Kindly help!
It says about all emergency help like,
-p ,-n ,-y etc. But when I’m typing it it says not found
You get a help page when running:
e2fsck --help
or the long version:
man e2fsck
What to do in the following case:-
Fsck.ext2 [-panyrcdfktvDFV] [-b superblock ] [-B blocksize], etc.
Then it goes like -
Emergency help-
-p
-n
-y
-c
-f
Extended option -z undo_file device
Don’t know what to do…help
First chill, get a cup of tea and relax. Whoever acts hastily makes it worse than it already is.
Can you explain what happens?
Do you have an USB-Stick ready to boot a Manjaro live session?
Usually you can repair an ext file system with:
fsck -f -y /dev/<devicename>
Could you please tell me how to upload a pic. I’m not able to do so…
I’m trying to upload a pic but error aa rha hai
https://paste.pics/dae5359dfa5a231c107a955e25394fa8
I have uploaded it … could u look n tell what to do
I see you are in rootfs.
fsck -f -y /dev/sda1
https://paste.pics/aac6dcb10964eeb1a96703b47b75e301
What to do next
There are I/O errors, which indicates that there is a hardware problem. Is it a rotating hard drive disk? If so, then I would say the HDD is just dying right now, or has badblocks, which are not known by the file system.
Anyway. It would better to boot a Manjaro Live Session and check the health of the Disk:
sudo smartctl -x /dev/sda
Ho gaya thik…thnx
