I’m using a piece of software called Xournal++ for PDF annotation using the touchscreen on my lenovo Thinkpad X1 Yoga Gen4 and the stylus that comes with it. It used to work just fine
Recently I tried annotating a pdf, and it would not allow me to zoom in our out. That was with me trying to pinch to zoom. Then I looked at the menu under View and the zoom in and out controls were greyed out.
On my desktop, the zoom in and out controls are not greyed out and I can zoom in and out. However its not as useful there.
The application was installed from the official community repositories. It is version 1.1.3-1
When I tried to take a screenshot of the view menu to show the greying out, the screenshot did not capture the dropped down menu.
Any idea what the problem is?
Thanks
Jason
Moderator edit:
- Removed useless screenshots
- Removed [SOLVED] from title, mark it solved instead
- Moved to #support:applications as
xournalpp
is in the official repos
