Welcome to the Manjaro community @strealstud
Could you please boot into a live session, open a terminal, and run the following command:
inxi -zv8
Copy and paste the entire output here. Make sure that you place three backticks ``` on the lines before and after the posted text so that it appears in the correct format.
Further reading:
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
The title is not clear - use a short title about your issue - then clearly elaborate on the issue.
If you are trying to install - please ensure you have verified the downloaded ISO using checksum and/or signature.
If you have completed the installation and subsequently did a system restart - a rare hardware issue - likely disk related occurred.
This kind of issue is impossible to fix using a forum thread.
You may try a restart using the installation media - run a file system check - and redo the installation.
Do you mean that the USB live session doesn’t boot at all or after installation ?
