fs: ntfs label: N/A
    uuid: 1AD30004D2FFE245
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 657 MiB fs: ntfs label: N/A
    uuid: BC8C88B18C88682A
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 163.74 GiB fs: ext4 label: N/A
    uuid: e33fb4b5-f867-4a55-ba5e-bae052f838e4
  ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 510 MiB fs: vfat
    label: NEW VOLUME uuid: 4A7E-590D
  ID-7: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: exfat label: N/A
    uuid: 7DFF-E661
  ID-8: /dev/sdc1 maj-min: 8:33 size: 3.71 GiB fs: iso9660
  ID-9: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 2983-4F90
  Device-1: 1-5:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-7:3 info: Elan Micro ActiveJet K-2024 Multimedia Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 04f3:0103 class-ID: 0300
  Device-3: 1-8:4 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Device-4: 1-13:5 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-5: 1-14:6 info: TP-Link Archer T4U ver.3 type: Network
    driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 2357:0115 class-ID: 0000
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Device-1: 2-7:2 info: SanDisk Ultra Flair type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 46 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 52%
  Processes: 282 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.07 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1238 libs: 346 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
The BT service is running (though it says some plugin aren’t available) :
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Sun 2024-12-15 14:30:50 CET; 19min ago
 Invocation: 51dc359eb03347bbb86f79de34069dba
       Docs: man:bluetoothd(8)
   Main PID: 571 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18497)
     Memory: 2.1M (peak: 2.3M)
        CPU: 63ms
     CGroup: /system.slice/bluetooth.service
             └─571 /usr/lib/bluetooth/bluetoothd
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support bap plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support bass plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support mcp plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support vcp plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support micp plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support ccp plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support csip plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: src/plugin.c:init_plugin() System does not support asha plugin
déc. 15 14:30:50 lothlorien bluetoothd[571]: Bluetooth management interface 1.23 initialized
Rfkill says BT is not blocked :
0: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
I’ve crunched many threads but could not find any usable answer… Any idea ?
Hi @valinatar,
Please see Bluetoothd errors - how to fix them? - #2 by xabbu
just a guess:
There was recently an issue with missing firmware in the released ISO’s - perhaps you used one of these to install?
It looks like it can be remedied by installing that package explicitly:
sudo pacman-mirrors -f
sudo pacman -Syu linux-firmware
Manjaro 24.2 Yonada released - #13 by philm
Hello Nachlese,
Thank you for the answer. I will try this this afternoon :slight_smile:
That was it ! Thank you :slight_smile: It works now…
