I just installed a fresh copy of Manjaro on a new M.2 and everything is looking great so far. I’ve only run into one issue and that is in trying to install Rename My TV Series. rather it’s the QT or GTK version I get the same error. I’d just as soon fore it cause I know the creator and the AUR maintainer and know the files have not changed since my last install of it on ArcoLinuxB. Any suggestions or help with getting this fixed would be greatly appreciated. Thanks ion advance.
Preparing...
Cloning renamemytvseries-qt-bin build files...
Generating renamemytvseries-qt-bin information...
Checking renamemytvseries-qt-bin dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building renamemytvseries-qt-bin...
==> Making package: renamemytvseries-qt-bin 2.1.7-1 (Thu 21 Apr 2022 01:02:09 PM PDT)
==> Retrieving sources...
-> Found LICENSE
-> Found RenameMyTVSeries-2.1.7-QT5-b24-beta-Linux-64bit-shared-ffmpeg.tar.gz
-> Found RenameMyTVSeries.desktop
==> Validating source files with md5sums...
LICENSE ... Passed
RenameMyTVSeries-2.1.7-QT5-b24-beta-Linux-64bit-shared-ffmpeg.tar.gz ... FAILED
RenameMyTVSeries.desktop ... Passed
==> ERROR: One or more files did not pass the validity check!
Failed to build renamemytvseries-qt-bin
Host: Unimatrix-Zero Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.4 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4204
date: 01/28/2021
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 2652 min/max: 2200/4208 cores: 1: 3598 2: 3998 3: 2398
4: 2198 5: 2199 6: 2198 7: 2141 8: 3599 9: 2399 10: 2708 11: 2199 12: 2199
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] driver: nvidia v: 510.60.02
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver:
X: loaded: nvidia gpu: nvidia resolution: 2560x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.49 running: yes
Device-1: Intel I211 Gigabit Network driver: igb
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:55:75:ae
Local Storage: total: 20.7 TiB used: 11.52 TiB (55.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 500GB
ID-2: /dev/sda vendor: Samsung model: MZNTY128HDHP-000L1 size: 119.24 GiB
ID-3: /dev/sdb type: USB vendor: Seagate model: Expansion HDD
ID-4: /dev/sdc type: USB vendor: Seagate model: ST8000AS0002-1NA17Z
ID-5: /dev/sdd type: USB vendor: PNY model: USB 3.0 FD size: 115.38 GiB
ID-6: /dev/sde type: USB vendor: Seagate model: ST330006 51NS
ID-7: /dev/sdf type: USB vendor: Seagate model: ST3000DM 001-1E6166
ID-1: / size: 465.46 GiB used: 30.5 GiB (6.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 568 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 465.46 GiB used: 30.5 GiB (6.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 465.46 GiB used: 30.5 GiB (6.6%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 40.0 C mobo: 32.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): cpu: 1264 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 0%
Processes: 444 Uptime: 1h 6m Memory: 23.45 GiB used: 5.27 GiB (22.5%)
Shell: Zsh inxi: 3.3.15
