I'm in Skype hell.
Hi klaude_kraap. You've got some pretty good ideas. earlier today I did create a seperate user account just for skype and work related files... for security. No go.
Hi rbrick49. That's exactly what I'm talking about and I'm not sure if it's a Skype problem since it trashed my computer on Friday. Build, install... fine. But it doesn't work. (Kind of like a blond - :slight_smile: )
Update. Skype classic installs, starts-up wonderfully fast, and won't log in to save the planet.
Yeah. I give in. Will move on to some other VOIP apparatus.
Thanks everyone. I'm leaving this thread as unsolved and unsolvable. At least by me.
Good advice to remember. It trashed my computer completely. I had to reinstall and then I found myself on a merry-go-round. Over and out.
would of been nice too know all these details from the start :man_shrugging: lots of mystery's here
oky, and are we sure the password is correct and the username ? in skype
some software can only be run on the default user, something something root access
just installed it on manjaro Cinammon it works fine wont work on manjaro xfce
Same issue on my computer gnome stable with latest skype version: skypeforlinux-preview-bin-8.51.76.87-2
It works well with the previous one: skypeforlinux-preview-bin-8.51.76.74-1.
Cheers,
@rbrick49 @d7rk and the plot thickens ... :alien: :ghost:
Ok, I noticed I had a pending update and it was skype. I just updated it and it doesn't run. I then downgraded it to the last version and it runs again. There's a definitely a problem with the new version.
ok thanks for that
mhhh, just check again now, both of you where right
strange, I deed search two or three time before, even after updating the DB, it was not appearing :crazy_face:
Yes the plot O the plot.
So why did i install skypeforlinux-stable-bin 3 hrs ago and it works fine then :+1:
their are no updates for it.
As for skype- secure the name says it all so secure skype does not run that what you call secure lol. :heart_eyes:
still thickening ... :robot::clown_face:
@mbb :man_shrugging:
@notageek :eyeglasses:
Seeing the discussion in skypeforlinux-stable-bin comment section, it seems that skype needs unprivileged user namespaces to run which is disabled by default in Manjaro kernels.
To enable it temporarily , use this command sudo sysctl kernel.unprivileged_userns_clone=1.
Yes. That's what I think. Everything was fine until I upgraded Skype last Friday. Then everything went to hell and drug me alone for the ride.
(It's a Microsoft conspiracy! They're after us again!)
I have skypeforlinux-stable-bin 8.51.0.86-2 on XFCE appears to be working OK
updated about 6 hours ago for me
if problem continues despite reinstalling, only user home folder data would remain
rm -r ~/.config/skypeforlinux/
and remove any other folders/files in home that may have been added by other skype versions
and reboot before launching skype for first run
I had skype fail to load in the past - never gets to login screen and notification is blank white blob
at the time i had been assuming skype would start ok after install like other Linux packages
but considering that skype was microsoft tat, and their tat usually requires a restart
appears to be what got it working for me
and skype has been ok with updates for over a year once it got through first-run configuration
i dont use skype, but i just installed to test it.
herecura/skypeforlinux-stable 8.51.76.87-1
    Skype for Linux - Stable/Release Version
install > run > done. that's from the herecura repo btw.
Yeah, skypeforlinux 8.51 won't run for me either. Looking at the AUR comments, there are real problems for lots of people. Downgrading to 8.50 works for now.
There's also web.skype.com for skype in a browser. I got it to work with Firefox by going into about:config and adding general.useragent.override.skype.com with a value of Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36 (to make them think I'm using Chrome).
I would suggest a title change. It's the Apparmor hell. :japanese_goblin::fire:
if not 'stable' version maybe skypeforlinux-preview-bin v8.51.76.87-2
saedlar93! You're my hero. That worked. I've signed in and I'm waiting for me interview 30 minutes before it started. I will try to install skype-secure after the interview. Thank you!
Is there a way to make this permanent?
(Also, I was kidding about blonds. I'm in love with one...)
I don't think so. At least not for me. I'm not using Apparmor. Apparmor seems to be pretty difficult to use...I guess that's for another thread.
