Imagewriter program fails to open
There is a package I have used called “imagewriter” that has been installed on my Manjaro Gnome for several years. I tried to use it to make a USB installer, but now run into this problem:
[dmn@Sydney ~]$ imagewriter
Starting up...
Cannot mix incompatible Qt library (5.15.2) with this library (5.15.5)
Aborted (core dumped)
Is this fixable?
Version installed:
SUSE Studio Imagewriter 1.10
Written by Matt Barringer mbarringer@suse.de
How did you install imagewriter?
It was years ago, but It probably was from Manjaro Repository. I did test with:
[dmn@Sydney ~]$ sudo pacman -S imagewriter
warning: imagewriter-1.10.1432200249.1d253d9.2.13-1 is up to date -- reinstalling
and aborted any reinstall.
Nothing to do with imagewriter. You’re using an incompatible Qt style. If you have qt5-styleplugins installed, remove it.
OK, that fixed it. It now starts. Thanks for your help.
