so i downloaded manjaros plasma desktop version 24.0 iso image and wanted to check the authenticity of the file and downloaded the .sig file from sourceforge but when i try to open the file it says that there was a problem opening the file
removed useless screenshot
im a total newbie so if you could tell me how to fix it in a more simple way i will be thankfull
nope im stupid and cant get it
i put everything in the temp folder i enter it run gpg --verify manjaro-kde-24.0-240513-linux69.iso.sig
gpg says no signed data
cant hash data file: no data
That they match, so the file is not corrupt
So you can happily install. I have to warn you though, manjaro is not the first choice for absolute beginners.
