I'm having trouble launching Dota 2
I could run it normally on Windows, then I had to switch to Linux and I can’t play it anymore :slightly_frowning_face:
My config:
Intel® Core™ i7-3770
Intel® HD Graphics 4000
Memory: 15gb
Error:
I’ve already tried the things he suggest, but nothing, the same error remains.
Read again the paragraph, then, “make sure”.
//EDIT:
You’re not on Windows now.
SYSTEM REQUIREMENTS
SteamOS + Linux
MINIMUM:
OS: Ubuntu 12.04 or newer
Processor: Dual core from Intel or AMD at 2.8 GHz
Memory: 4 GB RAM
Graphics: AMD GCN+, NVIDIA Kepler+, or Intel HD 5000-series or newer
Network: Broadband Internet connection
Storage: 60 GB available space
Sound Card: OpenAL Compatible Sound Card
Hi @Benjigx and welcome to the Manjaro community.
From the information both you and @omano have posted, it seems like you might not have the necessary system requirements under Linux.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. The linked page contains other links to useful information:
Instead of pasting images, you can place text in a scrollable preformatted texbox; or, quote tags, for example:
[quote]
This is some pasted text content.
[/quote]
…which will render as:
Much more forum goodness waits to be discovered.
Cheers.
