Probably the IDs are changed somehow, so they fail to be recognized in the config files ?!?!
I donβt understand anything , but if I boot into the earliest snapshot from timeshift, on which the 515 driver is installed, only 1 monitor works there, most likely the configuration file needs to be edited or something similar, I can install manjaro and drop the files which ones are needed, and then update the drivers and upload the updated configuration files so that you can compare, but I donβt know which files are needed
The /etc/X11/mhwd.d/nvidia.conf
β¦ is all should matter. The default one is made to work implicit for all cases, then with special cases you alter it and keep it, and always use that.
kscreen
is a different story.
Maybe the logs will help Xorg.0.log
[ 5.450] (--) Log file renamed from "/var/log/Xorg.pid-670.log" to "/var/log/Xorg.0.log"
[ 5.451]
X.Org X Server 1.21.1.4
[ 5.451] Current Operating System: Linux rinky-ms7a37 5.15.81-1-MANJARO #1 SMP PREEMPT Fri Dec 2 21:02:26 UTC 2022 x86_64
[ 5.451] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=6ea82956-863f-4d76-b15b-f03130dbcfde rw rootflags=subvol=@ quiet resume=UUID=6c3cb512-24ea-44ba-80b0-7581dbe13f2b udev.log_priority=3
[ 5.451]
[ 5.451] Current version of pixman: 0.42.2
[ 5.451] Before reporting problems, check http://wiki.x.org
[ 5.451] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.451] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec 6 19:46:34 2022
[ 5.452] (==) Using config file: "/etc/X11/xorg.conf"
[ 5.452] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.452] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.453] (==) ServerLayout "layout"
[ 5.453] (**) |-->Screen "Screen0" (0)
[ 5.453] (**) | |-->Monitor "Monitor0"
[ 5.453] (**) | |-->Device "Card0"
[ 5.453] (**) | |-->GPUDevice "Card0"
[ 5.453] (==) Automatically adding devices
[ 5.453] (==) Automatically enabling devices
[ 5.453] (==) Automatically adding GPU devices
[ 5.453] (==) Automatically binding GPU devices
[ 5.453] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.455] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.455] Entry deleted from font path.
[ 5.455] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.455] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.455] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.455] (**) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
[ 5.455] (**) ModulePath set to "/usr/lib/xorg/modules"
[ 5.455] (II) The server relies on udev to provide the list of input devices.
[ 5.455] (II) Module ABI versions:
[ 5.455] X.Org ANSI C Emulation: 0.4
[ 5.455] X.Org Video Driver: 25.2
[ 5.455] X.Org XInput driver : 24.4
[ 5.455] X.Org Server Extension : 10.0
[ 5.456] (++) using VT number 1
[ 5.456] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.456] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.456] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:26:00.0/drm/card0
[ 5.459] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.459] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.462] (--) PCI:*(38@0:0:0) 10de:1f08:1458:3fc2 rev 161, Mem @ 0xfb000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 5.462] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.462] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 5.462] (II) LoadModule: "glx"
[ 5.463] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.469] (II) Module glx: vendor="X.Org Foundation"
[ 5.469] compiled for 1.21.1.4, module version = 1.0.0
[ 5.469] ABI class: X.Org Server Extension, version 10.0
[ 5.469] (II) LoadModule: "nvidia"
[ 5.469] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 5.476] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 5.476] compiled for 1.6.99.901, module version = 1.0.0
[ 5.476] Module class: X.Org Video Driver
[ 5.476] (II) NVIDIA dlloader X Driver 525.60.11 Wed Nov 23 22:56:57 UTC 2022
[ 5.476] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5.476] (II) Loading sub module "fb"
[ 5.476] (II) LoadModule: "fb"
[ 5.476] (II) Module "fb" already built-in
[ 5.476] (II) Loading sub module "wfb"
[ 5.476] (II) LoadModule: "wfb"
[ 5.477] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5.477] (II) Module wfb: vendor="X.Org Foundation"
[ 5.477] compiled for 1.21.1.4, module version = 1.0.0
[ 5.477] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.478] (II) Loading sub module "ramdac"
[ 5.478] (II) LoadModule: "ramdac"
[ 5.478] (II) Module "ramdac" already built-in
[ 5.496] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 5.496] (==) NVIDIA(0): RGB weight 888
[ 5.496] (==) NVIDIA(0): Default visual is TrueColor
[ 5.496] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.496] (**) Option "AllowNVIDIAGpuScreens"
[ 5.496] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 5.496] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 5.496] (**) NVIDIA(0): Enabling 2D acceleration
[ 5.496] (II) Loading sub module "glxserver_nvidia"
[ 5.496] (II) LoadModule: "glxserver_nvidia"
[ 5.496] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 5.547] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 5.547] compiled for 1.6.99.901, module version = 1.0.0
[ 5.547] Module class: X.Org Server Extension
[ 5.547] (II) NVIDIA GLX Module 525.60.11 Wed Nov 23 22:51:25 UTC 2022
[ 5.547] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 6.281] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:38:0:0
[ 6.281] (--) NVIDIA(0): DFP-0
[ 6.281] (--) NVIDIA(0): DFP-1
[ 6.281] (--) NVIDIA(0): DFP-2 (boot)
[ 6.281] (--) NVIDIA(0): DFP-3
[ 6.281] (--) NVIDIA(0): DFP-4
[ 6.281] (--) NVIDIA(0): DFP-5
[ 6.281] (--) NVIDIA(0): DFP-6
[ 6.282] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 2060 (TU106-A) at PCI:38:0:0
[ 6.282] (II) NVIDIA(0): (GPU-0)
[ 6.282] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 6.282] (--) NVIDIA(0): VideoBIOS: 90.06.2e.40.42
[ 6.282] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 6.282] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 6.282] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 6.282] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 6.282] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 6.282] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 6.282] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 6.297] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 6.297] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 6.297] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 6.297] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 6.297] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 6.297] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 6.297] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 6.297] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 6.297] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 6.297] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 6.297] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 6.297] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 6.299] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 6.299] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 6.299] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 6.364] (==) NVIDIA(0):
[ 6.364] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 6.364] (==) NVIDIA(0): will be used as the requested mode.
[ 6.365] (II) NVIDIA(0): Validated MetaModes:
[ 6.365] (II) NVIDIA(0): "DFP-2:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 6.365] (II) NVIDIA(0): Virtual screen size determined to be 3200 x 1080
[ 6.395] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 6.395] (--) NVIDIA(0): option
[ 6.396] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 6.396] (II) NVIDIA: access.
[ 6.399] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 6.399] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 6.399] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 6.399] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 6.399] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 6.399] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 6.399] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 6.399] (II) NVIDIA(0): Config Options in the README.
[ 6.417] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 6.504] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 6.504] (==) NVIDIA(0): Backing store enabled
[ 6.504] (==) NVIDIA(0): Silken mouse enabled
[ 6.504] (==) NVIDIA(0): DPMS enabled
[ 6.504] (II) Loading sub module "dri2"
[ 6.504] (II) LoadModule: "dri2"
[ 6.504] (II) Module "dri2" already built-in
[ 6.504] (II) NVIDIA(0): [DRI2] Setup complete
[ 6.504] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 6.504] (II) Initializing extension Generic Event Extension
[ 6.504] (II) Initializing extension SHAPE
[ 6.504] (II) Initializing extension MIT-SHM
[ 6.504] (II) Initializing extension XInputExtension
[ 6.505] (II) Initializing extension XTEST
[ 6.505] (II) Initializing extension BIG-REQUESTS
[ 6.505] (II) Initializing extension SYNC
[ 6.505] (II) Initializing extension XKEYBOARD
[ 6.505] (II) Initializing extension XC-MISC
[ 6.505] (II) Initializing extension SECURITY
[ 6.505] (II) Initializing extension XFIXES
[ 6.505] (II) Initializing extension RENDER
[ 6.505] (II) Initializing extension RANDR
[ 6.505] (II) Initializing extension COMPOSITE
[ 6.505] (II) Initializing extension DAMAGE
[ 6.505] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.505] (II) Initializing extension DOUBLE-BUFFER
[ 6.505] (II) Initializing extension RECORD
[ 6.505] (II) Initializing extension DPMS
[ 6.505] (II) Initializing extension Present
[ 6.506] (II) Initializing extension DRI3
[ 6.506] (II) Initializing extension X-Resource
[ 6.506] (II) Initializing extension XVideo
[ 6.506] (II) Initializing extension XVideo-MotionCompensation
[ 6.506] (II) Initializing extension GLX
[ 6.506] (II) Indirect GLX disabled.
[ 6.506] (II) GLX: Another vendor is already registered for screen 0
[ 6.506] (II) Initializing extension XFree86-VidModeExtension
[ 6.506] (II) Initializing extension XFree86-DGA
[ 6.506] (II) Initializing extension XFree86-DRI
[ 6.506] (II) Initializing extension DRI2
[ 6.506] (II) Initializing extension NV-GLX
[ 6.506] (II) Initializing extension NV-CONTROL
[ 6.506] (II) Initializing extension XINERAMA
[ 6.553] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 6.553] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.553] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.553] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.553] (II) LoadModule: "libinput"
[ 6.553] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 6.557] (II) Module libinput: vendor="X.Org Foundation"
[ 6.557] compiled for 1.21.1.3, module version = 1.2.1
[ 6.557] Module class: X.Org XInput Driver
[ 6.557] ABI class: X.Org XInput driver, version 24.4
[ 6.557] (II) Using input driver 'libinput' for 'Power Button'
[ 6.557] (**) Power Button: always reports core events
[ 6.557] (**) Option "Device" "/dev/input/event1"
[ 6.560] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.560] (II) event1 - Power Button: device is a keyboard
[ 6.560] (II) event1 - Power Button: device removed
[ 6.589] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 6.589] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 6.589] (**) Option "xkb_layout" "us"
[ 6.590] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.590] (II) event1 - Power Button: device is a keyboard
[ 6.591] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 6.591] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.591] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.591] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.591] (II) Using input driver 'libinput' for 'Power Button'
[ 6.591] (**) Power Button: always reports core events
[ 6.591] (**) Option "Device" "/dev/input/event0"
[ 6.592] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.592] (II) event0 - Power Button: device is a keyboard
[ 6.592] (II) event0 - Power Button: device removed
[ 6.616] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 6.616] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 6.616] (**) Option "xkb_layout" "us"
[ 6.617] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.617] (II) event0 - Power Button: device is a keyboard
[ 6.618] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/event21)
[ 6.618] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 6.618] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 6.618] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse'
[ 6.618] (**) Logitech G102 Prodigy Gaming Mouse: always reports core events
[ 6.618] (**) Option "Device" "/dev/input/event21"
[ 6.674] (II) event21 - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[ 6.674] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[ 6.674] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device removed
[ 6.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/0003:046D:C084.0006/input/input23/event21"
[ 6.736] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse" (type: MOUSE, id 8)
[ 6.736] (**) Option "AccelerationScheme" "none"
[ 6.736] (**) Logitech G102 Prodigy Gaming Mouse: (accel) selected scheme none/0
[ 6.736] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration factor: 2.000
[ 6.736] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration threshold: 4
[ 6.794] (II) event21 - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[ 6.794] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[ 6.795] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/mouse0)
[ 6.795] (II) No input driver specified, ignoring this device.
[ 6.795] (II) This device may have been added with another device file.
[ 6.796] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse Keyboard (/dev/input/event22)
[ 6.796] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 6.796] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 6.796] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 6.796] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse Keyboard'
[ 6.796] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: always reports core events
[ 6.796] (**) Option "Device" "/dev/input/event22"
[ 6.798] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 6.798] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device is a keyboard
[ 6.798] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device removed
[ 6.829] (II) libinput: Logitech G102 Prodigy Gaming Mouse Keyboard: needs a virtual subdevice
[ 6.829] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:046D:C084.0007/input/input24/event22"
[ 6.829] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse Keyboard" (type: MOUSE, id 9)
[ 6.829] (**) Option "AccelerationScheme" "none"
[ 6.829] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 6.829] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 6.829] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 6.831] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 6.831] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device is a keyboard
[ 6.832] (II) config/udev: Adding input device Logitech Gaming Keyboard G213 (/dev/input/event16)
[ 6.832] (**) Logitech Gaming Keyboard G213: Applying InputClass "evdev keyboard catchall"
[ 6.832] (**) Logitech Gaming Keyboard G213: Applying InputClass "libinput keyboard catchall"
[ 6.832] (**) Logitech Gaming Keyboard G213: Applying InputClass "system-keyboard"
[ 6.832] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard G213'
[ 6.832] (**) Logitech Gaming Keyboard G213: always reports core events
[ 6.832] (**) Option "Device" "/dev/input/event16"
[ 6.834] (II) event16 - Logitech Gaming Keyboard G213: is tagged by udev as: Keyboard
[ 6.834] (II) event16 - Logitech Gaming Keyboard G213: device is a keyboard
[ 6.835] (II) event16 - Logitech Gaming Keyboard G213: device removed
[ 6.869] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.0/0003:046D:C336.0001/input/input16/event16"
[ 6.869] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G213" (type: KEYBOARD, id 10)
[ 6.869] (**) Option "xkb_layout" "us"
[ 6.871] (II) event16 - Logitech Gaming Keyboard G213: is tagged by udev as: Keyboard
[ 6.871] (II) event16 - Logitech Gaming Keyboard G213: device is a keyboard
[ 6.872] (II) config/udev: Adding input device Logitech Gaming Keyboard G213 Keyboard (/dev/input/event17)
[ 6.872] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 6.872] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 6.872] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "system-keyboard"
[ 6.872] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard G213 Keyboard'
[ 6.872] (**) Logitech Gaming Keyboard G213 Keyboard: always reports core events
[ 6.872] (**) Option "Device" "/dev/input/event17"
[ 6.874] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: is tagged by udev as: Keyboard
[ 6.874] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device is a keyboard
[ 6.874] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device removed
[ 6.909] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.1/0003:046D:C336.0002/input/input17/event17"
[ 6.909] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G213 Keyboard" (type: KEYBOARD, id 11)
[ 6.909] (**) Option "xkb_layout" "us"
[ 6.911] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: is tagged by udev as: Keyboard
[ 6.911] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device is a keyboard
[ 6.912] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control (/dev/input/event18)
[ 6.912] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "evdev keyboard catchall"
[ 6.912] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "libinput keyboard catchall"
[ 6.912] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "system-keyboard"
[ 6.912] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control'
[ 6.912] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: always reports core events
[ 6.912] (**) Option "Device" "/dev/input/event18"
[ 6.914] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 6.914] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 6.914] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device removed
[ 6.949] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.0/0003:2516:0051.0003/input/input20/event18"
[ 6.949] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control" (type: KEYBOARD, id 12)
[ 6.949] (**) Option "xkb_layout" "us"
[ 6.951] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 6.952] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 6.953] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control System Control (/dev/input/event19)
[ 6.953] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "evdev keyboard catchall"
[ 6.953] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "libinput keyboard catchall"
[ 6.953] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "system-keyboard"
[ 6.953] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control System Control'
[ 6.953] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: always reports core events
[ 6.953] (**) Option "Device" "/dev/input/event19"
[ 6.955] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 6.955] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 6.955] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device removed
[ 6.989] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.2/0003:2516:0051.0005/input/input21/event19"
[ 6.989] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control System Control" (type: KEYBOARD, id 13)
[ 6.989] (**) Option "xkb_layout" "us"
[ 6.991] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 6.991] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 6.992] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control (/dev/input/event20)
[ 6.992] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 6.992] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 6.992] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "system-keyboard"
[ 6.992] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control'
[ 6.992] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: always reports core events
[ 6.992] (**) Option "Device" "/dev/input/event20"
[ 6.994] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 6.994] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 6.994] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device removed
[ 7.056] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.2/0003:2516:0051.0005/input/input22/event20"
[ 7.056] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control" (type: KEYBOARD, id 14)
[ 7.056] (**) Option "xkb_layout" "us"
[ 7.058] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 7.058] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 7.059] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event3)
[ 7.059] (II) No input driver specified, ignoring this device.
[ 7.059] (II) This device may have been added with another device file.
[ 7.060] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[ 7.060] (II) No input driver specified, ignoring this device.
[ 7.060] (II) This device may have been added with another device file.
[ 7.060] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event5)
[ 7.061] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[ 7.061] (II) No input driver specified, ignoring this device.
[ 7.061] (II) This device may have been added with another device file.
[ 7.061] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event7)
[ 7.061] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event8)
[ 7.062] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event10)
[ 7.062] (II) No input driver specified, ignoring this device.
[ 7.062] (II) This device may have been added with another device file.
[ 7.062] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event11)
[ 7.063] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event12)
[ 7.063] (II) No input driver specified, ignoring this device.
[ 7.063] (II) This device may have been added with another device file.
[ 7.063] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event13)
[ 7.064] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event14)
[ 7.064] (II) No input driver specified, ignoring this device.
[ 7.064] (II) This device may have been added with another device file.
[ 7.064] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event15)
[ 7.065] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event9)
[ 7.065] (II) No input driver specified, ignoring this device.
[ 7.065] (II) This device may have been added with another device file.
[ 7.065] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 7.073] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.073] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.073] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 7.073] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse Keyboard'
[ 7.073] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: always reports core events
[ 7.073] (**) Option "Device" "/dev/input/event22"
[ 7.073] (II) libinput: Logitech G102 Prodigy Gaming Mouse Keyboard: is a virtual subdevice
[ 7.073] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:046D:C084.0007/input/input24/event22"
[ 7.073] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse Keyboard" (type: KEYBOARD, id 15)
[ 7.073] (**) Option "xkb_layout" "us"
[ 7.073] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 7.073] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 7.073] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 8.546] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.546] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 8.547] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 8.547] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.547] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 8.547] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 8.561] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 8.561] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 8.561] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 8.561] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 8.561] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 8.561] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 8.562] (--) NVIDIA(GPU-0):
[ 8.562] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 8.562] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 8.562] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 8.562] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 8.562] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 8.562] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 8.564] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 8.564] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 8.564] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 9.151] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 9.151] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 9.151] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 9.151] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.151] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.151] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.168] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 9.168] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 9.168] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 9.169] (--) NVIDIA(GPU-0):
[ 9.169] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.169] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 9.169] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 9.169] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.169] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 9.169] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 9.169] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 9.169] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 9.169] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 9.171] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 9.171] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 9.171] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
That file should not exist, only
Both monitors get connected β¦ but i would set the nvidia.conf to use for both monitors the fixed layout.
Hmmm β¦ do you mixed something else too? Please share
mhwd -li
Where is this coming from? Is clear you have that custom xorg conf file, and to be honest have no time to read again all the topic to see what was done or not.
For that i always use
Option "ConnectToAcpid" "Off"
in the Section "Device"
of my /etc/X11/mhwd.d/nvidia.conf
I just reinstalled manjaro and the guide followed from the arch wiki, I created xorg.conf and copied it to that folder along the way, Iβll delete xorg.conf well and will only use nvidia.conf, thanks
logs
[ 5.325] (--) Log file renamed from "/var/log/Xorg.pid-675.log" to "/var/log/Xorg.0.log"
[ 5.326]
[ 5.326] Current Operating System: Linux rinky-ms7a37 5.15.81-1-MANJARO #1 SMP PREEMPT Fri Dec 2 21:02:26 UTC 2022 x86_64
[ 5.326] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=6ea82956-863f-4d76-b15b-f03130dbcfde rw rootflags=subvol=@ quiet resume=UUID=6c3cb512-24ea-44ba-80b0-7581dbe13f2b udev.log_priority=3
[ 5.326]
[ 5.326] Current version of pixman: 0.42.2
[ 5.326] Before reporting problems, check http://wiki.x.org
[ 5.326] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.326] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 7 00:21:38 2022
[ 5.327] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.327] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.327] (==) ServerLayout "layout"
[ 5.327] (**) |-->Screen "Screen0" (0)
[ 5.327] (**) | |-->Monitor "Monitor0"
[ 5.327] (**) | |-->Device "Device0"
[ 5.327] (==) Automatically adding devices
[ 5.327] (==) Automatically enabling devices
[ 5.327] (==) Automatically adding GPU devices
[ 5.327] (==) Automatically binding GPU devices
[ 5.327] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.329] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.329] Entry deleted from font path.
[ 5.329] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.329] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.329] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.329] (==) FontPath set to:
[ 5.329] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.329] (**) Extension "COMPOSITE" is enabled
[ 5.329] (II) The server relies on udev to provide the list of input devices.
[ 5.329] (II) Module ABI versions:
[ 5.329] X.Org ANSI C Emulation: 0.4
[ 5.329] X.Org Video Driver: 25.2
[ 5.329] X.Org XInput driver : 24.4
[ 5.329] X.Org Server Extension : 10.0
[ 5.329] (++) using VT number 1
[ 5.329] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.330] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.330] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:26:00.0/drm/card0
[ 5.331] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.331] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.332] (--) PCI:*(38@0:0:0) 10de:1f08:1458:3fc2 rev 161, Mem @ 0xfb000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 5.332] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.332] (II) LoadModule: "glx"
[ 5.333] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.338] (II) Module glx: vendor="X.Org Foundation"
[ 5.338] compiled for 1.21.1.4, module version = 1.0.0
[ 5.338] ABI class: X.Org Server Extension, version 10.0
[ 5.338] (II) LoadModule: "nvidia"
[ 5.338] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 5.345] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 5.345] compiled for 1.6.99.901, module version = 1.0.0
[ 5.345] Module class: X.Org Video Driver
[ 5.345] (II) NVIDIA dlloader X Driver 525.60.11 Wed Nov 23 22:56:57 UTC 2022
[ 5.345] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5.345] (II) Loading sub module "fb"
[ 5.345] (II) LoadModule: "fb"
[ 5.345] (II) Module "fb" already built-in
[ 5.345] (II) Loading sub module "wfb"
[ 5.345] (II) LoadModule: "wfb"
[ 5.346] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5.346] (II) Module wfb: vendor="X.Org Foundation"
[ 5.346] compiled for 1.21.1.4, module version = 1.0.0
[ 5.346] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.346] (II) Loading sub module "ramdac"
[ 5.346] (II) LoadModule: "ramdac"
[ 5.346] (II) Module "ramdac" already built-in
[ 5.349] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 5.349] (==) NVIDIA(0): RGB weight 888
[ 5.349] (==) NVIDIA(0): Default visual is TrueColor
[ 5.349] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.349] (**) Option "AllowNVIDIAGpuScreens"
[ 5.349] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 5.349] (**) NVIDIA(0): Option "Stereo" "0"
[ 5.349] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 5.349] (**) NVIDIA(0): Option "SLI" "Off"
[ 5.349] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 5.349] (**) NVIDIA(0): Option "ConnectToAcpid" "Off"
[ 5.349] (**) NVIDIA(0): Option "BaseMosaic" "off"
[ 5.349] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 5.349] (**) NVIDIA(0): Stereo disabled by request
[ 5.349] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 5.349] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 5.349] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 1920x1080_60 +0+0, DP-4: 1280x1024_75 +1920+0"
[ 5.349] (**) NVIDIA(0): Enabling 2D acceleration
[ 5.349] (II) Loading sub module "glxserver_nvidia"
[ 5.349] (II) LoadModule: "glxserver_nvidia"
[ 5.349] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 5.399] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 5.399] compiled for 1.6.99.901, module version = 1.0.0
[ 5.399] Module class: X.Org Server Extension
[ 5.399] (II) NVIDIA GLX Module 525.60.11 Wed Nov 23 22:51:25 UTC 2022
[ 5.399] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 6.117] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:38:0:0
[ 6.117] (--) NVIDIA(0): DFP-0
[ 6.117] (--) NVIDIA(0): DFP-1
[ 6.117] (--) NVIDIA(0): DFP-2 (boot)
[ 6.117] (--) NVIDIA(0): DFP-3
[ 6.117] (--) NVIDIA(0): DFP-4
[ 6.117] (--) NVIDIA(0): DFP-5
[ 6.117] (--) NVIDIA(0): DFP-6
[ 6.118] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 2060 (TU106-A) at PCI:38:0:0
[ 6.118] (II) NVIDIA(0): (GPU-0)
[ 6.118] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 6.118] (--) NVIDIA(0): VideoBIOS: 90.06.2e.40.42
[ 6.118] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 6.118] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 6.118] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 6.118] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 6.118] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 6.118] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 6.118] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 6.133] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 6.133] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 6.133] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 6.133] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 6.133] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 6.133] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 6.133] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 6.133] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 6.133] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 6.133] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 6.133] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 6.133] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 6.135] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 6.135] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 6.135] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 6.204] (II) NVIDIA(0): Validated MetaModes:
[ 6.204] (II) NVIDIA(0): "HDMI-0:1920x1080_60+0+0,DP-4:1280x1024_75+1920+0"
[ 6.204] (II) NVIDIA(0): Virtual screen size determined to be 3200 x 1080
[ 6.235] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 6.235] (--) NVIDIA(0): option
[ 6.235] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 6.235] (II) NVIDIA: access.
[ 6.257] (II) NVIDIA(0): Setting mode "HDMI-0:1920x1080_60+0+0,DP-4:1280x1024_75+1920+0"
[ 6.346] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 6.346] (==) NVIDIA(0): Backing store enabled
[ 6.346] (==) NVIDIA(0): Silken mouse enabled
[ 6.347] (**) NVIDIA(0): DPMS enabled
[ 6.347] (II) Loading sub module "dri2"
[ 6.347] (II) LoadModule: "dri2"
[ 6.347] (II) Module "dri2" already built-in
[ 6.347] (II) NVIDIA(0): [DRI2] Setup complete
[ 6.347] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 6.347] (II) Initializing extension Generic Event Extension
[ 6.347] (II) Initializing extension SHAPE
[ 6.347] (II) Initializing extension MIT-SHM
[ 6.347] (II) Initializing extension XInputExtension
[ 6.347] (II) Initializing extension XTEST
[ 6.347] (II) Initializing extension BIG-REQUESTS
[ 6.347] (II) Initializing extension SYNC
[ 6.347] (II) Initializing extension XKEYBOARD
[ 6.347] (II) Initializing extension XC-MISC
[ 6.347] (II) Initializing extension SECURITY
[ 6.347] (II) Initializing extension XFIXES
[ 6.347] (II) Initializing extension RENDER
[ 6.347] (II) Initializing extension RANDR
[ 6.348] (II) Initializing extension COMPOSITE
[ 6.348] (II) Initializing extension DAMAGE
[ 6.348] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.348] (II) Initializing extension DOUBLE-BUFFER
[ 6.348] (II) Initializing extension RECORD
[ 6.348] (II) Initializing extension DPMS
[ 6.348] (II) Initializing extension Present
[ 6.348] (II) Initializing extension DRI3
[ 6.348] (II) Initializing extension X-Resource
[ 6.348] (II) Initializing extension XVideo
[ 6.348] (II) Initializing extension XVideo-MotionCompensation
[ 6.348] (II) Initializing extension GLX
[ 6.348] (II) Indirect GLX disabled.
[ 6.348] (II) GLX: Another vendor is already registered for screen 0
[ 6.348] (II) Initializing extension XFree86-VidModeExtension
[ 6.348] (II) Initializing extension XFree86-DGA
[ 6.348] (II) Initializing extension XFree86-DRI
[ 6.348] (II) Initializing extension DRI2
[ 6.348] (II) Initializing extension NV-GLX
[ 6.348] (II) Initializing extension NV-CONTROL
[ 6.349] (II) Initializing extension XINERAMA
[ 6.394] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 6.394] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.394] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.394] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.394] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 6.394] (II) LoadModule: "libinput"
[ 6.395] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 6.398] (II) Module libinput: vendor="X.Org Foundation"
[ 6.398] compiled for 1.21.1.3, module version = 1.2.1
[ 6.398] Module class: X.Org XInput Driver
[ 6.398] ABI class: X.Org XInput driver, version 24.4
[ 6.398] (II) Using input driver 'libinput' for 'Power Button'
[ 6.398] (**) Power Button: always reports core events
[ 6.398] (**) Option "Device" "/dev/input/event1"
[ 6.401] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.401] (II) event1 - Power Button: device is a keyboard
[ 6.401] (II) event1 - Power Button: device removed
[ 6.429] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 6.429] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 6.429] (**) Option "xkb_layout" "us"
[ 6.429] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.457] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.457] (II) event1 - Power Button: device is a keyboard
[ 6.458] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 6.458] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.458] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.458] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.458] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 6.458] (II) Using input driver 'libinput' for 'Power Button'
[ 6.458] (**) Power Button: always reports core events
[ 6.458] (**) Option "Device" "/dev/input/event0"
[ 6.459] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.459] (II) event0 - Power Button: device is a keyboard
[ 6.459] (II) event0 - Power Button: device removed
[ 6.482] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 6.482] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 6.482] (**) Option "xkb_layout" "us"
[ 6.482] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.483] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.483] (II) event0 - Power Button: device is a keyboard
[ 6.483] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/event21)
[ 6.483] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 6.483] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 6.483] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse'
[ 6.483] (**) Logitech G102 Prodigy Gaming Mouse: always reports core events
[ 6.483] (**) Option "Device" "/dev/input/event21"
[ 6.539] (II) event21 - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[ 6.539] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[ 6.539] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device removed
[ 6.602] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/0003:046D:C084.0006/input/input23/event21"
[ 6.602] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse" (type: MOUSE, id 8)
[ 6.602] (**) Option "AccelerationScheme" "none"
[ 6.602] (**) Logitech G102 Prodigy Gaming Mouse: (accel) selected scheme none/0
[ 6.602] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration factor: 2.000
[ 6.602] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration threshold: 4
[ 6.660] (II) event21 - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[ 6.660] (II) event21 - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[ 6.661] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/mouse0)
[ 6.661] (II) No input driver specified, ignoring this device.
[ 6.661] (II) This device may have been added with another device file.
[ 6.661] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse Keyboard (/dev/input/event22)
[ 6.661] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 6.661] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 6.661] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 6.661] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "Keyboard Defaults"
[ 6.661] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse Keyboard'
[ 6.661] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: always reports core events
[ 6.661] (**) Option "Device" "/dev/input/event22"
[ 6.662] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 6.662] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device is a keyboard
[ 6.662] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device removed
[ 6.696] (II) libinput: Logitech G102 Prodigy Gaming Mouse Keyboard: needs a virtual subdevice
[ 6.696] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:046D:C084.0007/input/input24/event22"
[ 6.696] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse Keyboard" (type: MOUSE, id 9)
[ 6.696] (**) Option "AccelerationScheme" "none"
[ 6.696] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 6.696] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 6.696] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 6.698] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 6.698] (II) event22 - Logitech G102 Prodigy Gaming Mouse Keyboard: device is a keyboard
[ 6.699] (II) config/udev: Adding input device Logitech Gaming Keyboard G213 (/dev/input/event16)
[ 6.699] (**) Logitech Gaming Keyboard G213: Applying InputClass "evdev keyboard catchall"
[ 6.699] (**) Logitech Gaming Keyboard G213: Applying InputClass "libinput keyboard catchall"
[ 6.699] (**) Logitech Gaming Keyboard G213: Applying InputClass "system-keyboard"
[ 6.699] (**) Logitech Gaming Keyboard G213: Applying InputClass "Keyboard Defaults"
[ 6.699] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard G213'
[ 6.699] (**) Logitech Gaming Keyboard G213: always reports core events
[ 6.699] (**) Option "Device" "/dev/input/event16"
[ 6.701] (II) event16 - Logitech Gaming Keyboard G213: is tagged by udev as: Keyboard
[ 6.701] (II) event16 - Logitech Gaming Keyboard G213: device is a keyboard
[ 6.701] (II) event16 - Logitech Gaming Keyboard G213: device removed
[ 6.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.0/0003:046D:C336.0001/input/input16/event16"
[ 6.736] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G213" (type: KEYBOARD, id 10)
[ 6.736] (**) Option "xkb_layout" "us"
[ 6.736] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.737] (II) event16 - Logitech Gaming Keyboard G213: is tagged by udev as: Keyboard
[ 6.737] (II) event16 - Logitech Gaming Keyboard G213: device is a keyboard
[ 6.738] (II) config/udev: Adding input device Logitech Gaming Keyboard G213 Keyboard (/dev/input/event17)
[ 6.738] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 6.738] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 6.738] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "system-keyboard"
[ 6.738] (**) Logitech Gaming Keyboard G213 Keyboard: Applying InputClass "Keyboard Defaults"
[ 6.738] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard G213 Keyboard'
[ 6.738] (**) Logitech Gaming Keyboard G213 Keyboard: always reports core events
[ 6.738] (**) Option "Device" "/dev/input/event17"
[ 6.739] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: is tagged by udev as: Keyboard
[ 6.739] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device is a keyboard
[ 6.739] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device removed
[ 6.776] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.1/0003:046D:C336.0002/input/input17/event17"
[ 6.776] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G213 Keyboard" (type: KEYBOARD, id 11)
[ 6.776] (**) Option "xkb_layout" "us"
[ 6.776] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.778] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: is tagged by udev as: Keyboard
[ 6.778] (II) event17 - Logitech Gaming Keyboard G213 Keyboard: device is a keyboard
[ 6.779] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control (/dev/input/event18)
[ 6.779] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "evdev keyboard catchall"
[ 6.779] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "libinput keyboard catchall"
[ 6.779] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "system-keyboard"
[ 6.779] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "Keyboard Defaults"
[ 6.779] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control'
[ 6.779] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: always reports core events
[ 6.779] (**) Option "Device" "/dev/input/event18"
[ 6.781] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 6.781] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 6.781] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device removed
[ 6.815] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.0/0003:2516:0051.0003/input/input20/event18"
[ 6.815] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control" (type: KEYBOARD, id 12)
[ 6.815] (**) Option "xkb_layout" "us"
[ 6.815] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.816] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 6.817] (II) event18 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 6.817] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control System Control (/dev/input/event19)
[ 6.817] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "evdev keyboard catchall"
[ 6.817] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "libinput keyboard catchall"
[ 6.817] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "system-keyboard"
[ 6.817] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "Keyboard Defaults"
[ 6.817] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control System Control'
[ 6.817] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: always reports core events
[ 6.817] (**) Option "Device" "/dev/input/event19"
[ 6.818] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 6.818] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 6.818] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device removed
[ 6.842] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.2/0003:2516:0051.0005/input/input21/event19"
[ 6.843] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control System Control" (type: KEYBOARD, id 13)
[ 6.843] (**) Option "xkb_layout" "us"
[ 6.843] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.844] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 6.845] (II) event19 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 6.846] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control (/dev/input/event20)
[ 6.846] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 6.846] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 6.846] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "system-keyboard"
[ 6.846] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "Keyboard Defaults"
[ 6.846] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control'
[ 6.846] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: always reports core events
[ 6.846] (**) Option "Device" "/dev/input/event20"
[ 6.848] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 6.848] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 6.848] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device removed
[ 6.909] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.2/0003:2516:0051.0005/input/input22/event20"
[ 6.909] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control" (type: KEYBOARD, id 14)
[ 6.909] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.910] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 6.911] (II) event20 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 6.912] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event3)
[ 6.912] (II) No input driver specified, ignoring this device.
[ 6.912] (II) This device may have been added with another device file.
[ 6.912] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[ 6.912] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event5)
[ 6.913] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[ 6.913] (II) No input driver specified, ignoring this device.
[ 6.913] (II) This device may have been added with another device file.
[ 6.913] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event7)
[ 6.914] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event8)
[ 6.914] (II) No input driver specified, ignoring this device.
[ 6.914] (II) This device may have been added with another device file.
[ 6.914] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event10)
[ 6.915] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event11)
[ 6.915] (II) No input driver specified, ignoring this device.
[ 6.915] (II) This device may have been added with another device file.
[ 6.915] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event12)
[ 6.916] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event13)
[ 6.916] (II) No input driver specified, ignoring this device.
[ 6.916] (II) This device may have been added with another device file.
[ 6.916] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event14)
[ 6.916] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event15)
[ 6.917] (II) No input driver specified, ignoring this device.
[ 6.917] (II) This device may have been added with another device file.
[ 6.917] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event9)
[ 6.917] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 6.925] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 6.925] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 6.925] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 6.925] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: Applying InputClass "Keyboard Defaults"
[ 6.925] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse Keyboard'
[ 6.925] (**) Logitech G102 Prodigy Gaming Mouse Keyboard: always reports core events
[ 6.925] (**) Option "Device" "/dev/input/event22"
[ 6.925] (II) libinput: Logitech G102 Prodigy Gaming Mouse Keyboard: is a virtual subdevice
[ 6.925] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:046D:C084.0007/input/input24/event22"
[ 6.925] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse Keyboard" (type: KEYBOARD, id 15)
[ 6.925] (**) Option "xkb_layout" "us"
[ 6.925] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 6.926] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 6.926] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 6.926] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 8.351] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.351] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 8.351] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 8.352] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.352] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 8.352] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 8.366] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 8.366] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 8.366] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 8.366] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 8.366] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 8.366] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 8.366] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 8.366] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 8.366] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 8.367] (--) NVIDIA(GPU-0):
[ 8.367] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 8.367] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 8.367] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 8.369] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 8.369] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 8.369] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 8.711] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.711] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 8.711] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 8.711] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.711] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 8.711] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 8.726] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): connected
[ 8.726] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): Internal TMDS
[ 8.726] (--) NVIDIA(GPU-0): BenQ GL2460 (DFP-2): 165.0 MHz maximum pixel clock
[ 8.726] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 8.726] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 8.726] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 8.727] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 8.727] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 8.727] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 8.727] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): connected
[ 8.727] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): Internal DisplayPort
[ 8.727] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-5): 2660.0 MHz maximum pixel clock
[ 8.730] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 8.730] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 8.730] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 8.828] (II) NVIDIA(0): Setting mode "HDMI-0: 1920x1080_60 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @1280x1024 +1920+0 {ViewPortIn=1280x1024, ViewPortOut=1280x1024+0+0}"
deleted xorg.conf, now my folder and files inside it looks like this
βββ mhwd.d
β βββ nvidia.conf
β βββ nvidia.conf.nvidia-xconfig-original
βββ xinit
β βββ xinitrc
β βββ xinitrc.d
β β βββ 40-libcanberra-gtk-module.sh
β β βββ 50-systemd-user.sh
β β βββ 80xapp-gtk3-module.sh
β βββ xserverrc
βββ xorg.conf.d
βββ 00-keyboard.conf
βββ 30-touchpad.conf
βββ 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
contents of nvidia.conf file
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 525.60.11
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "BenQ GL2460"
HorizSync 30.0 - 83.0
VertRefresh 50.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 2060"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-0: 1920x1080_60 +0+0, DP-4: 1280x1024_75 +1920+0"
Option "SLI" "Off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
in the settings I set everything according to the layout, deleted the kscreen folder, rebooted and the second screen did not work
through the mons utility (by the mons -e right command), I manage to turn on the second monitor, but I need to enter the command several times (random) to make it work, I want the second monitor to work without such crutches when loading
Quite interesting, but canβt say i have a clue why it does that. Have you tried to set the Samsung monitor at 60Hz instead of 75Hz?
no, I didnβt try it, I tried everything in auto mode, either fixed with 75 Hertz, fixed with 60 did not try, tomorrow Iβll try, thanks
