Impossible de charger le noyau
J'obtiens:
[manjaro@manjaro ~]$ manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/sda1]
 --> mount: [/mnt]
[manjaro /]# inxi -Fxxxza
12System:    12Host manjaro 12Kernel 5.4.6-2-MANJARO x86_64 12bits 64 12compiler gcc 12v 9.2.0
           12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free
           nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro
           misolabel=MJRO1815 quiet systemd.show_status=1
           12Desktop Xfce 12info xfce4-panel 12wm xfwm4 12dm N/A 12Distro Manjaro Linux
12Machine:   12Type Laptop 12System Dell 12product Latitude E5530 non-vPro 12v 01 12serial <filter> 12Chassis
           12type 9 12serial <filter>
           12Mobo Dell 12model 05GRXT 12v A00 12serial <filter> 12BIOS Dell 12v A16 12date 08/19/2015
12Battery:   12ID-1 BAT0 12charge 11.9 Wh 12condition 40.7/99.9 Wh (41%) 12volts 11.2/11.1
           12model SMP DELL P6YD623 12type Li-ion 12serial <filter> 12status Discharging
12CPU:       12Topology Dual Core 12model Intel Core i3-3120M 12bits 64 12type MT MCP 12arch Ivy Bridge
           12family 6 12model-id 3A (58) 12stepping 9 12microcode 21 12L1 cache 128 KiB 12L2 cache 3072 KiB
           12L3 cache 3072 KiB
           12flags avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx 12bogomips 19940
           12Speed 1196 MHz 12min/max 1200/2500 MHz 12Core speeds (MHz) 121 1196 122 1196 123 1196 124 1196
           12Vulnerabilities 12Type itlb_multihit 12status KVM: Split huge pages
           12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
           12Type meltdown 12mitigation PTI
           12Type spec_store_bypass
           12mitigation Speculative Store Bypass disabled via prctl and seccomp
           12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
           12Type spectre_v2 12mitigation Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling
           12Type tsx_async_abort 12status Not affected
12Graphics:  12Device-1 Intel 3rd Gen Core processor Graphics 12vendor Dell 12driver i915 12v kernel
           12bus ID 00:02.0 12chip ID 8086:0166
           12Display 12server X.org 1.20.6 12driver intel 12unloaded modesetting 12alternate fbdev,vesa
           12resolution <xdpyinfo missing>
           12Message Advanced graphics data unavailable for root.
12Audio:     12Device-1 Intel 7 Series/C216 Family High Definition Audio 12vendor Dell
           12driver snd_hda_intel 12v kernel 12bus ID 00:1b.0 12chip ID 8086:1e20
           12Sound Server ALSA 12v k5.4.6-2-MANJARO
12Network:   12Device-1 Intel Centrino Ultimate-N 6300 12driver iwlwifi 12v kernel 12port f040
           12bus ID 02:00.0 12chip ID 8086:422b
           12IF wlp2s0 12state up 12mac <filter>
           12Device-2 Broadcom and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe 12vendor Dell
           12driver tg3 12v 3.137 12port f040 12bus ID 0c:00.0 12chip ID 14e4:1681
           12IF enp12s0 12state down 12mac <filter>
12Drives:    12Local Storage 12total 301.83 GiB 12used 28.25 GiB (9.4%)
           12ID-1 /dev/sda 12vendor HGST (Hitachi) 12model HTS545032A7E680 12size 298.09 GiB 12block size
           12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12serial <filter> 12rev AF60
           12ID-2 /dev/sdb 12type USB 12vendor DaneElec 12model USB Disk 12size 3.73 GiB 12block size
           12physical 512 B 12logical 512 B 12serial <filter> 12rev PMAP
12RAID:      12Hardware-1 Intel 82801 Mobile SATA Controller [RAID mode] 12driver ahci 12v 3.0 12port f060
           12bus ID 00:1f.2 12chip ID 8086.282a 12rev 04
12Partition: 12ID-1 / 12raw size 298.09 GiB 12size 292.41 GiB (98.09%) 12used 28.13 GiB (9.6%) 12fs ext4
           12block size 4096 B 12dev /dev/sda1
12Sensors:   12System Temperatures 12cpu 50.0 C 12mobo 40.0 C 12sodimm 37.0 C
           12Fan Speeds (RPM) 12cpu 0
12Info:      12Processes 210 12Uptime 2h 24m 12Memory 3.75 GiB 12used 1.29 GiB (34.3%) 12Init systemd 12v 242
           12Compilers 12gcc 9.2.0 12clang 9.0.0 12Client Unknown Client: systemd 12inxi 3.0.37
[manjaro /]# parted -l
Model: ATA HGST HTS545032A7 (scsi)
Disk /dev/sda: 320GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  320GB  320GB  primary  ext4         boot
Model: DaneElec USB Disk (scsi)
Disk /dev/sdb: 4010MB
Disk Flags:
 2      2675MB  2679MB  4194kB  primary               esp
[manjaro /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=e03075ed-da71-4692-9e59-0bf0b527700f /              ext4    defaults,noatime 0 1
[manjaro /]# exit
exit
 --> umount: [/mnt]
tu va essayé ceci
à la 1ere erreur rencontré tu remonte le problème et tu quitte par exit
boot USB manjaro ( pas sur ton disque )
ouvre le terminal
manjaro-chroot -a
pacman-mirrors -c all
pacman -Syyu
pacman -S linux414 linux414-headers
pacman -S linux419 linux419-headers
pacman -S linux54 linux54-headers
grub-install --recheck /dev/sda
update-grub
mkinitcpio -P
exit
Vous êtes sûr que pour grub-update c'est pas update-grub?
Car j'ai eu, pour grub-update:
bash: grub-update: command not found
oui erreur de ma part c'est update-grub
Alors, ça a marché, sauf une petite erreur qu'il me semble sans importance, ou pas puisque ça ne fonctionne pas vraiment.
 --> mount: [/mnt]
[manjaro /]# pacman-mirrors -c all
::WARNING https://gitlab.manjaro.org '<urlopen error _ssl.c:1091: The handshake operation timed out>'
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.382 Austria        : http://mirror.easyname.at/manjaro/
  0.853 Austria        : ftp://mirror.easyname.at/manjaro/
  2.425 Brazil         : https://manjaro.c3sl.ufpr.br/
  1.885 Brazil         : https://www.caco.ic.unicamp.br/manjaro/
  0.466 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  ..... Bulgaria       : http://manjaro.telecoms.bg/
  ..... Chile          : https://mirror.ufro.cl/manjaro/
::ERROR TIMEOUT 'https://mirror.ufro.cl/manjaro/'
  1.992 Ecuador        : http://mirror.espoch.edu.ec/manjaro/
  2.944 France         : https://manjaro.ynh.ovh/
  0.297 France         : http://kibo.remi.lu/
  0.480 Germany        : https://mirror.alpix.eu/manjaro/
  0.453 Germany        : https://mirror.23media.com/manjaro/
  0.243 Germany        : http://mirror.23media.com/manjaro/
  0.348 Germany        : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.593 Germany        : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.375 Germany        : https://mirror.netzspielplatz.de/manjaro/packages/
  1.238 Germany        : https://manjaro.moson.eu/
  0.417 Germany        : http://manjaro.moson.eu/
  0.770 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.969 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  2.524 Hungary        : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  ..... Hungary        : http://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  1.823 Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  ..... New_Zealand    : http://manjaro.mirrors.theom.nz/
  ..... Poland         : https://mirror.tuchola-dc.pl/manjaro/
  0.641 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.427 Spain          : http://ftp.caliu.cat/pub/distribucions/manjaro/
  0.587 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.812 Sweden         : ftp://ftp.lysator.liu.se/pub/manjaro/
  0.586 Sweden         : https://mirror.zetup.net/manjaro/
  0.795 Ukraine        : http://mirrors.colocall.net/manjaro/
  ..... Ukraine        : ftp://mirrors.colocall.net/manjaro/
::ERROR TIMEOUT 'ftp://mirrors.colocall.net/manjaro/'
  ..... United_Kingdom : http://mirror.catn.com/pub/manjaro/
::ERROR timed out 'http://mirror.catn.com/pub/manjaro/'
  ..... United_Kingdom : http://repo.manjaro.org.uk/
  1.899 United_Kingdom : http://manjaro.mirrors.uk2.net/
  1.447 United_States  : https://repo.ialab.dsu.edu/manjaro/
  0.808 United_States  : http://repo.ialab.dsu.edu/manjaro/
  ..... United_States  : https://mirror.math.princeton.edu/pub/manjaro/
::ERROR timed out 'https://mirror.math.princeton.edu/pub/manjaro/'
::INFO Writing mirror list
::Germany         : https://mirror.23media.com/manjaro/stable
::France          : http://kibo.remi.lu/stable
::Germany         : https://mirror.netzspielplatz.de/manjaro/packages/stable
::Germany         : https://manjaro.moson.eu/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Sweden          : https://mirror.zetup.net/manjaro/stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::Austria         : http://mirror.easyname.at/manjaro/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Brazil          : https://www.caco.ic.unicamp.br/manjaro/stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable
::Ecuador         : http://mirror.espoch.edu.ec/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::France          : https://manjaro.ynh.ovh/stable
::Hungary         : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/stable
::Bulgaria        : http://manjaro.telecoms.bg/stable
::Poland          : https://mirror.tuchola-dc.pl/manjaro/stable
::United_Kingdom  : http://repo.manjaro.org.uk/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[manjaro /]# pacman -Syyu
 core                  151.4 KiB  35.5 KiB/s 00:04 [######################] 100%
 extra                1780.8 KiB   973 KiB/s 00:02 [######################] 100%
 community               5.2 MiB   739 KiB/s 00:07 [######################] 100%
 multilib              176.2 KiB  1325 KiB/s 00:00 [######################] 100%
warning: fontconfig: local (2:2.13.1+12+g5f5ec56-2) is newer than extra (2:2.13.1+12+g5f5ec56-1)
 there is nothing to do
[manjaro /]# pacman -S linux414 linux414-headers
resolving dependencies...
Packages (2) linux414-4.14.160-1  linux414-headers-4.14.160-1
Total Download Size:    69.08 MiB
Total Installed Size:  143.20 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
error: failed retrieving file 'linux414-4.14.160-1-x86_64.pkg.tar.xz' from mirror.23media.com : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
 linux414-4.14.16...     2.8 MiB  1132 KiB/s 00:03 [######################] 100%
 linux414-headers...     7.9 MiB   281 KiB/s 00:29 [######################] 100%
(2/2) checking keys in keyring                     [######################] 100%
(2/2) checking package integrity                   [######################] 100%
(2/2) loading package files                        [######################] 100%
(2/2) checking for file conflicts                  [######################] 100%
(2/2) checking available disk space                [######################] 100%
(1/2) installing linux414                          [######################] 100%
Optional dependencies for linux414
    crda: to set the correct wireless channels of your country [installed]
(2/2) installing linux414-headers                  [######################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
  -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
==> Starting build: 4.14.160-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
  -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
(4/4) Updating Grub-Bootmenu
Found background: /usr/share/grub/background.png
Found linux image: /boot/vmlinuz-4.14-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
[manjaro /]# pacman -S linux419 linux419-headers
Packages (2) linux419-4.19.91-1  linux419-headers-4.19.91-1
Total Download Size:    82.01 MiB
Total Installed Size:  165.28 MiB
 linux419-4.19.91...    73.2 MiB   378 KiB/s 03:19 [######################] 100%
 linux419-headers...     8.8 MiB   723 KiB/s 00:12 [######################] 100%
(1/2) installing linux419                          [######################] 100%
Optional dependencies for linux419
(2/2) installing linux419-headers                  [######################] 100%
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.91-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
done
[manjaro /]# pacman -S linux54 linux54-headers
Packages (2) linux54-5.4.6-2  linux54-headers-5.4.6-2
Total Download Size:    89.68 MiB
Total Installed Size:  186.38 MiB
 linux54-5.4.6-2-...    80.3 MiB   650 KiB/s 02:07 [######################] 100%
 linux54-headers-...     9.4 MiB   731 KiB/s 00:13 [######################] 100%
(1/2) installing linux54                           [######################] 100%
Optional dependencies for linux54
(2/2) installing linux54-headers                   [######################] 100%
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.6-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
done
[manjaro /]# grub-install --recheck /dev/sda
Installing for i386-pc platform.
Installation finished. No error reported.
[manjaro /]# grub-update
[manjaro /]# update-grub
done
[manjaro /]# mkinitcpio -P
[manjaro /]# exit
exit
 --> umount: [/mnt]
Comme vous pouvez-le voir c'est ça l'erreur "grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map."; je ne sais pas si c'est important, et si c'est le cas, je ne sais pas quoi faire.
J'ai testé tous les noyaux (sauf où il y avait marqué à côté "- fallback initramfs") et j'ai toujours la même chose (sauf pour 414 où c'est un peu différent). Je vous explique, j'ai un écran noir (là où habituellement, j'avais juste l'erreur), où rien ne se passe avec le logo de manjaro en bas à droite et aucune touche ne répond. Pour le 414, il y a du texte qui est écrit au début puis qui s'arrête ensuite et, égalment plus rien ne répond (mon ordinateur ne tourne pas car sinon un voyant s'allumerait, indiquant que le CPU tourne). J'ai indiqué un petit peu, mais ne voyant rien se passer j'ai décidé d'arrêter, je peux réessayer pour voir si quelque chose se passe, mais j'ai des doutes et je ne sais donc pas quoi faire.
pour le cas /dev/sdb1 cela concerne la clé USB donc pas de souci
essaye avec le fallback dans ce cas
et tu pourra ler voir la log du boot précédent
sudo journalctl -b -1 -p4   ( -b -1 , demarrage precedent , -b -2 démarrages précédents, etc .. )
Ça ne fonctionne pas non plus avec les fallback (pas de changement que pour les noyaux sans fallback). Et du coup je ne peux taper la commande (car sur le live, j'obtiens: Specifying boot ID or boot offset has no effect, no persistent journal was found. ).
on aura tout essayé ,
tu vas devoir tout réinstaller
pense a sauvegarder les données personnels et liste des paquets installés
je ne vois pas d'autre solution
Ok, comment je peux sauvegarder mes données? Et, avant de réinstaller, il vaut mieux que je désinstalle les noyaux comme on avait fait avant?
Dernière question, j'ai fait le live USB à partir de Etcher, est-ce vous savez si il y a une vérification de l'image disque à faire (car Etcher vérifiait à la fin, mais je ne sais pas si ça correspond à la même chose)?
  1. tu recopie les paquets dans ton /home ( par chroot )
sudo pacman -Qen > /home/<user>/pkglist-repo.txt
sudo pacman -Qem > /home/<user>/pkglist-aur.txt
puis tu recopie tout le /home/ sur une autre partition disque
si tu as un /home séparé , alors tu peux tenter de réinstaller uniquement
le / à partir de la clé manjaro USB ( ne pas formater /home ) et utiliser le meme login
  1. pour iso , j'utilise isousb qui effectue une copie par dd sur la clé USB ,pour Etcher pas de souci cela se passe bien à ce jour
ps : on a un forum français
https://www.manjaro.fr/forum/index.php
Je ne sais pas comment on peut recopier le /home/ sur autre partition disque. Et si j'ai bien compris, une fois que j'ai recopier le /home/, je peux directement passer à l'installation (sans vérification supplémentaire ou sans supprimer de noyau)?
Et, je l'avais vu le forum (quand je cherchais une solution), mais vu qu'ils disaient que c'était "non-officiel", je ne m'y suis pas intéressé.
alors tu as 3 possibilités pour copier
timeshift
rsync
clonezilla
pour la partie ré-installation , c'est particulier , il faut dans calamarès indiquer une installation / uniquement et avec le point de montage /home , dans cas seul le systeme est réinstallé
le forum est dit "non officiel" cad qu'il n'y a pas de developpeurs de l'equipe Manjaro , mais reste utile
Cela veut dire qu'il faut deux partitions, une en point de montage / et l'autre en /home?
2 ou 3
cas bios / et /home
cas EFI /boot/efi / et /home
Et ainsi l'installation se fera automatique en /home, sans configuration particulière?
Ah, Est-ce qu'il ne faut pas deux partitions de base?
oui car dans ce cas il ne modifie pas les donnes de /home
d'où l'intérêt d'une partition dédié et sauvegarde
Est-ce qu'en faisant les deux maintenant ça peut fonctionner où alors je peux oublier?
Parce que, du coup j'aurais copier mes fichiers (et tenter de les garder) pour rien.
Ok, je crois que je viens de comprendre, je ne peux pas garder mes fichiers.
Bon, bah, j'applique le même modèle que dans le guide.
ne jamais negliger une sauvegarde avant la moindre re-installation
si tu souhaite avoir une partition /home/dedié tu va devoir modifier les tailles et les formatter ,
donc perte des données
la sauvegarde est imperative
Vous parlez d'une sauvegarde externe? Car je ne suis pas sûr d'avoir un stockage suffisant pour.
Est-ce que vous voulez dire que si je garde le format de base, je pourrait garder mes fichiers?
Après, il y une option "conserver", mais je ne sais pas exactement comment ça marche.
Bon, je ne sais pas si j'ai bien compris, mais si c'est le cas, j'ai bien créer deux partitions une / et une /home et je vais lancer l'installation.
Bon bah, j'ai essayé de réinstaller, mais, la première fois, j'installe, je redémarre, et, il y a eu erreur et ne répondais plus. Du coup, décide de re-réinstaller et j'ai juste une image noir. Je vais essayer de vérifier l'image disque, peut-être en formatant les partitions. Je ne comprends pas, comment ça peut ne pas marcher. A ce niveau-là, je serai content, si je pouvais juste utiliser le système d'exploitation.
La vérification de l'image disque s'est bien passée (il n'y pas eu d'erreur), donc je ne comprends pas pourquoi ça ne marche toujours pas.
Je vais tenter d'installer en supprimant ce qui a déjà.
Bon, c'est bon, je peux enfin utiliser le système d'exploitation, mais j'ai dû tout supprimer pour que ça fonctionne.
Merci de ton aide! :slight_smile:
