Ik kan updates niet binnen halen met de paketten manager in xfce
#1
Ik kan updates niet binnenhalen in xfce via pakketten manager !
foutmelding : conflicterende bestanden:thunar-archive-plugin:/usr/lib/xfce4/thunar-archive-plugin/engrampa.tap bestaat al in het systeem.
Ik ben bekend met linux maar nieuw in Manjaro.
Hoe kan ik dit oplossen ?
Alvast bedankt voor de hulp .
Grt,
#2
Terminal
sudo rm -r /usr/lib/xfce4/thunar-archive-plugin/engrampa.tap
sudo pacman -Syyu
#3
Advies voor de volgende keer; update via de terminal met
sudo pacman -Syyu
#4
Please do not use -Syyu when not needed.
Your day-to-day updates and installation of applications only require -Syu
When using -Syu you are saying to the server
  • do you have updated databases for me
  • server answer no
  • fine install the package
When using -Syyu you are saying to the server
  • server answer no
  • don’t you teach me you scumbag I don’t care I want them anyway
  • install that d… package
Only and only when you have updated your mirror list - then it is mandatory to use -Syyu.
#5
I thought only -Syyuhuhu should be avoided by any means :smiley:
Thanks for the heads up !!! :wink:
#6
Some have learned their pacman the art of ‘jodeln’
#7
Never knew it mattered. I thought it just did a rebuild of the local package database. Thanks for the heads up, will not recommend it that way anymore (unless the mirrorlist changed).
#8
Het is gelukt .
Iedereen die meegedacht heeft van harte bedankt !
Groeten,
